Washer/dryer wont do its programme
When you start a wash it makes a sound like the dryer is working after a minute the reduced creases button flashes along with the on off button,it continues to flash not allowing overide. Is it the front faschia board gone wrong and how much to repair?
  • 15,935 Answers
It appears your main controller and/or touch panel has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
I have an aeg washer dryer L87695NWD which is stuck on drying. When I turn the button to select a washing program the drying light stays on, and the washing light is still off.. what can I do?
From user manual:
10.4 At the end of the drying programme
1. The appliance stops automatically.
2. The acoustic signals operate (if they are active).
3. In the display (number "0") comes on.
4. The indicator of button Start/Pause goes off.
5. The last minutes of the drying cycle the appliance performs the
anticrease phase. The anti-crease symbol ietounus3lrwasi2ko2vq2k81km1my9gxk62inwk5r2qaaaabjru5erkjggga=flashes. The
door is still locked (the key ezfxrjud2vanwq0oeawt0sih4u7drnvleuvj3nru5hkbv+p2lq2ra1xbwbjeddwhka3byaaaaasuvork5cyiiasymbol is on).
6. Press button On/Off for some seconds to deactivate the
appliance. After some minutes from the end of the programme,
the energy saving function automatically deactivates the
appliance.
7. When the door locked light goes off you can open the door.
8. Remove the laundry from the appliance. Make sure that the drum
is empty.
9. Keep the door ajar, to prevent mildew and odours.
10. Close the water tap.
If this doesn't help than check:
- If the delay start is set, cancel the setting or wait for the end of
countdown.
- Deactivate the Child Lock function if it is on
If anything of this doesn't help then pay attention to all the symbols appears on the display and check what it means in the user manual.
Dado
Apr 01, 2017 | AEG Washing Machines
Hotpoint WD440 washer/dryer wont control.when plugged in 4 lights flash and it goes to pump out . no switch has any effect. the lights flashing are the on/off ,drying high heat.reduced creases and time...
The NTC for the dryer is situated on top of the dryer heater box, fault can often be caused by a simple broken wire, they are very weak at this point.
its the sensor on the dryer
if you take off the top, its mounted on top of the dryer box, usually has a white plug with 2 black wires attached
Dec 13, 2011 | Hotpoint Ariston WD440G Front Load...
NEFF washer not starting. error code 3/flashing anti-crease butto
This may be a simple control fault that can be reset by unplugging for 5 minutes or switching the breaker switch off for five minutes also. if the five minute reset doesn't restore the machine to its original operational value, you will then need to replace the main control board in this unit. it has failed.
May 11, 2009 | Neff V4380X0 Front Load Washer / Dryer
On and off light and energy save and reduces creases lights flash
Hi Snarey, it sound like your door lock has passed away, you will need to make sure the appliance is unpluged, empty the water out of the drum, and check the vacuum switch which opperates the lock.
Mar 09, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wd44d wash/dryer wont finish a wash nor wont pump out
there may be something stuck in the pump itself. hairgrips and brawires are a common find.
Jan 19, 2009 | Hotpoint Ariston WD440G Front Load...
On/off button & non crease button flashing
Sounds like the pump and sump hose is blocked,Check both out
Oct 29, 2008 | Hotpoint Aquarius WD63 Front Load...
My hotpoint aquarius wd440 washing machine - flashing lights ?
I have a fairly new Hotpoint Aquarius machine (out of guarantee).
When it is switched on, all of the red lights flash and it will not operate.
Can you help please ??
Oct 18, 2008 | Hotpoint Aquarius WD63 Front Load...
ON/OFF & Time saver Button keeps flashing
For mine, it started flashing the on/off light along with the "drying high heat" and the "reduce crease".
Unplugging the unit for 30 minutes appears to have reset the machine and it is now working.
Aug 18, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WD440G
I SWITH ON THE MACHINE AND F 01 APPEARS
Aug 27, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
