Question about RCA D61W20 61" Rear Projection Television
RCA D52W23 breakdown in projection focus
I have a RCA D52W23, chassis model ITC222......I was watching tv, everything was fine....then all of the sudden the 3 color projectors seem to have lost their focus to one another, and it was still trying to display my picture, except each color was its own seperate picture, and the picture seemed to "bow" towards the center of the screen from the top and bottom.
When i say lost focus, the best way i can describe it is like in the old "3D" picture books where you needed the red/green glasses to see the picture, but when you look at the picture without the special glasses you can see the image drawn in green, and then next 2 it, the image is drawn in yellow? Same type of look, except for all 3 colors, and the inward box of the picture from top and bottom.
Now...it started out this way, so i took apart the tv, checked to any type of damaged parts (didnt go as far as individual component testing), but i could find anything that looked wrong, fuses were good, etc....so put it back together, tried it again....same problem, but this time after about 15 minutes of messing with the settings (hoping somehow it would fix it)....the TV totally died, when you power it on, the power light comes on for about 5 seconds, then screen never lights off, then the unit shuts itself down.
This seems to be a flyback transformer issue to me, based on what i've read for others, but i'm hoping for some insight before i order a part....it could be the convergance board as well....but if it was, i'd assume the tv would still stay powered on, just no screen.....i learn to the transformer because the symptoms seem like theflyback started to die....and wasnt delivering the proper voltage, thus my weird display, then finally went out for good.
Any insight would be great, thanks!
  • artic429 Jan 03, 2009
    I have the same problem. I heard about 3 red fuses triangle shaped near the flyback...? I want to try to fix this myself too so i can watch football today!
  • RCA Master
  • 5,138 Answers
First check capacitors cp150 2200uf 16v and cp114,cp120 220uf 35v If cp150 is puffed up on top it is bad , then there is a fuse FL231 on right side of flyback transfomer it will be the middle fuse if open you will lose convergence on picture .
Posted on Feb 10, 2009
RCA TV Model D52W23 when turning on light blinks and does not turn the tv on?
Look if have not done so at flyback to see if broken solder connections around it.
May 02, 2012 | Televison & Video
Do you know the code to overwrite or adjust my d52w23 model type tv?
Thats the ITC222 rear projection you can change settings and defaults via of the internal service menu. But its not advisable to do so unless you have the information which lets you know how and what to adjust as some settings can prevent the set from powering up or operating normally unless they are restored to the default settings. I suggest getting the manual which explains the proceedures. You can get one at the following link its the ITC222 Convergence and Geometry CD its available by download link.
http://www.tvrepairworld.com/instructional_cds
Apr 28, 2011 | RCA D52W23 52" HDTV CRT TV
Conversion missing from setup menu
The RCA repair called the ITC222 convergence option missing repair kit available from www.tvrepairworld.com will usually repair that issue. The kit contains the parts and the CD with instructions.
Aug 15, 2010 | RCA D52W23 52" HDTV CRT TV
My RCA D52W23 has 3 colors split.
Thats a convergence failure. You can get a repair kit called " The ITC222 and ITC222A convergence option missing repair kit" From www.tvrepairworld.com which should solve the issue. The kit also contains the CD with instructions.
Apr 02, 2010 | RCA D52W23 52" HDTV CRT TV
We have a RCA D52w23 rear projection tv that powers off.
most likley the deflection board is at issue. Thats the number one board which fails in that chassis.
Mar 15, 2010 | RCA D52W23 52" HDTV CRT TV
I have a rca d52w23x39 i need a replacement screen or something that would work
www.tvrepairworld.com has the replacement screens for the ITC222 series rear projection whuch is what your model number is.
Mar 03, 2010 | RCA D52W23 52" HDTV CRT TV
I WANT TO CONVERGE MY RCA REAR PROJECTION TV. HOW?
Here is a link to the detailed instructions for the RCA ITC222 convergence adjustment proceedure CD with detailed photos.
http://servicemanuals.vstore.ca/product_info.php/pName/itc222-convergence-and-geometry-adjustment-cd/cName/rca
Jun 14, 2009 | RCA D52W23 52" HDTV CRT TV
I have a 53inch RCA big screen tv, we have double vision
Is the convergence adjustment option still listed on the on screen menu or has it disappeared? Thats a very easy chassis to repair so let me know if the option has disappeared or not and I can asssist you with how to fix it.
TV shuts off on its own and wont come back on until unpluged.
On the Deflection board CK 3 capacitors cp150,cp114,cp120 If cp150 is puffed up on top it is bad 2200uf 16v /other 2 caps are 220uf 35v.Also resolder all pinns on FBT
Jan 13, 2009 | RCA D52W23 52" HDTV CRT TV
RCA D61W20 61" Rear Projection Television Logo
306 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
