Car hit in front 2009 grand cherokee auto shut down code 0688
Oh no problem
just restore default settings
Posted on Dec 30, 2008
Where is located the auto shut down relay of a 5.7 L engine
Should be under the hood. This seems to be pretty common so your local dealer should know exactly what going on if you tell them the story.
Jan 16, 2014 | 2007 Dodge Ram Truck
My jeep grand Cherokee will shut off and all the gauge on dashboard turn on
It could be the O2 sensor and the camshaft sensor. I have the same Jeep and having the same issues. Auto Parts stores have the sensor, just need to find a good mechanic that wont over charge you. When you do, ask then to run the codes to make sure.
Mar 21, 2012 | 1999 Jeep Grand Cherokee
Auto shut down from hitting a bump- no fuel pump or ignition - voltage gauge not working
You have a ASD relay (Auto shut down relay) this is not a safety device you basically knock something loose.Turn the key on do you hear the fuel pump go on. If you dont check the fuses for a open condition and fusable link that are on the battery with key on wiggle battery negative terminal especially at the engine block and the frame ,same with the Positive part of the battery terminal .
Mar 07, 2012 | 1994 Jeep Grand Cherokee
Auto shutdown security code removall
The 93 Grand Cherokee does not have an auto shutdown security code. To shut down the factory security, you have to unlock the rear tailgate lock cylinder with your key. If the jeep shuts down for any other reason, there is something else wrong with it.
Jan 26, 2011 | 1993 Jeep Grand Cherokee
Hits brake and car shut downs o
MANY THINGS WILL SHUT DOWN VECHICLE WHEN COMING TO A STOP.LIKE FAULTY TORQUE CONVERTER SOLENOID VALVE.IDLE SPEED CONTROL STOP WORKING OR LEAKING BRAKE BOOSTER.SCAN VECHICLE TO CHECK FOR TORQUE CONVERTER FAULT CODES.
Sep 07, 2010 | 1995 Jeep Grand Cherokee
Jeep starts and shuts off before even moving
You need to check the Diagnostic Trouble Codes and see what comes up. It definitely appears the ASD (Auto Shut Down) is kicking in, which is there to protect specific engine components.
Jul 18, 2010 | 2003 Jeep Grand Cherokee
1998 Jeep Grand Cherokee shuts down while driving.
97 cherokee crank sensor replaced, still shuts off, code 351
Apr 22, 2010 | 1998 Jeep Grand Cherokee
2001 jeep gd. cherokee larado 4.0 4wd auto. when
Have you run an engine control system fault code test? If not do that first.
Jun 08, 2017 | 2001 Jeep Grand Cherokee
2009 Jeep Grand Cherokee Laredo interior lights won't turn on
check your light dimmer & see if you have it set all the way down.If it's anything like my 99WJ it has an off setting when the dimmer is set all the down causing the interior lights to not come on when you open the doors,hope this helps
May 16, 2009 | 2009 Jeep Grand Cherokee
41 people viewed this question
 Grubhead
Grubhead
