Dsl not working
I have done everything that I know of but I can't get the internet to return. I removed the Linksis router, I have flushed the Ip address, I have changed network cables. The only weird thing is that the jack has been ripped open and the inside wiring looks weird. Does anyone have any suggestions
    Genius:
  • 1,605 Answers
If the jack looks weird, then you need some with the tool to punch down the jack.
and get a good cable between the modem and the jack.
Posted on Dec 30, 2008
Speedstream 4100 cant connect
plug the computer into the modem testing dhcp
if it gets internet the modem is the dhcp server
the plug into router by itself disconnected it from modem testing dhcp if gets ip address and no internet it's the dhcp server
dhcp can be done by the modem or router. I bridged mode the modem and let the router do dhcp. of course the router must be pppoe for dsl. been years since I had DSL, hope it helps
Jul 07, 2017 | Siemens SpeedStream Modem (4100) (SS4100)
Running two xbox live 360
Hello there.
A router shares your internet connection with local computers and devices on your local area network. Microsoft's xbox live requires a connection to your IP address on a certain port. This will be a problem when using 2 xboxes so what you would need to do is contact your Internet Service Provider, explain that you are using a router and require an additional Static IP Address.
Once they provide you the details for this, you can manually set up one of the xboxes with the static details your isp has given you.
This should stop the 2 xbox conflicting over connecting to the internet, as they will be running on seperate ip addresses.
Hope this helps.
May 19, 2008 | Microsoft Xbox 360 Console
How to configure a router
  1. Login to the router page but typing http://192.168.2.1 on IE
  2. Check if you have a WAN IP or Internet IP
  3. If it is 0.0.0.0 then there is a problem
  4. If your internet provided is Cable you may have to do MAC clone
  5. If your internet provided is DSL you have to configure the router in PPPoE mode
  6. You will get WAN IP and will be able to go online
  7. Change the SSID which is nothing but the wireless network name
  8. Change the security to WPA or WPA2 and setup a security key
Aug 17, 2010 | Belkin (F5D7230-4) Router (587009)
I'm trying to set up my netgear WGT624v3 router with AT&T DSL. I used to have broadband and used the netgear router. Switched to AT&T DSL. Internet is much faster when I go from the modem to the...
Please follow steps to configure your router with AT&T
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
(still doesnot work then click on basicsetting, it will say does your internet connection require login,you need to click on NO then very bottom there would be router mac address you need to select USE COMPUTER MAC ADDRESS then click on apply
17. Logout of the router.
18. Open up another browser window and try to access internet.
Hope it can resolve issue
Thanks for using Fixya
Apr 17, 2010 | NetGear WGT624 Wireless Router
No internet access with wireless
First of all check the DSL cable must be in WAN port of the linksys router. if it is done then do the following.
Actually DSL modem and Linksys router are conflicting with their IP class. Means DSL and Linksys routers are using the same IP class of 192.168.1.1 or 192.168.0.1.
You must change one's IP class because both are routers and if they having same class they cant communicate. Unplug the WAN cable of the linksys. open browser and put ip 192.168.1.1 or 192.168.0.1 any one which works for u in the address bar. Username and password hopefully be admin admin or just admin and password blank field.
when you access the linksys router configuration page then come to LAN configuration. If there IP is 192.168.1.1 then change it to 192.168.0.1 and if it is 192.168.0.1 then change it to 192.168.1.1 Save configuration and reboot your laptop and plug dsl cable to linksys WAN port.
Hope now this will work.
Regards;
Hasan
Dec 30, 2009 | HP Pavilion dv6000z Notebook
Dont have internet connection on my laptop
First change your LAN ip range on WRT54g, leave the wan interface as dynamic IP client. Connect your WAN port to the DSL router interface. ping your DSL router interface (most probably your DSL router will be having 192.168.1.1). Make sure that your laptop is not assigned with any static IP (Incase you use the laptop in home n work).
Jun 12, 2009 | Linksys Wireless-G WRT54G Router
I'm having trouble hooking up my zonet wireless router. I put the cd in and did everything but it still wont work.
Are you running a DSL connection, or is it cable? If you have a DSL connection, the router IP and the DSL modem will conflict with each other trying to establish connection. This may be something to call zonenet customer support on to find out if it is possible to change the router IP address so they don't conflict. If you want to basically "PLUG and PLAY" return the zonenet router and get a D-Link wireless router. They are most compatable with DSL connections.
Mar 14, 2008 | Computers & Internet
Solution 1 didn't work
Your Verizon DSL modem might be set to BRIDGE MODE. Try connecting the router again. Connect your pc to your router. Access the configuration page of the router. Set the INTERNET CONNECTION TYPE to PPPOe. You need to enter on that page the USERNAME and PASSWORD for your VERIZON DSL. Hope this helps.
Good Day
Mar 12, 2008 | NetGear WGR614 Wireless Router
Got a new modem so i decided to re-setup my wireless netgear router again. ive done everything the manual has said multiple times and everytime all i get on the LED display are the power light, internet...
Is all the cable connected? Is the ethernet cable or broadband cable all connected?
Did you check if your wireless internet works. My friends router indicator for the wireless died but the wireless connection has no problem. If that does not work try to get a different modem and try again. If it still does not work you may have to get somebody to set it up for you.
Sorry that i can't be much of a help.
My father is much better at this kind of stuff than me.
Mar 08, 2008 | NetGear WGR614 Wireless Router
Cannot connect with ATT modem
Connect your pc to the ATT box. If online, check the ip address of the computer. If the ip address is 192.168.1.x, then you just have to change the router ip address. The wrt54g ip is 192.168.1.1, it may be having conflict with the ATT modem. Change the wrt54g ip to 192.168.2.1
Good Luck
Mar 05, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
