Question about Hoover Company Wind Tunnel U53019 Upright Vacuum
Problem with use on carpet
The machine works fine in upright mode with the hose and tools or on bare floors. In carpet mode it is very hard to push and the belt overheats to the point of smoking. I took off the beater brush and it rotates freely when you hold the plastic end pieces. When it is off I can't find anything binding or rubbing. The self-propel feature works ok, and does not affect this problem. I'm baffled- any ideas? Thanks!
Your carpet setting is set to low, raise it to a higher pile.
Posted on May 01, 2007
  • 247 Answers
Very professional and useful account there of the problem and investigation so far! Unless you've got evidence that your machine is damaging the carpet, I'd be inclined to put a new belt on and see if that fixes it. Carpet makes the beater/brush roller much harder to turn than bare floor does, and this can be enough to start a loose belt slipping (after which things don't naturally improve themselves). A.
SOURCE:
Why does my eureka air speed vacuum not work when in floor mode?
There is an adjustment for carpet and for hard surfaces. Have switched it from carpet to a hard surface. When on carpet it sets up higher on a hard surface it should set lower. If it is to low it work properly either.
Oct 16, 2016 | Eureka Vacuums
Bissell carpet shampooer
HI,
Please check these:
• tanks are not sealed into receivers
• faulty auto load receiver
• pinched/clogged line
• defective component allowing air into system
• pump not mounted so it can move freely
• defective bridge rectifier
• clogged heater
• defective pump
• defective circuit board
* spray nozzles are clogged
Jul 20, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
After less than 2 years of use why is my DC41so hard to push on bare floors and carpet with the roller brush engaged? My wife will not use it any longer.
Your problem is with the centre wheel. This article will explain everything: http://dysonmedic.co.uk/dyson-dc40-dc41-dc50-hard-to-push-sticking-to-the-floor/
Feb 28, 2015 | Dyson Bagless Upright Vacuum DC41 Animal
How do i alter the dyson dc04 to use on hard floors
Hi there, it's Jack at Dyson.
If your DC04 has a brush control on the cleaner head, you'll need to set this to 'On' for carpets, and 'Off' for hard floors. You can find out how to do this on our Support site:
http://www.dyson.co.uk/support/dc04/dc04-brush-control/my-machine-is-not-working/i-can-see-something-wrong-visual/i-can-see-something-wrong-visual/my-brushbar-is-not-rotating2/does-the-brushbar-rotate-with-the-power-on
If your machine does not include the brush control, it will only be suitable for vacuuming carpeted surfaces and we'd advise against using it on hard floors in upright mode. However, you can use the hose and wand to vacuum hard floors and we have several suitable hard floor tools available which may help.
I hope this helps - if you'd like further advice you can reach our freephone Helpline on 0800 298 0298. Just to let you know, our Helpline is available from 7am-10pm, 7 days a week.
Best wishes,
JackDyson Online Customer Supporthttp://www.dyson.co.uk
Mar 06, 2013 | Dyson DC04 HEPA Bagless Upright Cyclonic...
Pushes hard over the carpet and left lines in the new carpet. My father pulled it backwards and seemed OK. It just pushes extremely hard forward. The Dyson is about four years old and have not had any...
Check the axles of the wheels for debris accumulation. Also, make sure the height is set for the type of carpet that you have. Try pushing the machine on a bare floor--is it hard to move there also? Hope this helps!
Nov 28, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Stripped gear noise occurs in carpet mode, not bare floor mode
Maybe the level to carpet is too low or there is more then one belt and one is broke?
Mar 26, 2017 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Placing the handle of my Dyson DC07 into its upright and locked position causes the beater bar to stop turning. It will not start turning until the handle is first lowered to the working position and the...
Hi its Darran at Dyson.
The brush control is designed to switch the brush bar off automatically when you stand the machine back into the upright position. It is designed this way to protect any delicate floor surfaces when you have the machine switched on and upright and when you are using the hose.
If the brush control should be in the centre position and move forward to the "on" position when you release the head. If it is not doing this, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Feb 22, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My brush bar won't turn - works in bare floor mode, but carpet brush won't turn when it should...
replace the belt the belt sounds like its worn or stretched the belts turn at high rpms and get very hot and soon just ware out they work fine on floors but when it comes to carpet they slow down, i hope this works out thanks
Nov 30, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Changing from carpet cleaning to hard floor cleaniang
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=540075
Changing from carpet cleaning to hard floor...
Posted by Charlottek on Apr 23, 2008
Bissell 9500 ProHeat 2X Clean Shot Upright
How do you change machine from carpet cleaning to hard floor cleaning?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The Bissell 9500 ProHeat 2X Clean Shot Upright are mainly designed to do mostly carpet, you can use it for bare floors, but for good wood floors I would use less water and pickup the water ASAP because you don’t want the good wood floor to warp - linoleum floors are fine but be careful with wood floors, and remember that the Bissell 9500 ProHeat 2X Clean Shot Uprights
Clean on the pull back, you squeeze the trigger, dispense water, the machine will use the scrubbing brushes to clean and the vacuum will pickup the water all in one smooth motion.
For further information please feel free to contact your local vacuum cleaner dealer in the area or the yellow pages or contact the Bissell Factory @ the information listed below:
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 23, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hoover Company Wind Tunnel U53019 Upright Vacuum Logo
230 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
