WHAT IS FAULT F01 ON MY WASHING MACHINE WF860
STARTS TO FILL UP THEN STOPS AND BEEPS THEN SHOWS F01
  • Washing Mach... Master
  • 3,463 Answers
F01 indicates a short circuit motor triac, this is part of the motor speed control, either in the motor, or the control unit, and as such is something you cannot repair yourself.
It means that you will have to call hotpoint unfortunately.
If it is under 5 years old, then you should be able to get it done under the 5 year guarantee.
Plz rate my solution.
Thanks.
Posted on Dec 30, 2008
I have a Fisher and Paykel Smartdrive 9 washing machine that won't fill. It starts then stops and continues to do so, then stops altogether and beeps. Can anyone help??
The error code is displayed when its beeping.
I don't know the error code, so It can only be three things,
Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below.
Add up the lights that are on.
Jan 08, 2013 | Fisher and Paykel Washing Machines
Showing F01 error code on readout? what does that mean?
Hi.
It depends on the model. On Whirlpool built machines F01 is EEPROM error, pump drive error, or main relays error.
With Hotpoint F01 means defective triac or defective motor.
Aug 18, 2011 | Washing Machines
Hi my washing machine door wont open, feels like the lock has broke ??
hi have you tried turning machine off at plug for a min then power back on put on a cycle press start. wait till it starts to fill and press stop and hold down the reset button till it beeps and wait till door unlocks. Or a quick way to open the door is unclip the foot kick stopper at bottom front of machine and pull the emergency door open which is a thing peace of hanging plastic. if none of this works try starting a cycle then press stop soon as it starts to fill and turn off on machine not at plug. hope this helps.
Sep 20, 2010 | Hotpoint Ultima WF860 Front Load Washer
Wf860 washer dryer - dryer has no heat and displays f01
Hi, Fault code F01 indicates a problem with the motor triac.Check all connections to and from the motor, the control module, and the motor plug
Apr 08, 2010 | Hotpoint Ultima WF860 Front Load Washer
What does a fault F01 signify on a Hotpoint Ultima 7kg washing machine?
Error code F01 indicates a short circuit motor triac.
Thoroughly check all connections on the motor, the motor plug, and the electronic module board..
Look for a broken wire, or a bad connection.
Please rate my solution.
Thankyou.
Jan 22, 2010 | Hotpoint Ultima WF860 Front Load Washer
Error F01
i have the same problem the machine gets part way through a cycle and then stops and Displays F1.
Oct 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
I have a Hotpoint ultima wt960 with f01 error can I fit the part
Hi
f01 means motor fault. remove motor and check the brushes. if ok then fault could either be motor or pcb which is faulty.
regards
Mar 21, 2009 | Hotpoint Ultima WF860 Front Load Washer
F01 flashes and machine not work.WF860P
motor triac short circuit check motor and module connections, if o.k poss motor fault
Jan 26, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
709 people viewed this question
Top Washing Machines Experts
