Question about HP OfficeJet 6110 All-In-One InkJet Printer
I need instructions on how to setup speed dial on HP 6110
I need instructions to setup speed dial on HP 6110 all in one.
    President:
  • 2,110 Answers
I would like to send a fax from my PC. I have a MS Word document and a HP 6110 xi connected as a printer to my PC. Can I send the fax directly to the other person or do I have to print it and send it via...
You can send the Word document as Fax from Your PC to Printer
Open the document and Click File menu and Click Print option
Choose the HP Officejet 6110 series Fax ( not the regular printer icon )
Click Print Button
You will find a cover page to enter the fax details
Enter the details and click SEND FAX button - the Printer will start dialing the # to send Fax ( word document )
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 19, 2011 | HP OfficeJet 6110 All-In-One InkJet...
I don't understand the one touch dialing on the HP 2140
Hi Suzeo. Many HP fax machines have the function you are requesting. It is called the broadcast fax feature. Look in your owner manual for this feature. If I knew which model you have I would have researched it for you. IF by chance, your machine does not have this feature, it would be money well spent to replace your current machine with one that does. Depending on how many pages the daily fax is, I am estimating that you are spending an hour or more each day on this task. J.
Jul 03, 2010 | HP Office Equipment & Supplies
I have a HP officejet 6110 all-in-one and I cannot fax a document. It works but i had to hook my new PC and I might have gotten my phone wires crossed. I am using modem high speed internet and I was able...
HI,
ITS PROBLEM WITH URS RJ11 TELEPHONE CONNECTOR,
CHECK RJ 11 CONNECTOR WITH OTHER TELEPHONE,IF U HEAR DIAL TONE THEN PHONE LINE IS OK,I T MIGHT BE PROBLEM WITH URS PRINTER FEMALE CONNECTOR RJ 11 CONNNECTOR,
APPROCH PRINTER TECHNICHIAN...
TNKS
RABBANEES
Nov 11, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How to delete and program in speed numbers for fax
Create speed dial entries for fax numbers that you use frequently. The number of speed dial entries you can set up depends on the HP device. For more information, see the specifications for the HP device.
expanded.gifTo manually create a speed dial entry 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Click New Entry. 3 In the Speed Dial Settings - New Entry dialog box, type a name and fax number, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Note If you are creating a speed dial entry for a networked HP device and you are unable to save the entry, another user on the network might have accessed the same speed dial. Wait a few minutes and try to save the entry again. expanded.gifTo create a speed dial entry from the Address Book 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Under Address Book, click Select From. 3 In the Address Book dialog box, select one or more names, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Sep 11, 2009 | HP Office Equipment & Supplies
Is there software to support the speed dial settings for the fax machine in my HP 6110?
Here is the link to your machine manual
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=79477&lc=en&cc=us&dlc=en&lang=en&cc=us
On page 32 or 36 of the 1st list pdf manual there is information on how to configure speed dialing
Hope it helps.
Sep 04, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Please help me send a fax on my HP 5610
Send a fax
You can send a fax in a variety of ways. Using the control panel, you can send a blackand-
white or color fax from your HP All-in-One. You can also send a fax manually
from an attached phone. This allows you to speak with the recipient before sending
the fax.
If you frequently send faxes to the same numbers, you can set up speed dial entries.
For more information on setting up speed dial entries, see Set up speed dialing.
Send a basic fax
You can easily send a single- or multiple-page black-and-white fax by using the
control panel, as described here. If you want to send a color or photo fax, see the
onscreen HP Image Zone Help.
Note If you need printed confirmation that your faxes were successfully sent,
enable fax confirmation before sending any faxes. For more information, see
Print fax confirmation reports.
Tip You can also send a fax manually from a phone or by using monitor
dialing. These features allow you to control the pace of your dialing. They are
also useful when you want to use a calling card to charge the call and you
need to respond to tone prompts while dialing. For more information, see Send
a fax manually from a phone or Send a fax using monitor dialing.
1. Load your originals, with the print side up, into the document feeder tray. If you
are sending a single-page fax, such as a photograph, you can also load your
original on the glass.
Note If you are sending a multiple-page fax, you must load the originals
in the document feeder tray. You cannot fax a multiple-page document
from the glass.
2. Press Fax.
Oct 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
How do I set speed dial numbers?
Here is the procedure to setup speed dials (both individual and group) on your printer.
thx
Oct 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Fax will fax or receive fax
If it is a Officejet 6110 All-In-One first run a fax test:
Press Menu/Setup> Press the right arrow key to locate Tools> Press OK> Now press the right arrow key to locate Run Fax Test> and press Ok.
Check to see what has failed and correct what ever has failed in the fax test.
And follow the below mentioned steps to connect the All-In-One according to your setup:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu50333&cc=us&lc=en&dlc=en&product=79477
Good Luck
Oct 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Office Jet 6110 All in One faxing
This document covers the basic fax functions of the HP Officejet 6100 series. The HP Officejet 6100 series can perform the following functions:
  • Send and receive paper faxes.
  • Send and receive color faxes. Color faxes can be sent only to color fax capable machines. If a color fax is sent to a black-and-white only fax machine, the HP Officejet sends the fax in black and white.
See Figure 1 below to identify the buttons in the Fax area of the front panel. Figure 1: Identifying the fax area of the front panel c00259777.gif 1- Turns Auto Answer on or off 2- Scrolls through speed-dial entries 3- Redials the most recently dialed number 4- Dials fax numbers, enters text, and specifies menu items. 5- Starts a fax 6- Changes the fax resolution 7- Dials one-touch speed-dial numbers Fax settings Most fax settings are configured during installation through the Fax Setup Wizard. These settings, and some additional options, can be accessed through the front panel menu (see Figure 2). Figure 2: Changing fax settings from the front panel menu
1. Menu: enters the menu system.
2. Right and left arrows: navigate the submenus and options.
3. Enter: selects a submenu or option.
4. Cancel: exits from the menu. c00259778.gif Sending a fax To ensure the best quality when sending faxes in color, use a color original instead of a color copy. Follow these steps to send a fax:
  1. Load the original. Load originals directly on the glass or in ADF. For multi-page faxes, you must use the automatic document feeder (ADF). Loading original on the glass Place the original, print-side down, on the front-right corner of the glass. Loading original on the glass c00259779.gif Loading original in the ADF Place the original, print-side up, in the ADF. Adjust the paper-width guide to fit the original. Loading original in the ADF c00259780.gif
  2. Enter the fax number using the keypad. Dial the number just as you would from a telephone (dialing 1 before an area code, etc.)
  3. Press Start Fax Black or Color.
  4. If there is no original in the ADF, the display will read, "Send from Glass? Press 1 for Yes or 2 for No"
    • Press 1 to scan the document from the glass.
    • Press 2 to load the document in the ADF. The display will read, Load original, then press Enter .
Apr 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
131 people viewed this question
Ben Johnson
