Question about Fujitsu M4097D IPC Path-Through Flatbed Scanner
Inconsistant Blank Streaks
I've got a problem with blank streaks down all of my scans, one time it will just be the middle, the next it will be most of the document, very inconsistant. I've clead glass, rollers, basically everything i can get into. is this a cleaning issue? or could it be something else?
  • 247 Answers
Couild still be cleaning. Look to see if there's a separate glass strip across the paper path (usually just upstream of the flatbed window). Dirt here is a common cause of streaks. If not that, then you might be looking at a problem on the scanner array, or in the connections going to it (much harder to get to the bottom of this - and I wouldn't have mentioned it but for the fact you say the streaks are inconsistent). A.
Posted on May 01, 2007
SOURCE:
Images have a streak of color in the middle
The problem you describe sounds like moire.
Try scanning the image at different resolutions until the effect disappears.
Dec 12, 2013 | Kodak i1420 Pass-Through Scanner
Streaks or lines
Vertical streaks:
Check,which color/s streaks are appearing on print out,remove that cartridge/s check on drum surface for streaks.. if found replace that cartridge/s..check.
Horizontal streaks:
This problem appears when the cartridge/s image drum not rotating properly. Resit the cartridges properly, print 20nos of blank pages, then check.... replace the cartridge..
Dec 29, 2012 | HP Color LaserJet 2600n Printer
Our copies are streaky like the drum is not clean.... help! There is black streaks on the top of all of our copies on our canon imagerunner 3300.
A) Black Streaks, Shadows, And Ghosting
Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears. Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Try another toner also.
Feb 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
I'm getting a color line going down the page on my pictures and the quality of the picture is no good
IssueWhen you copy, fax, or scan an original, the resulting output contains vertical bands, lines, or streaks in one or more colors.When you print the original, the output is normal. Figure 1: Sample output with vertical white or black linesc01892760.gif Figure 2: Sample output with vertical colored bands or linesc01892761.gif
NOTE: This article does not apply to most PSC products, to the Photosmart C6100 or C7200 series, or to the Photosmart Premium C309a and C309c All-in-Ones.If you are using a PSC product other than the PSC 2400 or 2500 series All-in-Ones, go to Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans (c01887564) (in English).If you are using a Photosmart Premium C6100 or C7200 series All-in-One, go to Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans (c00899181) (in English). If you are using a Photosmart Premium C309a or C309c All-in-One, go to Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans (c01622189) (in English). Solution one: Reset the All-in-One If there is static interference, or loose connections with the product, this can result in bands or lines in the copy, fax, or scan output. To resolve this issue, check the product connections and reset the product.
  1. Make sure the product is powered on, and then disconnect the power cord from the product.
  2. Disconnect the USB cable from the product, and then disconnect it from the computer.
  3. Reconnect the USB cable to the computer, and then reconnect it securely to the product.
  4. Disconnect the power cord from the wall outlet, and then reconnect it to the wall outlet.
  5. Reconnect the power cord to the product.
  6. Press the Power button (c01892763.gif ) to turn on the product.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , see the next solution.
Solution two: Clean the All-in-One and print a blank copy If the scanner glass or the white underside of the lid has fingerprints, smudges, lint, dust, or other debris, this can slow performance and affect copy and scan quality. To resolve this issue, clean the All-in-One. Before you begin, gather the following materials:
  • Several clean, soft, lint-free cloths
  • Mild glass cleaner
Step one: Clean the scanner glass and lid
  1. Press the Power button (c01892763.gif ) to turn off the product, and then disconnect the power cord from the product.
  2. Open the scanner lid. Figure 3: Open the scanner lidc01893292.gif
  3. Spray a clean, soft, lint-free cloth with mild glass cleaner.
  4. Wipe the scanner glass and the white underside of the scanner lid with the dampened cloth. Figure 4: Scanner glassc01893293.gif Figure 5: Scanner lidc01893294.gif
  5. Dry the scanner glass thoroughly with a clean, dry cloth, or chamois to prevent spotting, and then dry the white underside of the scanner lid.
  6. Close the scanner lid.
  7. Reconnect the power cord to the back of the product, and then press the Power or Start button (c01892763.gif ) to turn on the product.
Step two: Make a blank copy
  1. Remove any originals from the scanner glass.
  2. Load plain white paper in the input tray.
  3. Press Start Copy Black to make a blank copy.
If the copy is clean, there is no need to continue troubleshooting.If the copy has vertical bands, lines, or streaks, there might be dust inside the product, poor internal connections, or the product might be damaged. See the next solution. Solution three: Service the All-in-One If you have completed all the steps listed above and are still experiencing a problem, service the product. Causes
  • Static interference
  • Loose USB cable or power cord connection
  • Fingerprints, smudges, lint, or dust on the scanner glass
  • Dirt or debris on the scanner lid
  • Scratched or damaged scanner glass
  • Poor internal connections
  • Dirt or debris inside the product
  • Damaged or faulty scanner bulb or parts
Jan 27, 2010 | HP Photosmart 2610 All-In-One InkJet...
Hp Photosmart c5280 1/ 2inch thick black line
There is something on your scanner glass. Clean the glass with glass cleaner. If this happens when using the automatic document feeder, open the top side cover where the paper feeds into. There is a narrow glass strip there. Clean that as well.
If this fails, the scanner head has a bad sector on the CCD and will need to be replaced. You will probably find that it will be cheaper to replace the printer entirely if that is the case.
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Magicolor 2530 DL
The streaks are typically a sign of a toner drum going bad, or possibly just dirty, or even caused by the toner being low, as you have mentioned it to be. 1 way I know to 'clean' the drums is to have the printer run multiple blank pages. If your software will not allow you to print blank pages, type a single character by using this little trick, hold down the ALT key, and type 2 5 5 on the number pad in a blank text document. This will allow you to print the "blank" document, I would suggest about 10 copies. This should help for a short duration, and doesn't use any toner.
Hope this helps!
Backu
Oct 30, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Blue streaks on 3800
This is going to seem dumb
If the streaks are in the direction of the lens travel
vaccum the thing out
If there is a dust crumb on the lens, it will show as a line, streak
Jul 02, 2008 | Microtek ScanMaker 3800 Flatbed Scanner
Blank Streaks
streaks are caused either by the toner, drum, lamp or fuser.
If you make a copy and it does not show a streak then it was done by the person sending the fax. BUT, check this,
open door and take out toner cartridge. look for a thin glass that is on the bottom of the machine and wipe it. Toner spills will cause a black streak.
Nov 15, 2007 | Brother IntelliFAX 2800 Laser Fax
Streaks
It sounds like the lamp/light is going out.  Open the top and try to make a copy and see if the light stays on the entire time.
Erice
Oct 29, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Fujitsu M4097D IPC Path-Through Flatbed Scanner Logo
190 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Smidler
Level 1 Expert
Vincent_G
Vincent_G
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
