Question about Hotpoint WMA64 Front Load Washer
Leaking machine hotpoint front load wma64 leaks from detergent tray
  • speedysnail Apr 02, 2012
    Mine leaks "foam" when its on a hot wash (more than 65 degrees C), but not on cooler washes. I think that on mine its the detergent. Hope this helps.
  • Hotpoint Master
  • 3,463 Answers
Could be caused by several reasons.
1- Overfilling, check water level .
2-Blockage in dispenser, or dispenser inlet hose to drum
3-Drawer not in properly.
4-M/c not draining properly, thus when it goes into spin, water could be thrown up by centrifugal force, and come out of the front of the drawer.Check filter.
5-Water pressure very high, forcing water out of drawer, adjust pressure.
Plz rate my soution.
Thanks.
Posted on Dec 30, 2008
Hotpoint WMF720 Aquarius+
Hotpoint WMF720 Aquarius washing machine is leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 28, 2012 | Hotpoint Washing Machines
After starting,water goes into the outlet pipe then immediatley leakes out directly under the oulet pipe at the bottom of machine.
The outlet pipe must be routed higher than the top of the washer or it will always drain. this is normal. The leak, however is not, something may be damaged, open and inspect.
Sep 26, 2010 | Hotpoint WMA64 Front Load Washer
I got an hotpoint wma64 front loading washing machine and my water intake has stopped working i am filling the machine with a hosepipe what can i do to fix the problem?
water goes through softner and powder draw hole gets gunged up stopping water supply take drawer out and clean then clean inside where draw fits black gunge blocks small hole where water comes through should do the trick
May 15, 2010 | Hotpoint WMA64 Front Load Washer
My washer is leaking from the detergent tray.
There is a hose to the tray so it can rinse the detergent inside the machine. The hose can leak, sometimes there is a seal on the tray that can leak also
May 04, 2010 | Kenmore 45981 Washer
Hotpoint WMA40 washing machine is leaking from detergent drawer- any suggestions ? Thanks
Hotpoint WMA40 washing machine is leaking This video will show you how to find that leak on any front loading washing machine
Nov 27, 2009 | Hotpoint WMA40 Front Load Washer
Water leaking through detergent tray of my Hotpoint WF860
It sounds like the washer is not draining properly.
Remove lower rear cover of washer, locate and remove the large black hose fastened to bottom of tub.
remove plastic filter inside hose, and clean same.
Refit filter and hose, making sure it is on properly.
Be careful when you remove the hose, as there will be water in there.
As an extra precaution, remove soap draw,and thoroughly clean all parts, particularly,the conditioner parts
Please rate my fixya solution.
Thanks.
Feb 01, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WMA76 Leaking door and soap tray
you may be using too much detergent, or you have a blockage in the outlet.try putting it on to spin to drain out the water, if it does not drain then check the filter or sump hose for a blockage
Jan 23, 2008 | Hotpoint WMA76 Front Load Washer
Hotpoint WMA64 Front Load Washer Logo
217 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
puggy666
Level 1 Expert
gbob59
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
