Goodmans tvc141 combi + AV sender problem
I have an av sender but have no av button on my Goodmans tvc141 combi remote box to receive the cable channels - how do i get cable channels on my tv please?
Benimur
  • 6966 Answers
SOURCE: RE; Remote control TV/AV button doesn't work LXI series
Hi, Based on your post/description: 1. the TV is stuck to A/V; 2. you have two video sources - VHS & DVD (assuming both are external and both have A/V outputs with the VCR also with inputs); 3. you want to use either VHS & DVD, one at a time. You can do it the old fashion way, remove yellow, red, white RCA connectors from DVD and plug them at the outputs of the VHS when you want to use the VCR; or Connect the A/V outputs of the DVD to the inputs of the VCR, connect the outputs of the VCR to the A/V inputs of the LXI TV. Hopes this give you an idea. Post back how things are or should you need further information. Good luck and kind regards.
Posted on Aug 24, 2007
  • 22 Answers
SOURCE: Can't access AV Channel on Sony KV-C27TD
If the TV has no RCA inputs, then there is no "AV channel" option for it on any remote, just channel selection.
The purpose of a RCA to SCART converter (aka RF modulator) is to convert one of your channels to an A/V input. They operate (standard) on either channel 3 or 4 as selected by a switch on the converter.
If your converter is unpowered, it's entirely possible that the signal coming out is not good enough to overpower your antenna signal. In this case, you may need a powered unit (such as this one http://www.bestbuy.com/site/olspage.jsp?skuId=5806345&productCategoryId=abcat0107025&type=product&tab=7&id=1067388827858#productdetail) which can actively "shut off" the antenna input when signal is received from the auxiliary device.
Posted on Nov 13, 2007
SOURCE: How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
I had this problem with my TV/VCR combo unit (Samsung CXC1972) after losing the remote while in the dorms. I tried a few different universal remotes and dozens of codes before I tried the Philips 3 device universal remote as pictured below with code 037 programmed into the VCR/DVD button. I can't change the volume with this code but the input key switches between line in and tv. You can also change the channel, access the menu and operate the VCR functions with the code. I bought the remote for less than $10 at Walmart so it might be worth a try, and if it doesn't work you can always bring it back. Hope this helps.98fe8a9.jpg
Posted on Jan 19, 2008
crazy larry
  • 6 Answers
SOURCE: how to access AV channel on Toshiba TV model 2125RA
some sets auto-go av when you plug a rca jackin the set, others have a switch in front or back , others you might set your channel to 00 or 99 or 100 forget and work different , I the owners manual of course would tell you. but I assume u dont have it . try hooking it and letting the dvd run now find it using the remote.
good luck.
Posted on Feb 23, 2008
SOURCE: changing the channel to av without a remote
I dont know if you tv has this sertting but click menu usally 4 times and it will bring u to a page wich might say channel or something else and u can chane the channel by using the volume buttoms this worked for me and i can put it onto av1 av2 av3 and av4
Posted on Jan 03, 2009
CHANGE CHANNEL TO AV/SCART ON A GOODMANS TVC 1400 WITHOUT THE REMOTE CONTROL , ONLY RUNS THROUGH 7 CHANNELS
Not familiar with this, but see if there is another button on front or top or behind a cover marked AV or source, if so then that will select the channel you want.
Sep 16, 2014 | Televison & Video
Receiver stays on stand by
Turning On and Standby
On the AV receiver, press the [ON/STANDBY] button.
On the remote controller, press the [RECEIVER] button, followed by the
The AV receiver comes on, the display lights up, and the STANDBY indicator goes off.
To turn the AV receiver off, press the [ON/STANDBY] button, or press the remote
controller's [ON/STANDBY] button. The AV receiver will enter Standby mode.
If you have any trouble using the receiver, a simple reset could solve your problem.Note that resetting the AV receiver will delete your radio presets and custom settings.
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VCR/DVR] button, press the [ON/STANDBY] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Onkyo TX-SR307 A/V Receiver
Ive got a urc-3920 One for all remote . All functions works perfect , but the AV button mutes the TV. Cant change to AV with remote.I've pressed all buttons on the remote to see if it has not been switched...
i have a goodmans tv GTV69RFDT and i have brought a one for all remote urc-3920-urc 3940. All the codes dont work, i have tried the seach method and still nothing is working properly, i get the number buttons and volume but no up channel and down or menu button. Need help
Dan
Nov 03, 2010 | One For All URC-3021 Remote Control
Using a magic eye with an onkyo av reciever
Logitech's Harmony 900 is an RF remote that works through doors or walls. I think that it may be what you are looking for.
May 20, 2010 | Onkyo TX-SR607 Receiver
Old daewoo tv, cant get my xbox to work on it, no
www.remotes.com has a substitution for the original remote. Unfortunately you will have to have a Daewoo remote to get it to switch over. Thanks
Nov 10, 2009 | Daewoo DTQ-29S1FCN 27" TV
Hi, i have just bought a logik wireless av sender so send my sky signal to the tv in the bedroom. the instructions in the manual are very basic and i cant get it to work. any ideas. on the tv in the...
Red and white are only Audio ports.
IF there is a scart port plug your av receiver into the scart. Take note on which number your on ie channel there should be several numbers you can choose on your tx/rx then go down stairs to your sky box and ensuring that you are on the same number as the one upstairs.
Then just plug it into the back of your sky Box.. the number on your sender are incase your getting interfearance from other sources in the home. have a play with this and see what works best
Hope this Helps
Little Dish Fitter
Aug 22, 2009 | Televison & Video
Philips 21RF vardaan there is no sound but everything works fine
buy a remote for rs 100 . select the AV button on the remote .
May 27, 2009 | Philips 32PW6506 32" TV
Lcd tv not receiving remote control signal
Whatever circuit board the remote signal is received on is faulty.
May 19, 2017 | Televison & Video
WIRELESS LINK FOR SKY+ BOX
your sky box should have 2 scarts ;input and tv.I have one so as can watch sky upstairs and on projector screen.
reciever sender is in av on tv upstairs sender downstairs is in scart next to tv scart on skybox scart lead in tv scart connected to av on tv.some senders need to be turned on.when you plug in adapter and led is on doesnt necessarily mean sender is on .is this a new sender with instructions youve bought
Jan 01, 2008 | Acer TravelMate 2300 Notebook
Televison & Video Logo
158 people viewed this question
Top Televison & Video Experts
