Question about Dataproducts FP 2000A Matrix Printer
Getting different character printout after replacing Timing and s
After replacing Timing and status board getting different characters
on self test and online printouts. Looks like Chinese. Also replaced
processor board but then restored the original processor board.
  • rbelisle Dec 31, 2008
    Actually, the printout showed misplaced characters like the pound
    sign and period but made the printout unreadable. The fix was to
    set the switches on the S3 switch bank the same as board that was replaced which was overlooked.
    President:
  • Dataproducts Master
  • 990 Answers
Hello sir; there are so many difference sub-manufacture around the world, they made their ovwn language, so you have to reset, just press the manu key search for language,pick up english should be ok!
Posted on Dec 30, 2008
What is an internal conflict and a external conflict
hi Conner.
What is the difference between an external conflict and an internal conflict? Internal conflicts are character vs. self. • External conflict, which generally takes place between a person and someone or. something else, such as nature, another person or persons, or an event or situation. External conflicts may be character vs. character, character vs. nature, or character vs. society.
What is an internal conflict and external conflict Google Search
Dec 13, 2017 | Computers & Internet
What is the cause of characterized printout. When I printout a test page, it just prints all sort of digits and numerals in no chronological order. What is the cause, is it the motherboard??
A print test page does just that the printer will print every character that is in its memory, together with lines and if it has colours will also use the different colours
Oct 06, 2015 | Office Equipment & Supplies
I am getting all the wrong characters, when I
You simply need to replace the daisy wheel to resolve this issue.
Jun 16, 2010 | Brother GX-6750 Typewriter
Printing - print job arives @ printer no output
Sounds like a driver problem. Some printers require eoj (end of job) character & will wait forever.
Do a test print (search internet on how to print status page- usually button press combo). If you get a printout, you know the print engine is good.
If the printer is able to parse text, then try sending an ascii test file & see if anything prints. This will tell you whether it's a comm issue or rendering issue.
Jun 02, 2010 | Office Equipment & Supplies
HP notepad - continueous beeping sound with equal sign characters
If you are getting a lot of = character along with the beeping, this indicates you have a stuck = key and the beeping sound is the keyboard buffer is swamped with the = character. If you can't unstick this key, then you need to replace the keyboard.
Jun 08, 2009 | HP Pavilion dv6000t Notebook
Tally 6100 missing lines
horizontal or vertical characters missing???
if your missing horizontal lines, look at where the print is missing if you see imprints... u have bad ribbons.
if your missing vertical characters down the page
Power off the printer & unplug from wall
Remove with phillips the top right cover. u will see that the control panel has a plastic clip needs to be pressed in for the control panel to come loose from the top right cover.
Then you will see P703 Hammerbank Ribbon Cable and
P704 Hammerbank Ribbon Cable swap these 2 cables on the Engine Controller Board part# 083368.
IF your missing characters move to another place on the printout then u will need to replace part# 083368.
IF your missing characters are still in the same place, then you will need to replace hammer module part# 081152, their is qty 11 of the individual 081152 about 1 inch wide. this will save $$$ ordering and replace 081152 if you have some at your work semi technical.
Be very careful with hands when powering the printer with the top right cover off
Electrically and mechanically.
Need more help you may call Toby at x311
Apr 24, 2009 | Tally Line Matrix T6100 Printer
Printing not proper
Adjust the printing properties from normal to best.
Mar 28, 2009 | HP DeskJet 3940 InkJet Photo Printer
AE 740 types different characters than typed on keyboard
make sure your printwheel is latched securely, turn off t/w, press and hold the margin release button while turning power on to do a reset/self-test. if characters are not right on self test, then you might have a problem with either the carriage or main board.
hth,
razors
Feb 05, 2009 | Nakajima AE-740 Typewriter
I'm trying to go through the setup to WII fit. My child did the body test with no problems a couple of days ago. I keep getting an error (fidgeting) when I try to take the body test. Tried to do fit test...
If your Wii Fit Balance Board is on carpet, be sure to use the extra foot pads that came with your board. If your carpet is really thick, you may need to use a flat woodend board to set the balance board on.
Finally, make sure that you are NOT using your child's Miii to do your own balance test. Each user of Wii Fit must use their own Mii character.
If you don't like my suggestion, please don't rate this suggestion a '1'. If my suggestion doesn't help, the problem may exceed the scope of what can be answered here. You will need to contact Nintendo directly through their website and open a problem ticket.
Good Luck!
Jan 17, 2009 | Nintendo Wii Fit for Wii
Horzontally double printing & characters are not clers.
Is the ribbon tight or sticking, If ribbon can't turn, it delays entire carriage, you will notice that if you move carriage up and down by hand ribbon turns, I have seen sticky ribbon s cause problems as well as gearing that drives ribbon with wornout gears
If self test fails then all faults /i can think of on these is
  • Dry rail/dirty bearing
  • incorrectly manufactured ribbon
  • Damaged dot head
  • broken/breaking ribbon interface carriage cable
  • worn ribbon drive gears
  • worn/dirty ribbon drive rail
  • main board
Nov 17, 2007 | Epson LX-300 Matrix Printer
Dataproducts FP 2000A Matrix Printer Logo
99 people viewed this question
Top Dataproducts Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dataproducts Office Equipment and Supply Expert? Answer questions, earn points and help others
