Question about Hoover U5180-900 Vacuum
Vibration When vacuuming
Love my vacuumj. It just recently started making a vibration sound when vacuuming though. It seems to be coming from the rollers. I have manually inspected the roller and it is in good condition. the belt is not worn either. I am concerned that there may be a piece the should be on the metal rod that the other end of the belt connects to....? Right now the belt is just on the metal 'drive shaft' rod and then goes to the roller. The belt does get pretty hot. The rollers do spin I have watched them. I love my vacuum, can someone suggest something?
  • 247 Answers
I don't think you need to worry about the belt going straight onto the motor spindle - this is usually the way they're meant to be. Similarly, belts tend to run a bit warm. You might like to try something to find out which bit of the mechanism is really making the noise. Remove the belt altogether. Grab the end of the motor spindle, and give it a little wobble. While it should be free to turn, you shouldn't expect to be able to move it along its axis by more than a couple of millimetres. There should be even less freedom to move across its axis. Unwanted motion here might suggest a problem with the motor bearings (probably your least desired outcome) If you spin the spindle, it should be free to turn with a gentle whirring noise, but there should be no nasty knocking sounds, and the spindle shouldn't appear bent. Knocking sounds probably mean something unwanted has got into the motor or (more likely) the fan impellor - and are best investigated by taking it all to bits slowly and carefully. If the motor feels and sounds right, reasssemble the machine without the belt and see what it sounds like when you run it. If it's still noisy, then you're back with a motor or fan problem - but one which is speed related. This too is a dismantle and inspect job - check for any evidence of parts rubbing against one another and pay particular attention to the impellor, looking for cracks in the blade roots (especially near the hub). If running the motor without the belt sounds OK, you've isolated the problem to the roller assembly or the belt. See if anything is fouling (ie getting in the way of) the roller. Take it out and check the bearings at either end spin equally freely. Have a quick look to make sure nothing large is missing making the whole thing horribly unbalanced. Finally, reassemble with a bew belt (they're dirt cheap, and it's surprising how many problems they cause even when they look OK). Unless you have to strip the motor and fan, this could all take less than ten minutes. A.
Posted on May 01, 2007
  • Alastair Macleod
    Alastair Macleod May 01, 2007
    Correction: Word after "Finally, reassemble with a" should be "new". Never could spell on Tuesdays.
    A.
Makes heavy vibration noise when turned on for carpet and belt is good
Check the brush roll and the end caps to insure the brush roll is spinning freely. If there is wear or damage to the brush roll it can cause it to be out of balance and vibrate
Jan 12, 2014 | Electrolux EL5020 Vacuum
Vacuum problems?
do you have a radio that is not factory with a e q hooked up .
Oct 27, 2013 | Vacuums
Noise
Hi there, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your Dyson vacuum. From your description, it sounds like the model number you've supplied may not be correct, as DC08 is a cylinder vacuum which doesn't use a belt-driven brush bar. So we can confirm exactly which model you own and take you through some quick diagnostic checks, I'd encourage you to contact us directly. You can reach our experts by calling 0800 298 0298 (UK), or 1-866-693-9766 (US).
We'll look forward to hearing from you.
Best wishes,
Jack - Dyson Official Online Customer Surpport
http://www.dyson.com
Apr 25, 2013 | Dyson DC08 Cylinder Bagless Canister...
Dyson DC17 making loud noise
Hi Liz,
I'm sorry to hear that you're concerned about the noise your DC17 is making. It will be difficult for us to help without hearing the noise, so it's probably best if you get in touch with us directly. One of our Helpline experts will be able to determine the cause of the issue, and will be able to recommend the best course of action.
You can call us free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Oct 27, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
I inherited an Esccelsa Modello Depositato pasta machine and absolutely love it and know my Mother was able to remove and replace the rollers. But............I would like to remove and clean the rollers...
I know you wrote this a long time ago, so perhaps you've found the answer elsewhere (everyone here seems to think you have a vacuum cleaner)--in fact maybe you've learned enough by now to help me, since I'd like to clean my own Esccelsa. What I can tell you is that it was built by R.I.V. in Turin, and that the manual which came with it wouldn't help you. I've seen it, and--as with a lot of products back in the old days--it's extremely brief. The only thing they mention about taking it apart is urging you not to, and as for maintenance, all they say is to squirt vaseline oil on the bushings.
However, the Esccelsa is the same basic design as most other pasta machines, including the Marcatos and Imperias of today, and on youtube I've found videos of owners of these describing the process of removing the bottom and side plates to get at the rollers, though I've yet to find a video of anyone actually doing it.
May 11, 2011 | Vacuums
Very loud "jet like" noise,please
Vacuums are noisy, but shouldn't sound like a jet.....
Trying to find out what is wrong depends on what kind of noise it makes, i.e. high squeal, vibration, whining and where it comes from.
Here is a webpage with troubleshooting advice on noise in vacuum cleaners. Hopefully you should be able to track down the problem. http://www.ehow.com/how_7493926_fix-noise-vacuum-cleaner-motor.html
If you need further help with repairs, please reply back. Thanks,
Handie Andie
May 09, 2011 | Dirt Devil Reaction Twin Cyclone Upright...
My Dyson is making a really strange loud sound. It appears to be working. I just took it apart and cleaned the filter and the wand. When I put everything back together, it started making a heavy whirring...
Check the tips of the beater bar. I "bumped" mine to hard and broke a tip. Still worked! Just noisy. Called Dyson support and they sent me a new one no charge. Note. Mine had a loud whirring and a vibration.
Jan 30, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Hoover U5180-900 Vacuum Logo
184 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
