Question about Olevia LT42HVi 42 in. LCD Television
RV generator destroyed color on Olevia TV=generator off color bad
On a recent trip when we turned on our Olevia LCD screen TV while the generator in our RV was running the color distorted by black turning shimmering blue, yellows on skin tones and other distortions. A friend mentioned it was "noise" from generator and probably needed a filter, so we turned off the TV and didn't turn it 0n again until we were hooked up to electricity in a KOA Campground. The color is still distorted and shimmery blue on the dark colors. We were referred here by a amature TV tech and thought we would get your opinion.
Is the TV permanently damaged or out of adjustment? TV came with our RV and is just 2 mos over waranty period so can't expect RV dealership to help.
  • sass21hondo Dec 30, 2008
    We figured it was probably damaged, however, the warranty period is over by 2 mos so we were hoping it might just be something simple. Thanks for the prompt response, now we need to decide to pay to have it fixed or replace it. Not sure we want another Olevia anyway. Thank you.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, a couple of ideas you can try/explore/consider::
  • is the color/video distortion on all Source/Inputs, DVD, tuner, regular TV, HDTV Terrestrial Receiver;
  • have you tried unplugging from the mains for an extended period of time (turning off the generator would be the same);
  • have you tried doing a reset/default on settings/menu;
  • have you tried pressing the v.format on the remote;
  • have you tried going to HDTV setup, format and change the "format". Choices are: 480i 480p 720p 1080i;
  • have you tried a soft reset, power on, up, down, left, menu.
Good luck and Thank you for using FixYa. Happy New Year.
Posted on Dec 30, 2008
  • 163 Answers
Check that, is there any me magnetic field or any other electronic device near to TVNote: any magnetic field or any heavy electronic device caused damaged to your tv.
  • 304 Answers
It seems that the unit was practically damaged due to this power abnormality. aand you said it was only 2months over, and it is still cover under warranty. it better not to self service the unit, and call it in your manufacturer and put it under the warranty service.
Multiple colored lines on my tv, then about 2 minutes it shows the picture. I replaced the t-con board, now what?
Unfortunately, lines in the screen is usually caused by a bad LCD panel. You eliminated the T-Con as the problem after replacing it. A replacement LCD panel is very expensive. Buying a new TV is cheaper. Sorry.
Nov 04, 2013 | Olevia LT26HVX 26 in. LCD Television
32 in olevia 332-b11 tv and the color is going bad how do know if it's the master backlight inverter or the other one
It is neither. Your inverters do not control your picture color. All they do is power the back-lights. If your color is going out, odds are it is in your main board.
Apr 11, 2011 | Olevia 332V LCD TV
My 32" Olevia lcd when i turn on thre tv it will work for a couples of minutes then then screen turn very dark with images,sounds ok,then it will change back and forth.
you may have a back light inverter board bad.
undo the back and check the power supply for bad caps in the inverter area , or check the inverter board
Aug 14, 2010 | Olevia LT32HVM 32 in. LCD Television
Flat screen tv power surged
Is it just the cable? Do you have a DVD player or game system connected? If so, how do they look? Ofter a momentary power loss can cause cableboxes to loss picture, loss sound, and even cause the picture to be distorted. Try unpluggind the AC power from the cablebox and TV. Wait about 5 minutes and reconnect both. Leave the cablebox alone for about another 5 minute after you reconnect it so that it can fully boot up. Then see if you still have the problem.
Mar 15, 2010 | Olevia LT37HVS 37 in. LCD HDTV
My Olevia 27in. LCD Television does not turn on
Well, at least the standby 5vdc circuit is still working but the problem can be in the controller board is not sending the signal to turn on the main power supply sections, or the power supply itself is bad. Look at the power supply first for burnt parts, bad capacitors.
Nov 10, 2009 | Olevia LT27HVX 27 in. LCD Television
White screen with some colored vertical lines
christoph430. Your TV is hosed. Olevia will not fix it even if it is still under factory warranty. They are having lots of issues with their products and it will be too costly for them to pay for the repairs they should be covering. They are hoping you have an extended warranty through whomever you bought the TV from and will let that company deal with what should be THEIR problem. The repair company has to try to fix the TV at their cost. Nothing but a scam. We will never buy an Olevia TV again. Respond to if you would like to understand details about our frustration with them. Unbelievable. Sorry for the bad news.
Feb 23, 2009 | Olevia 237T 37 in. LCD TV
37" Olevia Tv
Unless some one with a remote did it the set would not likely turn itself on..
Mabe someone was in your rv
Sep 02, 2008 | Olevia LT42HVi 42 in. LCD Television
You need to take the unit to an authorized repair shop to have it
check and correct it , looks like the power supply section got affected by the sudden change of voltage and damaged an internal part, hope this helps , AJ
Jul 02, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Power problems
I have a 32'' olevia 232v hdtv. I had a similar problem where the tv stays on less and less as you use it longer and it gets warmer. I called customer service and they explained that its most likely a problem with it is doesnt have enough power to run well. They said turn the TV off, then hit the master turn off switch in the lower back of the tv, then unplug everything from the TV, then unplug everything from the wall. Then after 3 or 4 hours, plug all back in and try again. Then they said if i still have a problem, call customer service at 1 866 9 olevia
Sep 29, 2007 | Olevia LT37HVS 37 in. LCD HDTV
Olevia LT42HVi 42 in. LCD Television Logo
44 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
