Question about DeLonghi DE500 Dehumidifier
Delonghi dehumidifier frost light remains on
I have a 2 year old delonghi dec14 dehumidifier, after repairing a seized fan motor i reassembled the unit plugged in, switched on, everything seemed ok untill i noticed the unit was not filling up and the frost/pause light remained on usually goes off after 3 mins or so. i then took the unit apart again in case i had accidently dislodged any wireing but all seems to be in order and light remained on, i let it stand for 24 hours but still no joy. any help would be appreciated
  • Anonymous Jan 23, 2009
    I also have a Delonghi dec 14, which has just started staying stuck on pause and not going into dehumidify mode.
    Did you manage to sort yours , and which bit needed changing ?
    martyn
    oldercover@hotmail.com
  • frankmyers Feb 05, 2009
    No didnt manage to get mine going, its currently waiting at the back door till i can be bothered to take it to the dump !
Boba
  • 64 Answers
SOURCE: Frost, ice on coils DeLonghi DDE50E Dehumidifier
expected? of course! this is not ur solution try draining all the water to the sewerage if u cant try to pump it out with a vacuum cleaner (that can pump water) or a pump then turn on the Dehumidifier every time it frosts turn it off untill it defrosts or u can heat up the basement with a bellower and the Dehumidifier wont frost
Posted on Feb 06, 2006
techman
  • 3130 Answers
SOURCE: Dehumidifier Compressor is not working
this unit is very simular to an air conditioner except it has a humidistat instead of a thermistat.. if your handy with a continuity tester unplug the unit find the humidistat and check to see if its open or if its good then call the company at 1 800 322 3848 or contact the web site at customerservice@delonghiusa.info Good Luck
Posted on May 31, 2006
  • 3 Answers
SOURCE: Delonghi Dehumidifier DE500P - Code E3
Hi Thomast5263,
I live in NJ and the nearest center is in CT. So you can imagine that I am not gonna to ship my unit! :-)
The one I got is from Hartford, CT Utility Electric Service: 860-246-7271; talk to Dana and he is very helpful. They charged me $25 and shipped me the part and it now works fine.
When I talked to Dana he sounded pretty sure it was the condensor sensor. Simply call Dana and tell him that you have an "E3" code. I do NOT know the part number or ID.
Don't open the unit until you get the new part ---- it will help you to identify the part to be replaced. After you get the part, make sure you mark down all the screws (they are not the same! so pay attention which one is where). There are two tabs on the top so be careful when get them separate apart ---- don't force it or you might break it. The sensor itself is attached/stuck in between the copper coils under a black cover. Plug another end to the control board and you are done. Apparently there are two kinds of plug-in end ---- the first part Dana shipped to me did not match the old part so he has to send me another one which worked.
The whole procedure is not that difficult, but when you are doing this the first time you just need to be patient to locate all the screws and sparate the covers. From my experience you do need to take all covers off, otherwise you can not see the part and the wire.
Good luck to you and let me know the good news!
Posted on Oct 23, 2008
  • 52 Answers
SOURCE: dehumidifier coil frost up
Hi Eric where do you live? what is the Air on temperature i the basement? what is the Air off temp in the Basement? what temp difference are you getting.I ask where you are located in the world so we can work out the Ambient temperatures in the area.
Posted on Jun 08, 2009
heatman101
  • 43501 Answers
SOURCE: Dehumidifier is tripping circuit breaker.
The compressor is bad and is causing the circuits to trip....
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on Apr 30, 2010
Delonghi Dem 10 dehumidifier has stopped working - the 'operational light' turns on, but the fan does not start up so nothing happens.
It could be that the fan / fan motor has seized or jammed. Have a look through the vents and see if you can spin the fan. If not, you will need to strip the machine. Try lubricating the bushes / bearings. Often on these type of units, the vapours dry out the bushes and then they get tight and jam the fan.
Nov 08, 2013 | DeLonghi Dehumidifiers
DeLonghi Dem 10 dehumidifier stopped working - the 'operational light' turns on but the fan does not start up.
You may need a new fan motor. If you can get to this
motor, with the power disconnected, see if the blade
is free to move. Do you hear any sound coming from
this unit?
Nov 08, 2013 | LG DH30 GoldStar Dehumidifier
My dec14 has stopped prodicing water in the tank but seems to be working normally. I have damp patches on my walls so there is moisture to collect. Why has it stopped working please?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 12, 2011 | DeLonghi Dehumidifiers
My DeLonghi dehumidifier model DE500P is tripping the breake
the motor is tight, (can't turn) lubricate the motor bearings with light machine oil. retest. rust causes this. the motor "tries" to turn, more power is needed, still can't turn, power exceeds safe limits: breaker trips.
Apr 25, 2010 | DeLonghi DE500P Dehumidifier
Blower fan is seized Kenmore 54501 Dehumidifier?
If the blower motor is siezed up, then you need to replace the motor.
You can have new bearings put in it, but by the time you get thru it will cost you about the same as a new motor and you won't have any warranty on the old motor, you will have at least a one year warranty on the new one.
Aug 09, 2009 | Kenmore 54501 Dehumidifier
Dehumidifier coil frost up
Jun 08, 2009 | Whirlpool 75-Pint Dehumidifier
Feb 05, 2006 | DeLonghi DDE50E Dehumidifier
DeLonghi DE500 Dehumidifier Logo
143 people viewed this question
Top DeLonghi Dehumidifiers Experts
dennis lewis
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
