Question about Samsung UpStage SPH-m620 Cellular Phone
Sgh-m620 cannot read micro sd
When micro sd card is inserted into the sgh-m620, the phone would not come up nor read the card. kindly, help i just bought this phone....
  • chulo954 Jan 14, 2009
    my sgh-m620 will not read my micro sd card
  • Anonymous Mar 29, 2014
    where does the SD Card go in my Samsung TracFone SGH-T301G phone?
I just had the same problem and I found out that the phone can only handle 2gb and below. I had a 4gb card and the phone would not read it but once i switched it to a 1 gb it came right up.
Posted on Jan 14, 2009
Micro SD Slot in My LG Rumor 2 isn't reading Micro SD Card
hello,kindly check if it is inserted properly,you will see a directive arrow on the memory card to show you how it is to be inserted,if after you have inserted it correctly and it still does not sees it,i would suggest you suspect your memory card is corrupt if their is any message displaying on your mobile phone screen,and if it does not show any message like memory card corrupted,then you will have to visit a mobile phone repair expert to help you change the memory card slot,after this your mobile phone will now read your memory card.
kindly rate this solution if it's helpful,
take care.
Apr 16, 2010 | LG RUMOR Cellular Phone
Want to upload pics to my sgh 251 from my micro sd card. how do i do it?
there are two ways...you can connect your mobile to PC using a data cable copy the pics into ur mobile or remove the SD card using a SD card connector copy all the pics into ur SD card....n again insert it back to the mobile....u can find all ur pics in memory card...hope this helps....
Mar 05, 2010 | Samsung SGH-E251 Mobile Phone - Black
Unable to reformat memory card cause computer can't find it
try using a q-tip and some rubbing alcohol to clean the 'fingers' on the sd card (both sides). let it dry. re-insert card and try again!
good luck!
Sep 29, 2009 | Samsung UpStage SPH-m620 Cellular Phone
SD Micro card- Formatting
your micro SD card may be damaged in some small way, or the card reader is a defect in it, to see which one it is,
****TRY TO BUY ANOTHER SD card, your phone can support up to a 2 GB micro SD card, if it persists, then *********** board in the phone has a defect.
Apr 16, 2009 | Samsung SGH-A707 Cellular Phone
LG KC550 PC Suite Problem
I speant Hours swearing at my phone because it would not read my music files, Tried the card on many different phones which would take Micro SD and all other phones read the music Just not the LG KC550.
I found that getting a Micro SD dongle reader, Insterting your 2GB Micro sd card in that and then putting your music files into the "sounds" folder works.
Instructions.
1. Insert Micro SD card into Card reader.
2. Insert card Reader to Computer Via USB.
3. Go to my computer and Open the USB Card reader.
4. Select the Music files from your pc Via Copy files
5. Go to open Tab (Where you can see your Micro Sd card) Open the sounds folder and Paste.
If you are finding it hard to get the 5 folders of images, Documents, Sounds, others and Videos on your Micro SD card. Format the card by going My computer, Right click the Card reader (with you Micro sd card inserted) and click format. Takes a few seconds. Insert the card into the phone, the phone will auto put the folders on the card. Then go to step 1 (above) and start again.
Hope this Helps guys.
Apr 04, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Micro SD NOT WORKING (SONY ERICSSON W580i)
You need to buy a different kind. i just bought a 4G Microcenter brand and its doing the same thing.
i'd recommend a Sandisk M-2 microSD.
Apr 12, 2008 | Sony Ericsson W850i Cellular Phone
Need to reformat micro-sd card in up stage phone
to reformat micro sd card in your phone
go to menu>my stuff>select removable disc or memeory card then select options>format
>>or you can reformat the micro sd card using your pc
>>connect the sd card to the memeory card reader then connect it to the memory card adapter
>>go to my computer then select removable disc then right click then select format
Feb 28, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Micro sd card not reading songs
Yes, Brother there is one probability that your sd is formatted in fat-32 file system. For that i would like to say phone can only read FAT not FAT-32. Go to my computer, select sd drive properties and format it with FAT file system. Then load the files and you will be able to see it in your phone. If it works don't forget to vote here. For any proble contact me patel352003@gmail.com or patel352003@yahoo.co.in
Jan 07, 2008 | Samsung UpStage SPH-m620 Cellular Phone
My New Micro SD Memory Chip
i need help. i insert my lexar 1gb micro sd memory card into my phone and my phone doesnt show that there is a memory card inserted and i have no idea how to work it on my phone. my phone is a samsung blast.
Jul 31, 2007 | Samsung SGH-D900 Cellular Phone
Samsung UpStage SPH-m620 Cellular Phone Logo
429 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
