Question about Kyocera KM-1505 Copier
Kyocera KM-1510 Can't make any copies - error code J98 appears. Any solutions?
  • Valentin Georgiev May 11, 2010
    are you sure that J98 is lignthing? Because trouble codes are AXXX and CXXX?
    Problem Solver:
  • 7 Answers
BD steady-state problem • BD steady-state problem is detected. (jam code 98)
BD steady-state problem • The VTC detects a BD error for 800 ms after the polygon motor rotation has been stabilizad.
Poor contact of the connector terminals. Defective LSU. Defective main PCB.
Check the connection of connector CN18 on the main PCB and the continuity across the connector terminals. Remedy or replace if necessary. Replace the LSU. Replace the main PCB and check for correct operation.
Posted on Dec 31, 2008
How do i fix J98 error in Kyocera KM-1505 copier
This is from the users manual:
"Open the drawer and left cover and check for any misfed paper. If the same indication appears, contact your service representative."
Jan 16, 2015 | Kyocera Office Equipment & Supplies
What happen when kyocera KM-1505 is bringing error code J98
There's probably a time piece of paper or something blocking a sensor or pressing down on an actuator or something
try checking this then do a good clean of the unit.
Jan 16, 2015 | Kyocera Mita Km 1810 1510 1505 Copier Drum...
Just hold down the stop/clear button for 3 seconds..
It will flash F24 then 3 increments then 3 more.. eg; F24>063>123
It means you have done 063123 copies/prints..
Sep 18, 2009 | Kyocera KM-1510 Copier
Kyocera KM-1510 when i turn it on the code C-620 appears and will not function,how can i fix it?
Hello sir; You need to do a reset procedure;
press these keys in order and keep hold them down, "stop/reset" "start" "left copy density", press "stop/reset"key again, then enter U163 press "start" twice to clear.
Sep 17, 2009 | Kyocera KM-1510 Copier
Kyocera KM-1510 error c610
Broken fixing heater wire
Jul 10, 2009 | Kyocera KM-1510 Copier
I need to know what error code A400 means?
a400 is a trouble code for Laser Scanning Unit problem.
Jun 24, 2009 | Kyocera KM-1510 Copier
Error code C0F37 on Kyocera mita KM-C1530
This code is not documented, the firmware must be reloaded and a service tech can only do it ...
Feb 18, 2009 | Kyocera KM-1510 Copier
Please Help Kyocera KM-1510 Grayscale Copier & Minolta D251 C0F32
check the exp.lamp . it mzay be blinking at the time of scanning the original.
Feb 17, 2009 | Kyocera KM-1510 Copier
this is a fuser error meaning that the fuser has overheated. In most cases the thermal fuse or thermostat blows and will need replacing. especially if you get the 630 code, and switch the machine of and back on and get a 610 code.
Oct 13, 2008 | Kyocera KM-1510 Copier
Km-1510 .. AP error code
AP = Adding Powder (toner) it's not an error
it's adding toner from the container into the developer unit while displaying AP. when there is enough toner in the container the AP will disappear and copies can be made when there is not enough toner in the container the toner empty light will come on.
Oct 22, 2007 | Kyocera KM-1510 Copier
Kyocera KM-1505 Copier Logo
267 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
