Question about HP Photosmart C3180 All-In-One InkJet Printer
HP Officejet 6310 cannot connect to computer
Computer recognizes and sends print jobs to printer. Printer cannot connect to computer but runs fine otherwise.
uninstalled and reinstalled printer software.
unplugged and reseated ethernet cable-no apparent damage
deleted and re-added LPT1 port
HP tech support confirmed printer is functioning properly
Printer still has no connection.
Any ideas?
Thanks
iqbal_del
  • 655 Answers
SOURCE: USB port problems with hp printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Posted on Apr 15, 2008
  • 287 Answers
SOURCE: 6310 Officejet all in one
Are you running AVG 8 free anti Virus? Did you install it recently? There are some reports that AVG 8 free version has some issues causing this to happen with VISTA. If so try printing with AVG turned off (Careful where you go on the internet while it is off - suggest a trusted site like microsoft)
Then try with AVG running and disable IE7 protected mode,
Click Tools, then click Internet Options.
  1. Click the Security tab.
  2. To disable Protected Mode uncheck the box next to Enable Protected Mode to disable it.
  3. Click OK.
Note: Enabling or disabling protected mode requires Internet Explorer to be restarted
If it is AVG causing the issue perhaps try and see if they have a later version available as it is not recommended to run with protected mode disabled
Posted on Jul 02, 2008
adonscott
  • 106 Answers
SOURCE: Cannot print with wirelessly networked printer
hi,
if printing from 2 other computer works fine, will i think its not an issue of IP address which changes somehow. but anyways, try to check if you still have other printer drivers under "PRINTERS" (see control panel). it should say HP Photosmart c6100 series. If you also have there a printer icon that says HP Photosmart c6100 series Copy1, try using it (right click on that icon and choose Set as Default Printer). If you only have HP Photosmart c6100 series under PRINTERS, try to right click, then choose properties. When Properties box is open, click on PORTS tab. then click on configure ports below. Try to type in the IP address of the printer under "Printer Name or Host name or IP address". make sure that you already printed network configuration page to get the exact ip address of the printer, Dont know how to print? do this.
PRINTING NETWORK CONFIGURATION PAGE
1. press setup, then scroll down and look for Network.
2. press okay on network, it will give you the first option "VIew network settings".
3. press okay on it, and it will give you the first option "Print network configuration page."
4. choose that and press okay. it will print the network config page. from this document, you will be able to see the IP address of the printer.
Please let me know if the issue is still not resolve so that i can go ahead and give you another possible solution.
Thank you so much.
adonscott
Posted on Jul 07, 2008
Bubbabear64
  • 2794 Answers
SOURCE: I have a hp Officejet 6310 AiO and a Mac. Problems with Scanning Image Properties
You can preview a scan and adjust to whatever size you need by moving the dotted lines around the scanned image. Once that is determined you can rescan the doucument with the revised settings.
Posted on Jul 31, 2008
  • 90 Answers
SOURCE: hp 1350v all-in-one printer won't print
if you have a print job stuck go in and hit cancel job. If it stays even after a few min right click "my computer" on your desktop and hit "manage" go to "services and applications" click "services" find the print spooler option and right click it and stop the service. Once stoped right click it again and start it. This should clear anything stuck in print queue trying to delete
Posted on Jun 22, 2009
My 6310 will not print from the computer
Might be printernUSB port faulty, remove USB cable from the printer end, un install the drivers from system, re connect the cable. If system found new hardware, run the drivers, if printer not recognized, definitely its printer mother board faulty...
Dec 22, 2011 | HP Officejet 6310 All-In-One InkJet...
Copies have black streaks. Printer is fine. Have cleaned rollers and separator pad (with damp cloth) in document feeder. This did not help.
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 26, 2010 | HP Officejet 6310 All-In-One InkJet...
HP6300 will not accept print jobs from HP computer it says no computer connection. Has prinyed in the past
hello
In this case please plug the printer into a different USB port and check for USB drive in device manager if it has red cross in it please enabel it or try to reinstall the HP prinetr driver.
Thanks
May 28, 2010 | HP OfficeJet 6310 All-in-One Printer...
I need to install my new HP Officejet 6310 and set it as the default printer . I don't have a Installation CD Rom
STEPS FOR INSTALLING THE HP OFFICEJET 6310 PRINTER WITHOUT CD-Rom
STEP 1: In your computer window click the Start button and select the option Devices and Printers.
STEP 2: A new menu Devices and Printers appear on the screen. Then click the option Add a printer.
STEP 3: After clicking the Add a Printer option two options appears on the screen.
Add a local printer
Add a network & wireless or Bluetooth printer.
Select the option that suits to your printer
STEP 4: If your printer is not a wireless then select the Add a local printer and select the option Use an existing port then click next.
STEP 5: Scroll down to select the HP in the manufacturer section.
STEP 6: Select your Hp printer model in the printer section then click next.
STEP 7: If your model number is not present then click the windows update it will automatically add your printer model.
Note: You must need internet connection to update the printer model to your computer.
STEP 8: Then click next and finish.
STEPS FOR INSTALLING THE HP OFFICEJET 6310 PRINTER FOR WIRELESS CONNECTION:
Add a local printer
STEP 4: Select the option Add a network, wireless or Bluetooth printer and click your printer name and address.
STEP 5: After the HP officejet 6310 printer installation of your wireless printer next step is to add your printer name and click next.
STEP 6: Set default printer as your HP Officejet 6310 printer and select the option print a test page.
STEP 7: A new popup window appears on the screen, then close it and finish.
Jun 11, 2009 | HP Officejet 6310 All-In-One InkJet...
Hp 6310 show offline wont print
Hi, how do you connect to the printer? USB/parallel/Network? Does it prints fine if you print an information page from the printer display/butons? I would try to uninstall the printer driver and install it again to start. It's definately a communication problem so it may take a few tries to get it to work again.
Jun 03, 2009 | HP Officejet 6310 All-In-One InkJet...
"NO SCAN OPTIONS" in HP Officejet 6310 all-in-one
You need to install the software and driver for the version of windows that is on the new computer.
Link to you model printer/scanner below:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1119598〈=en&
Mar 19, 2009 | HP OfficeJet 6310 All-in-One Printer...
HP Photosmart C3180 All-In-One InkJet Printer Logo
117 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
