Question about Dryers
The starter won't start the machine
When I turn the starter on, there's a noise, but the machine doesn't start
I turn on the knob to start the dryer and it makes the sound like the dryer is done with a cycle but the dryer won't start. I had a repair man over and he told me the motor was shot.
Posted on Jan 13, 2009
My 2000 Pontiac Montana won't start. I hear a clicking noise from the back but the starter doesn't engage
have somebody hit the starter with a hammer while somebody turns the key on the start position as he holds the key keep hitting the starter not at the solenoid at the round part if it tries to start then you have a defective starter now if you have a alarm system you are going to have tutoo isolate the starter to do a different test.
Apr 16, 2013 | Cars & Trucks
My starter won't work just one click noise when I try start my harley
A LOUD single click, sounding the the started is initally engaging and then does nothing?....that would be a bad starter clutch.
Is it a fairly loud rapid clicking noise like a machine gun?....that would be low battery CURRENT to starter, faulty battery.
Is it a quiet single click?....that would be a bad starter relay
Mar 30, 2013 | Harley Davidson Motorcycles
I have a 2000 Ford Taurus. My wife left the radio running with the ignition off for a short while. Now the car won't turn over, won't start, won't jump. There is one click when trying to s
The click you are hearing is most likely the start slenoid making contact, however you should short the large wires @ the solenoid to make certain the starter still doesn't run, if so try tapping the starter with a hammer to shift the comutator a litle and try to start. Even if it now starts the starter will continue to give you problems so the proper fix is change the starter
Sep 22, 2012 | 2000 Ford Taurus
Ford contour wont start
You need answer some questions first to rule some things out.
Is the starter making a noise when you turn the key or is it just clicking? If the lights light, but the starter makes absolutely no noise, then the power cable to the starter is bad or contacts are corroded. If you hear a click every time you turn the key but that is all, then the starter is bad and needs replace. Once it is removed, most parts stores can test it for you. If you can hear the starter spinning but its going real fast then again the starter is bad. If the starter is working properly (like on a really cold day when it doesn't start right away) but the car still won't start, then the starter is fine and your problem is either in the ignition or the fuel system. You may be able to narrow it down if you can read the codes, otherwise it needs a mechanic and you need to decide what is the car worth to you.
Sep 17, 2012 | 1998 Ford Contour
Jon Deere mower LX277 won't crank
Try replacing the starter solenoid. If that doesn't do it, try replacing the whole starter.
May 05, 2012 | John Deere Garden
Car won't start . Clicking noise wen key is turned
It's your starter. Find location of your starter. By the flywheel. Then. Bang on it . Your car will start. You still need to replace the starter.
Dec 08, 2011 | 2004 Honda Accord
I have a 2002 Chrysler town and country. I just put in a new battery 3 weeks ago and they checked the alternator and said it was fine. Now it won't start. When you turn the key the radio and lights...
I hate to say this to you but make sure the engine is not locked up. If you can turn the engine, either by pulling on the belt, or by putting a wrench on the crankshaft bolt, try another starter. If you can't turn it, try another engine. (sorry for the insensitive attempt at humor)
Aug 17, 2011 | 2002 Chrysler Voyager
My car will not start my lights, radio work its not the battery. I recently replaced the starter, the altenator, battery, fuel pump catalyic converter. when i turn the key there is no noise it won't...
Sounds to me like the starter or starter relay, OR did you check all the fuses? When the starter doesn't click or turn over the engine it is likely a problem with it or the power supply to it. Start with the easy thing. check the fuses, then the relay.
The P0300 is usually caused by something other than the spark plugs or coils. A fuel/oxygen sensor can cause this code. I would say that doesn't have anything to do with not starting.
Good luck.
Thanks for using FixYa.
Gaker
Jul 22, 2011 | Ford Expedition Cars & Trucks
Car will not start, just makes a whirring noise when I try to start it,the check engine light comes on.
There is most likely a problem with your starter -- if it is not grabbing the engine to turn it over when you turn the key, the starter motor will spin (giving you the whirring noise) but the engine will not move. First things first ... have someone turn the key, and hit your starter with a stick or something ... sometimes this will free up whatever part is not working proper5ly, and you won't have to replace your whole starter. If hitting your starter doesn't work ... and if you are good with cars, try replacing the starter and see if that helps.
Hopefully those will help ... if not, you will probably have to take the car to a mechanic to get it fixed, as there are several other parts that could be causing the issue -- but they are hard to get to and require some experience to know what you are looking for.
May 29, 2011 | 2004 Chevrolet Cavalier
Dryers Logo
63 people viewed this question
Top Dryers Experts
