Question about Behringer ULTRA-Q PRO PEQ2200 5-Band Car Equalizer
How do I connect a berhringer equalizer to amp and mixer
I have a pro equalizer, pro Amp and a pro Mixer I I want to connet all and set the equalizer
SOURCE: hook EQ to my mixer
I assume you want to put the EQ on the mains output of the mixer -- is that correct?
Just run the left/right out from the mixer to the left/right in on the EQ, then run the left/right out on the EQ to your amp.
Posted on May 27, 2009
VOTIT
  • 2071 Answers
SOURCE: power supply problem in Behringer pmp 3000 mixer
Just try to resolder all component parts in power supply section,maybe there is a loose connection or cold solder joints that causing of abnormal voltage or missing voltage.Also check the resistor for cange value causing the voltage trap.Check also all electrolytic capacitor for leak. Hope it may help you;;
Posted on Jun 08, 2009
SOURCE: i have a xenyx 2442fx
You would need a 2 or 3 way crossover, depending on whether or not you biamp your tops. Simply go out of your main outs on the mixer into the input of the crossover. Go from the low output of your crossover to your low power amp input (subs), and the high output of the crossover to the high power amp input (tops). Then go from your outputs of your amps into the speakers themselves.
Posted on Oct 23, 2009
technical114
  • 1851 Answers
SOURCE: whow i connect my xenyx 1002 mixer to audiophil 2496 sound card
You must connect:
the main out of the 1002, or the ctrl room out of the 1002 at your power amplifier's input.
the line in 9/10 of the 1002 at your 2496's line out.
the cd/tape out of the 1002 at your 2496's line in.
in case of a cd connect it's line out at line in 3/4, or line in 7/8 of 1002
some mic at the mic 1 or mic 2 of 1002.
That's the way you're going to have control for:
the mic level from channel 1 or 2.
cd level from channel 3/4 or 7/8.
pc playback from channel 9/10.
master speakers from main mix or ctrl room.
All the above connections are not absolute and may vary depending on your needs.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Posted on Feb 24, 2010
  • 5603 Answers
SOURCE: set up my two 15"mains/ and one 18"sub.
This unit will put out around 400 Watts a side. PLENTY !
If you want a sub, either get a powered one or an amp for it and run off the MON output.
CAUTION: NEVER permit the speaker cable to be removed or interrupted whilc power is on... you will arc out the rear most amp in the unit... I know... I fix them... There si a bit of weak insulation that can arc through on a circuit board.
If you ever have a fuse blow, DO NOT replace it, you will do further damage inside the unit... take it for service.
Posted on Apr 13, 2010
I no nothing about hooking these things up my mixer is un powered mixer so i bought a 1200 watt amp to power it mixer yamaha
Humm??? a mixer in a car ?? what a concept !! could bring an entire new dimension to "air guitar on the freeway " but might you mean an equalizer ??? if so its easy to connect a equalizer before the amp as it comes from car stereo , the round "rca" jacks are the best way to do it if you have the means !! then its a simple wire out to each speaker and whoola !! you got sound !!
Nov 22, 2016 | Car Audio & Video
How to hook up a mixer, pre amp, power amp, crossover and equalizer
let see you want me to teach you what it took me 20 years to learn in a few moments...really
Mar 06, 2014 | Behringer Ultragraph Pro Fbq1502 Feedback...
Shud i get an external equaliser? i'm using MG166CX 16-Channel Mixer as the main mixer.
An external equalizer will not help this at all. The problem is likely within the amp (feeding the main speakers), the connections from the board to the amp, or the speakers themselves. In other words, the answer would be "NO." Best of luck!
Jan 14, 2013 | Music
Having problems connecting speakers via a power amp in to my behringer x2222 usb mixing desk - im not getting the ins and outs correct :(
I had a like problem with a crown amp. I found it was in the amp settings , nothing to do with the mixer set up. We had it a mono setting. Take a look at your amp set up book, i'll almost bet thats where the problem is
Dec 06, 2012 | Behringer Xenyx X2222USB USB Audio Mixer
Power mixer to a power amp.
You have two aux sends on that mixer so quite easy to use one of those to feed the external power amp. You could have one set of spkrs connected to that amp and another connected to the powered mixer. This would give you full independent control over each set.
Aug 09, 2012 | Samson Xm910 8Channel Powered Mixer...
How to run receiver+mixer+pre-equalizer-mixer+equalizer+receiver in loop
solution 1
repost this to right forum for other experts to solve
Jun 02, 2012 | Sony PC Notebook
I have a ep4000 amplifier, how can i connect to a mixer
The rule of thumb is you control your audio on the low side. That means you plug your mics, tuners, audio sources into the pre-amp and then the pre-amp into the equalizer/mixer ant finally the mixer into the power amp and the amp into the "large honkin' speakers". The inter connects on the low side (between the source, the mixer and the power amp are usually done with RCA plugs. Use a good quality set of cables to get good tight connections and solid grounding.
AUDIO SOURCE?MIXER?POWER AMP---
heavy speaker wire sized to your SPEAKERS.
Sep 29, 2011 | Behringer EuroPower EP4000 2Channel...
Mixer and an EQ & amp ?
The order is mixer, equalizer and amp. The output of the mixer connects to the input of the equalizer and the output of the equalizer connects to the input of the amp. The equalizer has three types of input and output connections. They are XLR, 1/4 inch and screw terminals. The mixer will have one or two of the three. Choose XLR if possible on the mixer, choose line level output on the mixer if possible. A XLR male to female cable is needed for the connection. The equalizer has two channels, if the mixer has two output channels the two output channels of the mixer can connect directly to the two input channels of the equalizer. If the amp has two input channels, the two output channels of the equalizer can connect directly to the two input channels of the amp. If the mixer only has one output channel then only one channel of the equalizer can be used and one channel of the amp likewise. A XLR male to female connection cable can be used to connect the equalizer to the amp.
Jun 23, 2010 | DBX 1215V Home Equalizer
Hook EQ to my mixer
May 27, 2009 | Behringer ULTRAGRAPH PRO FBQ3102 Turntable
Dont know how to connect everything so it all works
you need a small mixer from radio shack near you.
1-connect cd player to channel 1 in mixer.
2-connect tape to channel 2 in mixer.
3-connect mixer out to equalizer in.
4-connect equalizer out to amp in.
Nov 09, 2008 | Audio Players & Recorders
Behringer ULTRA-Q PRO PEQ2200 5-Band Car Equalizer Logo
133 people viewed this question
Top Behringer Car Audio & Video Experts
xxxxxx xxx
Are you a Behringer Car Audio and Video Expert? Answer questions, earn points and help others
