Question about Toshiba e-Studio 350 Copier
Toshiba E350 My Estudio 350 will not allow printing to it from the network. It will send out scanned documents, etc. but will not receive the print que. Does the firewall have to be configured differently? The copier has been assigned a static IP address so all people in the company can install the software on it and then print from their desktop computers to the printer however, this function is not currently working.
  • Anonymous Apr 05, 2009
    same problem. the print log on e350 will show the job but won't print.
Do you have the print option ? If not, you can configure everything, print jobs will show up on the cue, but they will just disappear into space. The print option looks like a USB key attached near where the network attaches to the copier.
Posted on Dec 12, 2007
    Problem Solver:
  • 18 Answers
Go to control panel, then select printers, select add a printer. When it ask you to install choose tcpip port and configure the port for the ip addres you gave the printer. Make sure you have the PCL driver for the unit and load when asked. This will ensure your on the network properly. Also try typing into explorer address bar the ip address only (i:e: 192.168.1.108 )only and see if the printer comes up on your explorer. If you can see the printer from explorer you should be able to configure it on the network using TCPIP.
Posted on Aug 15, 2007
Toshiba estudio 255 Cannot usefunctions
you must connect the machine with you're computer.you want the fax you must check the you're photocopy machine have a fax board.you want the scan & printing connect the photocopy machine to the computer.(network cable)
Jan 27, 2014 | Toshiba estudio 255 Copier
When i scan a document it won't email it
Usually this is not a problem with the copier, but mostly its network related. First switch off the device and remove the power from the socket for 10-20 seconds and than switch it on again. If still doesn't send after 3-5 minutes make sure that all necessary settings are correct (SMTP address, etc...) Most of the device needs more than a minute to fully initialize the network interface after turning on the unit's power, so always wait a few minutes before you scan or print. If you recently changed your Internet Service Provider it is possible that you need use a different SMTP address.
Sep 05, 2013 | Toshiba 2830c,estudio,color...
Scanner problem - Panasonic DP-8020E
try uninstalling printer driver then reinstalling it if this doesn't work then contact adobe support see if they have a patch for this problem
Jul 30, 2010 | Panasonic Office Equipment & Supplies
Scan feature greyed out on Toshiba eStudio 232
You have to have the USB stick to enable the scan.
It locates on the right side near the back of the machine.
They make , print dongles, Scan dongles and print scan dongles. But that USB device enables scan.
May 04, 2009 | Toshiba e-Studio 232 Black and White...
Printer not printing documents in que
my printer hp psc1315xi all in one printer copier, scanner will not print any documents, not even a test print, there is also a doucument in it that am not able to delet from the printer
Jan 22, 2009 | HP PSC 1315 All-In-One InkJet Printer
Toshiba e-Studio 350 Copier Logo
1,013 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Timothy Van Der...
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
