Question about Bushnell Deep Space 18-1560 (150 x 53mm) Telescope
Bushnell 18-1560 Telescope
Hi I received the above model as a gift. My problem is that I cannot focus on any object when using the 4mm eyepiece. I can focus 100% when using the 20mm eyepiece. What am i doing wrong or is my 4mm faulty. Regards Gary
    Problem Solver:
  • 11 Answers
What you have is called a refractor-type telescope with the primary lenses (the Objective) at the top of the tube and the only other lenses in the system are your selection of eyepieces, probably a barlow lens (2X magnification of any eyepiece used), and a diagonal (in line mirror so that you cand see into the telescope from the side.). As the focal lenth of the eyepiece decreases, so does the distance away from the Objective Lens. I believe that you are using the telescope with a diagonal mirror which makes the optical path longer. The fact that your longer focal lenght eyepiece can focus and not your short one would be only if you didn't have the diagonal or the eyepiece all the way in tight to allow the focus mechanism (rack and pinioin) to get compressed enough to focus. Look at the Moon, if the image gets smaller then bigger as you focus, but not sharp, then I would have to tell you that your eyepeice lenses are not in the right order. Someoner may have taken it apart and didn.t put them back in the correct order. The lenese could just be very dirty also. Barrow a short focal lenght eyepice from a friend and see if it works in your system. Then you will know for sure.
Posted on May 31, 2010
  • Bushnell Master
  • 19,396 Answers
Hi.
A refractor is a very simple telescope, with only two sets of lens (objective and eyepiece) and a small aperture.
Remove the prism (the diagonal adapter before eyepiece). Check status of the objective lens. Ensure that the lens is steadily incorporated into the objective.
Ensure the eyepiece is properly screwed to the telescope.
If all the rest is fine, and the 20mm is working, then replace the 4mm. If the objective or the eyepiece is not well in place, that may cause the telescope not focusing on the 4mm eyepiece.
Hi there koosie when using the 4mm eye piece you have to be looking at something at quite a distance hence the power with a 20mm eye piece you can focus closer objects and dont need so much light as the 4mm the more power the more light and furthur away the least power(20mm)the least light and closer you cant focus close with a 4mm eye piece but can with a 20mm
Posted on Jul 17, 2007
SOURCE:
Cant find this model 18-1750. need eyepieces
Eyepieces come in .965, 1.25 and 2 inch formats. Measure the diameter of the focal tube to determine if you have a .965 or a 1.25 inch focuser. If you have a .965 inch tube, you are very limited in choices. Antares sells very nice .965 plossls.
If you have a 1.25in. focuser, your choices abound. Suggest a 25mm plossl or 25mm MA eyepiece first. Max magnification with a 50mm objective is about 100x. to find the highest eyepiece you can use divide the focal length of the scope by 100.
Jan 04, 2013 | Bushnell Optics
I have the whole telescope assemble except I'm having trouble with the lense and eye piece. I have the 78-9970 refractor scope and I don't understand where to put the 4mm lense (and the other...
Put the diagonal into the rear focuser-- then put the eyepiece into the diagonal. DO NOT use the 2 x barlow if you have one. AND the 4mm may also be too much magnification for this size telescope.
So-- put the eyepiece with the largest number written on it into the diagonal and practice focusing on a distant object during the daytime. DO NOT POINT the scope at the sun! You will be instantly blinded!
Jul 01, 2011 | Bushnell Voyager 78-9970 Telescope
I bought a Prinz Astral telescope Model 100 at a boot sale. I don' t seem to be able to adjust the focus. Can you help ?
Never heard of this telescope. However take it outside during the day time and practice focusing on a distant object. Put the eyepiece with the largest number written on it into the focuser. DO NOT use the 2x barlow if you have one. Turn the focus knob left and or right until you get a sharp image in the eyepiece.
Apr 25, 2011 | Optics
I can find objects in the finderscope but when I look through the eyepiece of the main telescope it's all black. There is absolutely no light coming through the main eye. I have tried everything. I have...
Put the eyepiece with the largest number written on it into the focuser, do not use the 2xbarlow if you have one.
On a reflector the end with the focuser is the UP end the mirror is on the bottom. During the daytime point the scope at a distant object with the above eyepiece in place and practice focusing. Also line up the finderscope with the main telescope tube.
Jan 16, 2011 | Edu-Science (10166) Telescope
I am a beginning amateur astronomer and received a Meade Polaris 60EQ-D as a gift for my hobby. I can't see anything. I have ensured that all the caps are off. I can see distant objects through the...
Put the eyepiece with the LARGEST number written on it into the focuser. DO NOT USE the 2x barlow if you have one. Try focusing on a distant object during the daytime--- again.
Sep 06, 2010 | Meade Polaris 60EQ-D (36 x 60mm) Telescope
Will not focus, only light comes through, no image at all
All the manuals for Bushnell telescopes are located on this web site- look down the page for your model telescope:
http://www.opticsplanet.net/bushnell-warranty.html
Put the eyepiece with the LARGEST number written on it into the focuser, this is your lowest magnification.
Take the scope outside during the daytime and practice focusing on a distant object. Turn the focus knob slowly while keeping your eye on the eyepiece, watching closely for a focused image.
Read my TIPS on my profile page.
Aug 11, 2010 | Bushnell 570x60 Voyager Rotary Refractor...
Bushnell Telescope 78-4678
A telescope like that has a very narrow depth-of-field, so you need to focus very, very slowly to be able to see any image. Try focusing on something bigger (like a spot on the moon) and adjust the crosshair accordingly. The two eyepieces gives different magnification.
Jun 30, 2010 | Bushnell 675x5 EQ Reflector Telescope
Cannot focus model AP-78-9570 Bushnell Telescope
Is this your telescope?
http://www.binocularsdirect.com/Bushnell_Telescopes/dptsmzmyqcq.html
Can you try replacing the eyepieces on the side with the one on the back. Also if you "slightly" slide the eyepiece OUT does it come to focus?
I must tell you this is a very unusual design with a turrent AND another eyepiece on the back. Has the rotary eyepiece module become loose from the back of the tube? Can you push it in closer to the tube?
Other than forward or backward adjustment that's all the focuser will do.
Mar 01, 2010 | Bushnell Banner Dusk & Dawn 3.5-10x36 AO...
I have a TASCO telescope model 40-114675 incompletely assembled
Put the eyepiece with the largest number written on it into the focuser. I believe you have a REFLECTOR style telescope with a 3.5 inch mirror in the bottom.
Point the focuser end toward a distant object and practice focusing during the day time.
Later you can try the higher power eyepieces with the SMALLER numbers written on them. I belive one of the long pieces is a finder scope that mounts on top. AND the other is a 2x barlow which multiplies the eyepiece power by a factor of 2 times. Don't use the barlow. You will not need it.
The image will be upside down, which is normal for an astronomical telescope.
Mar 01, 2010 | Optics
Can't see anything through eyepiece.
The FOCUSER end should be pointed UP the mirror end is toward the ground. Turn the scope around and put the eyepiece with the largest number written on it into the telescope. DO NOT use the 2x barlow if you have one.
Go outside during the day time and practice focusing on a distant object.
Jan 22, 2010 | Bushnell Deep Space 78-9003 (525 x 76mm)...
Bushnell Deep Space 18-1560 (150 x 53mm) Telescope Logo
730 people viewed this question
Top Bushnell Optics Experts
Steve Allison
Steve Allison
Goldi Kunal
Damen Wong
Damen Wong
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
