Question about Zanussi FLA1001W Front Load Washer
Zanussi FLA1001 My machine will wash and drain, but will not spin. Any suggestions as to what this could be and how to remedy the problem. Thank You
  • Lesley Bishop May 03, 2007
    Hello - it will not turn at all now. It will fill and will drain. We have taken the top off the machine (cannot accessthe back of the machine as the back cover will not come off). Cannot see where the belt is. Any comments. Thank You
Sounds like the belts come off - or motor brushes.
To get the back off: -
take top off; release 4 off (2 each side) self tapping bolts from top plate by the springs; remove plastice plugs at bottom sides and remove self tapping bolts (1 each side); remove 2 off bolts from back (at bottom); remove plastic housing holding pipework and cable from top; now work loose the back (it will be bonded up the sides so you'll have to be forceful). When the back is off you will see the belt. If belt is still on wheel and motor then check motor bushes. If belt has come off then check if your wheel is aligned with motor rotor - as mine isn't. I wounder if this misalignment is by design.
Posted on Apr 03, 2008
    President:
  • 1,294 Answers
If the washer seems to complete all of its cycles, but it doesn't spin: 1) Be sure the load of clothes is not lop-sided, and dont overload. If the tub becomes unbalanced, it may spin erratically or not at all. Sometimes you can just open the lid and reposition the clothes. This automatically resets an off-balance shut-off switch. Just close the lid and re-try. 2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during the spin cycle. If the switch doesn't click when you press and release it, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) The belt may be loose, worn, or broken. If you're fairly handy, tighten or replace the belt, otherwise call an appliance repairperson, there may be a problem with the controls.
Posted on May 02, 2007
  • prem mathew May 03, 2007
    There are screws at the back to unscrew...well, take a nice look. Your model is belt driven & for access it is only thru the rear........
Zanussi washer dryer showing e20 error message in dryig cycle
Hi
This means that the filter is clogged. Unscrew the filter it'll be full of lint. E20 also means drain problem. If it actually goes through the Spin cycle then there is most likely some water still not drained out at the time of the tumble dry. Check the drain and the hose to make sure it isn't clogged.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jan 03, 2011 | Zanussi Washing Machines
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
My zanussi 1600 aquacycle will was but not drain
it sounds like have a bad water pump
Feb 24, 2010 | Washing Machines
Zanussi washer machine zwf1621s does a washeing
3 things you need to check : DRAIN MOTOR PUMP ,
LID SAFETY SWITCH & THE MAIN TIMER , hope it helps , AJ
Dec 27, 2009 | Washing Machines
Zanussi washing machine, conditioner doesn't empty
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2009 | Zanussi ZWF1430W Front Load Washer
My washing machine will not spin( zanussi wda1055w)
heatman101
Jan 19, 2009 | Zanussi WDA1055W Front Load Washer / Dryer
Zanussi zwf 1020w drum not revolving
The drum will not rotate until the draining process is satisfied, there is either something in the pump or pump is broken
Oct 20, 2008 | Zanussi FJD1666W Front Load Washer
Zanussi FC1200W
have you checked the filter behind the flap on the front of the machine, this could be blocked. if the machine is full of water though you will have to manually drain it by putting the grey outlet hose into a bucket or a washing up bowl. you will also need one or two towels to place on the floor because there wil still be a bit of water left in the ipes even though the drum is empty.
hope this helps
Jul 28, 2008 | Zanussi FC1200W Front Load Washer
Filter can be clogged, pump can be dead or water outlet clogged.
Apr 11, 2008 | Zanussi ZWF1430W Front Load Washer
At bottom left of machine there is a small metal flap where you can drain off water. Next to that is a grey pipe you can keep pulling and pushing i have done this quite a few time and it has let out sludgey stuff put washing machine is now spinning and draining. Good Luck.
Aug 29, 2007 | Zanussi ZWF1420W Front Load Washer
Zanussi FLA1001W Front Load Washer Logo
121 people viewed this question
Top Zanussi Washing Machines Experts
shaun taylor
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
