Question about Kenmore 82822 Electric Dryer
Kenmore Elite HE3 "PF" isue
Model number 11082826102, we got a PF code last night, reviewed the manual and checked the breaker, the plug, opened the door and tried to reset the maching. At that point, all of the lights on the panel went off. When we open the door the inside light comes on. Any ideas?
  • 1 more comment
  • rljennings Dec 31, 2008
    I replaced the thermal fuse last night and still no luck. I checked the breaker, the voltage at the plug, and at the terminals on the back of the dryer....all good.
    Question: It's a 4 -wire plug. I was getting 120 on the green and red wires (to ground) but not the white wire. Is that OK? Not an electrician. I know just enough to be dangerous.
    How do I get to the control panel? I started to pull the plastic cover off the front but wasn't sure what I was doing and didn't want to bust a clip. Suggestions?
    Thanks....I'll call a pro.
    President:
  • 948 Answers
A four wire plug should be three phase 220v, and normally would be wired green for ground, and red, black, and white would all have 110v when tested to ground. Since you indicate you are not an electrician I caution you NOT to open your electrical box or take chances with electricity. You can be seriously injured or killed.
However, in your circuit breaker box there should be a three pole breaker labeled for your dryer. It seems likely you have a broken white wire between the breaker box and the dryer. Why did this wire break? Did it overheat and melt? Did a squirrel chew through it? This needs to be investigated. Wires rarely break on their own, overheating indicates a failure in the system somewhere and the breaker should have tripped before the wire melted.
Posted on Dec 31, 2008
    President:
  • 2,110 Answers
The "PF" error code indicates a power failure to the dryer. To clear the error code, press Stop/Cancel.
If the Stop/Cancel button does not clear the problem you will need to replace the control board on the dryer. The part number for the control board is 3976611, in case you need it.
  • Sibananda Jena
    Sibananda Jena Dec 31, 2008
    He3 is not the real model number, it is a style. You can take your
    real model number which should be somewhere inside the door and go to
    Sears website
    http://www3.sears.com/intro.shtml
    and enter your model number. Then you can see diagrams of each
    section of the unit. It will allow you to see what comes apart and
    what does not. If you need further assistance, just reply. Thank
    you, Ann
  • Sibananda Jena
    1. Turn the dryer off but keep the electrical
    supply connected.
    2. Make sure that the dryer is empty and that
    the lint screen is clean.
    3. Close the dryer door.
    4. Select Heavy Duty, Timed Dry, More Time
    or Less Time, End of Cycle Signal (Louder)
    and Start.
    5. If error codes E1 or E2 flash on the display
    after 1 minute and the dryer turns off,
    the thermistor, or the wire harness, is either
    shorted or open. Check the wire connections
    at the thermistor or the machine
    control electronics board. If wiring checks
    okay, replace the thermistor.
    6. If the dryer seems to operate normally, remove
    the exhaust vent and start the dryer.
    7. Select the desired temperature cycle to be
    tested, and select 20 minutes of Timed Dry
    heat using the More Time or Less Time
    pushbuttons.
    8. Hold a glass bulb thermometer capable of
    reading from 32°C to 82°C (90° to 180°F)
    in the center of the exhaust outlet. Measure
    the exhaust temperatures with the
    heater on and off. The correct exhaust temperatures
    for the various settings are
    shown in the following chart.
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore elite he3 gives me the pf signal and turns off ? what may the issue be?
this is regeristering a power failure,you will need to check the main power supply.there is also a chance that the main control board may be faulty you will need to check all the wiring to the unit.
Feb 02, 2011 | Kenmore Elite HE3 Steam 8674 Dryer
We just replaced the power cord and outlet for a Kenmore Elite HE3 dryer and now it will not go on. I flipped the circuit breaker on and it said PF and now I get nothing.
PF error = Power Failure - error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Here is a site to double check the wiring:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Good Luck Tim
Nov 28, 2010 | Kenmore Elite HE4 Electric Dryer
How can I get an operators manual for a kenmore elite quietpak2 HE3 washer?
See the following Sears site for manuals:
http://www.managemylife.com/mmh/owner_manuals/search/product_type.Residential%20Washers?query=kenmore+elite+quietpak2+HE3
You'll have to determine the actual model number and then you can download a PDF version of the manuals.
Nov 18, 2010 | Kenmore Washing Machines
I have had a Kenmore Elite HE3 Electric Dryer for a number of years. As of today, it seems to have no power (it won't start/the panel has no illumination). The Dryer is plugged in. I checked the...
Paste this web address into your browser. This is Kenmore's website. There is an online manual that you can find if you know your model and serial# of this machine.
http://www.kenmore.com/shc/s/nb_10154_12604_NB_CCphoneoremail?adCell=W3
Oct 08, 2010 | Kenmore Dryers
I have a Kenmore Elite HE3 dryer model # 110.8483220. It has no power. We tested the plug and it tests for 110V of power, and the wire connection at the top of the dryer (on the outside) has power. But...
Your dryer is electric. This means it needs 2 electrical phases (hot wires) and one neutral to wor. If you measure 110v across 2 phases - one of them is out.
Unplug the dryer. Find the double breaker for your dryer on the breaker panel.
Pull breaker to the off position hard (do not overdo it,as you can pull the breaker out), and then back to on position.
Check voltage between the two phases, it should read 220-240v. Check the voltage between each phase and the neutral (middle prong), should read 110-120v. If you don't get these readings - call electrician.
If you get the proper voltage, plug the dryer back in. If it does not work - Dryer needs repair. Likely a thermal fuse is blown or problem with power wiring inside.
Oct 13, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore Elite HE3 Dryer PF on control panel,
HI, there may have been a slight power failure within the home breaker unit or the dryer may have lost power to the control for some sort of reason.
I recommend a thorough inspection of the terminal block on the back side of this unit. make sure the power cord is attached tightly and the wall outlet is secure and holding the power cord correctly. if everything looks great with the terminal block and the power cord is plugged in the outlet correctly, simply unplug this unit for 5 minutes to reset the control. after the 5 minutes are up, plug the unit in once more and the PF alert should reset.
Make sure the breaker box in your home is working properly. (the actual breaker switch for the dryer must be in the on position)
Apr 26, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer working but no heat
The manual says that two circuit breakers used,and that the dryer
can spin but no heat if one of them tripped, check your panel and see
if any breakers are tripped. If this was the problem,have an electrician
check the circuit.
Apr 09, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore 67082 "PF" power failure code
Check your circuit breaker. Reset it even if it doesn't look tripped. It is a dual switch and sometimes you can't tell if one of them is tripped. Then try it. When you reset the breakers leave them off for about 10 minutes before turning them back on.
Dec 24, 2007 | Kenmore 67082 Electric Dryer
Kenmore 82822 Electric Dryer Logo
188 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
