Question about Dryers
Dryer not getting hot, is it dryer element? - Dryers
  • 3,463 Answers
It is more than likely an element or stat(s) problem, as you do not state make, I cannot tell you where to look for them. Usually , they are located at the rear of the m/c, but not in every case.
Hope this helps.
Plz rate my solution.
Thanks.
Posted on Dec 30, 2008
I have samsung dv220aew/xaa dryer, that gets too hot and kicks code HE. New element, thermistor and cleaned thoroughly. Gets hot, codes on all heat settings. Any ideas?
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Apr 21, 2015 | Samsung Dryers
Why does dryer gets super hot
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Aug 02, 2014 | Dryers
What could be causing inside of the drum of my AD55 F&P dryer to very hot?
see this causes and fix it. God bless you
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Sep 28, 2012 | Fisher and Paykel Dryers
Whirlpool Electric dryer type-DWJR-ELE-2406028-FM54. model LER7646JQO the heating element get very hot. the dryer does not turn on. the drum does not turn either.
If the heating element is getting very hot that means there is no air flow across it. If the drum doesn't turn then the blower is not turning causing the element to get very hot. Could be drum belt, drum rollers, or motor.
Mar 17, 2010 | Whirlpool Dryers
Dryer fails to get hot
Failed element most likely, particularly if the machine has had a lot of use. (There's not much in a dryer, beyond a motor / fan, belt, drum, timer and the heating element). A simple resistance check across the element will prove the failure of the element.
Mar 16, 2010 | Dryers
We just bought this dryer and after drying a load I touched the top of the dryer and it was incredibly hot? is this normal?
Check your vent it may be stopped up this will cause the top to get overly hot and the bearing to squeak
May 31, 2009 | Frigidaire GLER341A Electric Dryer
Replaced element and now dryer too hot - vent is clear
Hi, Check the element again. It sounds like the element has relaxed and shorted out against the metal housing. The squeak might be the rear bearing cup. You can check and see if it needs grease while you have the drum out.
I hope this helps you. Please let me know.
Thanks
Vic
May 30, 2009 | Frigidaire GLER341A Electric Dryer
GE Prodigy Electric Dryer not getting hot
The exhaust hose in the back will not affect whether the dryer will heat. The hose just removes the used hot air to a place outside your house. I assume dryer drum spins, but you get no heat. If the dryer has gotten a few years of use, I suspect that the heating element has gone bad. Have you noticed that it has taken longer and longer to dry clothes than it used to? If so, most probably the element is bad. The element is not unlike a heating element in an electric stove, and is housed in a duct inside the dryer.
Mar 10, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
126 people viewed this question
Top Dryers Experts
