Question about ASUS P5LD2-VM Motherboard
BIOS cannot detect SATA harddisk
My PC suddenly cannot detect my 2 SATA harddisk. It also not show up in BIOS. Test the two harddisk, both of them can be detected in another PC, Also the calbe and power cord are also work in other PC. NO idea why the SATA harddisk cannot be detected.
Try to update the BIOS to the newest version, however, it didn't work.
Please help
  • Anonymous Jan 22, 2009
    I have ASUS MBoard P5K PRO. After Windows crash and "hard" reset my bios refused to detect SATA HDD. However It still can detect another HDD which is IDE.
  • jason May 11, 2010
    have you tried clearing bios?
  • 42 Answers
Most motherboards have multiple plug-ins for Sata drives. Try another plug in. This will typically solve this type of issue.
Posted on Dec 30, 2008
Sir,i have install 3 sata hdd on my motherboard gigabyte 945 GCM-S2L 1. 160gb 2. 500gb 3. 1 tb. my pc many times hangs on bootup and freezes then i disconnect the cable to turn off. how to fix that...
Do extensive diagnostic tests:
1. Set BIOS to default settings and do not use overclock settings, check.
2. Memory test, download ISO image, burn it onto cd and boot from it.
If memory fails after several hours testing: Replace memory
3. Flash the latest (original)[beta] BIOS version.
4. Connect just one (1) harddisk and test for longer time. *
5. Add second harddisk and test for longer time. *
6. Add third harddisk and test for longer time. *
* If connecting or adding harddisk leads to freezes, exchange that harddisk and retest.
Sep 25, 2011 | Gigabyte GA-945GCM-s2C socket LGA775...
MSI RC410 - cannot detect Sata HDD
i think the problem is with ur SATA HDD. To confirm, try another SATA HDD on ur mother board and see if the problem persists
Sep 20, 2009 | ASUS P5RD1-VM Motherboard
Mother board cant detect my Sata HDD, please advise me urgenly...
I will advice you to exchange the HDD with someone or with brand new one as it seems to be problem with drivers of the sata.
Sep 20, 2009 | MSI RC410M-L Motherboard
Es2 300x not boot up
Open your cpu cabinet.
Refix your RAM clean all dust from circuit bord.
Reconnect power cable and ide or sata cable to harddisk.
Reconnect processor fan and processor.
Reconnect power supply from psu to motherbord.
Pull your cmos cell from motherbord for 15 minutes from motherbord so all settings are reset to defaults.
Check in bios your harddisk is detected?
For boot your computer with operating system your harddisk must detect in bios.
Aug 15, 2009 | Computers & Internet
System can't fully boot, cannot communicate with internal hdd. have used restore disk to get back to dos prompt
Your harddisk is not detected proeprly in bios .
For that when you power up the computer press F1 or F2 or "del" key to enter in bios .
Then check your sata option is disabled in bios .
Then save settings then your harddisk is detected properly.
Aug 03, 2009 | Dell Latitude D800 Notebook
Compaq deskpro 2000 error code 1780 disk 0 failure,how do I fix it?
first open cpu cover and reconnect both connection to hardisk. Like sata or ide and power cable.
Then check in bios .
When you power up the computer pressF2 or "del" or F5 to enter in bios setup then load optimal defaults.check your harddisk is proeprly detected in bios.
also if youi have sata harddisk then enable sata option in advanced .
then save settings and exit.
Thanks for using fixya.
Please rate solution if it helps.
Jul 23, 2009 | Computers & Internet
Unable to detect 250GB Seagate hard disk on P4 PC
you need bios update
download bios express installation file
install first any 40 or 80 gb ide harddisk install windows and run express installation file
your motherboard will update your bios
download from http://www.updrivers.com/search/d845glly
or
http://www.updrivers.com/getdriver/Motherboard/Intel/D845GLLY-BIOS/10018.html
Oct 17, 2008 | Intel D845GLLY Motherboard
My dvd rw is not detected
Sounds like you need your manufacturer's SATA drivers.
This problem exists a lot when installing Windows from scratch on SATA hard disks. When you start the installation, Windows prompts you to "load additional drivers". It's at this point you put a floppy disk with the SATA drivers in.
If your install is already working, but just stopped as you say... then you could hunt around the BIOS for a SATA "compatibility" mode, which will get you booting straight away. Install the SATA drivers and you can then put the drive back into normal operation instead of compatibility mode.
This is also the reason why your other hard disk with Windows can see the SATA disk and optical drive... it probably has the SATA drivers installed.
Aug 20, 2008 | Microsoft Windows XP Professional With...
HELP ABOUT K8C-X motherboard
Hi thun, Unplug the power cable from the PC.
Please reset the bios. This is shown in you're user manual on page 1-17. (If you no longer have you're user manual for the Asus K8V-MX MB you can download it from Asus by clicking on this link):
http://support.asus.com/download/download.aspx?modelname=K8V-MX&SLanguage=en-us
Remove the SATA data cable & clean both ends of the cable with a few drops of alcohol on to a cotton swab. Than clean both SATA ports on the motherboard using the same method.
Also clean the SATA power connectors in the same fashion. (Allow time for the alcohol to dry).
You can help it dry using some canned air.
Re-connect the SATA data cable & SATA power cable to the SATA drive. (Check all other connections within the PC for good connections before closing case). (SATA data & power connectors are easily knocked loose, so be careful).
Plug the power cord back into the PC & boot the PC. Enter you're bios. Check the main menu & make sure the bios has listed the SATA drive. Than go to Boot menu. Page 2-27, 2-28 in the manual. Make sure you see the SATA drive listed here. If you are sure the SATA drive was listed in the main menu than it must also be listed in the Boot menu.
If it is not listed in the Boot menu than there is a problem with you're bios. You're board is warranted for three years from manufactures date. Please call Asus tech at 1-812-282-2787.
M-F 9:00AM to 5:00PM EST. You will need the serial number printed on a white label located on the pink LPT port. You can see this only from within the PC. Asus will ask for that S/N to determine if you're board is still within warranty. If it is, make sure you get a case number & instruction before ending the call.
Good Luck!
Mike
Jun 06, 2008 | ASUS K8V-MX Motherboard
ASUS P5LD2-VM Motherboard Logo
1,830 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
