Question about Oregon Scientific Lwb0997110113004 Thermometer, Tht312/Blrw Clock Radio
Wireless thermo clock not reading outside temp
I have an Oregon Scientific Model # RAR601 Wireless Thermo Clock
The clock is not reading the outside temp. from the remote sensor.
I have changed batteries in the remote sensor.
  • Anonymous May 26, 2009
    I have the exact same issue. The outer sensor does not register on the control module.
  • Helper Man Aug 15, 2013
    Change the channel the outer sensor is operationg on and hit reset.
I've had a similar problem with another model, an Oregon Scientific Model IWA-80055 Wireless Thermo Clock, in which when I replaced the batteries in the remote sensor, the clock would not read the temperature from the remote sensor.
I found it fairly consistent to solve this by taking a battery out of place in the clock and putting it back in.  Unfortunately this also messed up the clock's time and date.  This is also in the instructions catalogue for the device, check and see if yours gives a similar solution.
Posted on Apr 13, 2009
I replaced the batteries in the outdoor sensor and put them in and out several times (didn't work). But now I realize that the solution suggested by Lamp post is to take out a battery in the RECEIVING unit and put it right back in. Worked like a charm.
Posted on Dec 11, 2009
    New Friend:
1. Take the cover off the back of the remote sensor.
2. Set the chanel to ch.1. (I tried all three but only ch.1 worked for me).
3. Use a stick, needle, or whatever you can but you need two) and hold down the reset button on both the sensor and the clock at the same time.
If done right, it should only take a few seconds to start.
The outside temp is delayed at first. Be patient.
Posted on Dec 05, 2013
  • James Hatch Jr.
    James Hatch Jr. Nov 16, 2015
    Channel 3 worked for me on the sending unit . I took one battery out of the receiver ,then put it back in - it took a minute .Now the outside temperature works like a charm with special thanks ! to Lamp Post ,and Cat's Meow for both of their comments about this model - Wireless Thermometer.
    New Friend:
Inserted paperclip into the reset slots of the remote sensor then base station. Pen or pencil is insufficient.
Posted on Dec 06, 2012
Eddie Bauer Thermo Clock 0465 - I replaced batteries in both the sensor as well as the sensing unit, and couldn't get the outside temp to read. I then slid the 'CH' (channel) button from far left position to the far right (3), and then back to the far left position, and everything started working. I had to reset the time and date (triggered by holding in the 'Mode' button and toggling to the appropriate area, reset using the 'ADJ' button. Works like a charm now.
Posted on Feb 20, 2012
SOURCE:
Need a out side temp sensor for a sharp wireless thermo clock it is a sharp SPC 373
DO YOU HAVE A MANUEL ,,OR GOOGLE THE MODEL AND MAKE AND CONTACT SHARP CUSTOMER SERVICE IF IS ISN'T TO OLD THEY'LL PROBABLY SEND YOU ONE OR TELL YOU WHERE TO GET IT!!
Jan 21, 2016 | Sharp Atomic Wall Clock, Silver/Titanium...
MODEL WMR80 / WMR80A
3. Use a stick, needle, what ever you can (but you need two) and hold down the reset button on both the sensor and the clock at the same time.)
Oct 09, 2013 | Oregon Scientific Lwb0997110113004...
My oregon scientific indoor outdoor weather station with atomic clock just stopped picking up the outdoor readings, it won't switch to that channel any longer. tried removing and reinstalling the battery,...
I had the same problem, Since the outside temp wouldn't read, I figured it was the outside unit batteries. Went through half a dozen AAA batteries and wouldn't read. It was the indoor unit. Had the same bats I installed 3 years ago. DUH! Replaced the AAA, and all was well. When the inside batteries die out, it has just enough juice to read indoor temp, but not enought to sense exterior signal.
Oct 20, 2010 | Oregon Scientific Wireless IndoorOutdoor...
Oregon scientific IWA 80055 Outside temp won't display and I have replaced the batteries on the sending unit and it blinks two times every few seconds.
I have the same unit (IWA-80055) and after not finding anything helpful on the net, I just messed with it until I got it fixed. Here's what to do:
3. Use several tools. (i.e. a stick, needle, what ever you can but you need two) and hold down the reset button on both the sensor and the clock. (at the same time.)
Jan 31, 2010 | Oregon Scientific Lwb0997110113004...
Oregon scientific thermometer model tht312
Actually I just kept working with it, but I did put a new battery in and that may have helped. It is working fine now, thanks for your response.
Jun 03, 2009 | Oregon Scientific Lwb0997110113004...
I have two Oregon Scientific systems. they are interfering.
Two things...
1) press reset on the base unit
2) press and hold for 2-3 seconds the channel button
You should be in business
Apr 11, 2009 | Oregon Scientific Lwb0997110113004...
I changed the batteries in my atomic wireless thermo clock and now it wont give me out temp
The easiest way to fix this is to either take the battery out of the clock, which will reset the clock, or use a paper clip to press the reset button on the back of the clock.
Mar 10, 2009 | Zapf Chou Chou 716212
Oregon Scientific Radio controlled Thermo Clock RMR382A -
Check the channel mode that you are in. I play with the channel /memory buttons on mine and I finally get it to work. Sometimes it worksfor weeks sometimes just a day. Just glad I can get it to work - thought it was the remote unit but I was wrong.
Sep 03, 2017 | Oregon Scientific RMR-182A Clock Radio
Resetting the atomic clock to the correct time zone, and outside temp to work.
For the Sharp SPC374T Atomic Clock - Time Zone setting- Press the 'Time' button once, the time zone will show where 'Day' usually is, use the Up or Down buttong to adjust.
For the outdoor Thermo, credit to my neighbor for this one. Remove battery from main unit, wait 2-3 minutes. Reload batteries. Once you get a reading from the outdoor sensor, hit the reset on the main unit. You will have to reset the time zone as described above, but this worked for me after 10 months of no outside temp showing up!
Good luck,
Doc
Dec 01, 2007 | Baby Gear
Oregon Scientific Lwb0997110113004 Thermometer, Tht312/Blrw Clock Radio Logo
12,368 people viewed this question
Top Oregon Scientific Audio Players & Recorders Experts
Gyula Lacz
Tom Chichester
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
