Acer pc and lg monitor blank screen says power save mode on start up, anyone know how to fix this?
  • 3,267 Answers
Actually during start-up there is a slight delay before the HDD & OS is detected by the CPU. Normally all monitors slip into power saving mode within 10 secs of inactivity of either mouse or keystroke. This inactivity is read by the monitor which promptly switches to power saving mode. However the moment the HDD LED starts blinking, the monitor wakes up & starts displaying. This power saving mode in most of the flat screens is only associated with movement of mouse or keypad. This does not register till the CPU starts up & thats why the monitor switches over to power saving mode till it starts receiving signal from the CPU.
It is a normal behaveour, so don't get worked up over it, plus you can always hit the Auto set feature on the monitor after booting the PC completely. ( I think the time out for the monitor to enter power saving mode is only 10 secs). Hope this helps.
Posted on Oct 10, 2012
SOURCE:
  • 38 Answers
SOURCE: "analog power save mode"
different monitors have different settings. Anyhow, press the menu button on your monitor (hope it is there otherwise some other button must have been assigned this function). Choose recall or auto adjust or factory default from there (whichever of these options you can see). Nothing serious.....
Posted on Oct 01, 2007
SOURCE: LG Flatron LCD Power Saving Mode
Hi, September 2008 and still problems happening with the LG screens. Mine is a Flatron W1942T.
I hit the screen as suggested (my old mum was a great believer in " if it won't work kick it", this applied to anything electrical, tele, vacuum cleaner etc.,) and guess what? my old mum was right. The screen came on.
Hope this works if it happens again. I'd turned everything off because of an electrical/thunder storm. Won't do that again.
Joan
Posted on Sep 14, 2008
SOURCE: Dell E177FP monitor won't turn off in power saving mode
I had the same problem and I went to the first button on the monitor to the left(main menu) then with the button to the right (-) I scrolled down to factory reset. I also did the osd setting and I'm not sure what fixed it, but I havn't had the problem sence.
Posted on Feb 28, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Dell Monitor in Power Save mode
Hello there:
i would refer to your users manual to see if there is a power save mode setting on the monitor it'self and to see how to adjust it or contact the manufacture of the monitor . ok ?
hope that this is helpful
Posted on Aug 06, 2009
  • 65 Answers
SOURCE: computer screen goes into "digital power saving mode"
You should be able to adjust the settings on the monitor to prevent it from going into power save mode, or at least to delay how long it takes before it goes into power save mode. Press the menu button and look for settings that might disable or change power save mode.
Also, does your desktop/PC display show anything before the monitor goes into power save mode? If nothing comes up, its possible that you have a loose VGA connection or that your video card/motherboard are defective in some ways. Try using a different monitor.
If the other monitor works fine with your computer, try changing/lowering the screen resolution. If in XP right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution. If in Vista/Win7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there. Then check and see if your newer monitor works on it.
If the other monitor also doesn't show any display, most likely the problem is either with your video cable or your PC's video card/motherboard, not the monitor.
Hope that helps. Good luck
Posted on Feb 16, 2010
Computer screen goes into "digital power saving mode"
Feb 15, 2010 | LG L1915S 19" LCD Monitor
Monitor automatically clicks into power saving mode
Laptops often have a function key which switches from laptop only, external monitor only, laptop & external. One of the top number keys, along with the function (fn for short) must be pressed simultaneously to step through these.
Where these keys are at, may differ from laptop to laptop.
Nov 28, 2007 | LG L1915S 19" LCD Monitor
LG LCD Monitor L1530S problems
Most screens will show nothing or go to power saving mode until the PC is turned on. The monitors need a signal in order to be 'active'.
From your description it could just as well be a problem with the PC rather than the monitor. The easiest way to find out is to connect another PC or laptop to the screen or connect another monitor to the PC unit.
Did you try pressing the Del key or F2 key when you turn on the unit to get into the Bios?
Jules
Jul 16, 2009 | LG L1530S 15" LCD Monitor
Blank screen problem
hi,
1.Please keep pressing and releasing F8 key when ACER logo is coming.
2.start the computer in safe mode by selecting it in advanced OS choice menu.
3.If started in safe mode go to programs>accessories>system tools>system restore and restore the system to a back date by selecting a bold previous date in calender.
Idf not booting in safe mode also you may need to reinstall the OS again.
Jul 06, 2009 | Acer Aspire One PC Notebook
LG W1952T LCD monitor power save mode during bootup?
called customer service - see other post for details
May 11, 2009 | LG L1915S 19" LCD Monitor
Flatron L1953S Goes to power saving mode while playing..
I had the same problem with my LG Flatron (not the same model as your one). I fixed it by connecting both the digital and analogue cables from the pc. Presumably, the problem occurs because the monitor is not receiving a digital signal.
Mar 18, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
External monitor says laptop is in power save mode and goes blank
hey jkep
this has nothing to do with power, here is what to do
right click your desktop->
properties->
click the settings tab->
click the advance button->
click the display tab->
depending on your graphic card there should be 2 or 3 different monitors being displayed switch them on and automatically your TV will turn on then you can change the settings to your likings
Feb 13, 2009 | Acer Aspire 5610 Notebook
LG FLatron W2252TQ Not working properley in DIgital mode.
Fixing power problems with your LG Flatron Monitor (LG1753S) ' Just ...
blog.lopau.com/fixing-power-problems-with-your-lg-flatron-monitor-lg1753s/
Fixing power problems with your LG Flatron Monitor (LG1753S) ... So after checking the power isproperly plugged, I shut down my pc again. .... I can start a game and then change the resolution, Popp of "energy saving mode digital" led goes ..
Mar 21, 2017 | Computers & Internet
NEW LG monitor to work on emachines PC with adaptor
First of all, most monitors now a days are plug and play. Make sure the monitor is secure on both sides. There is also another connecter like the one attached to the CPU on the monitor, so make sure they're both securly attached. Also make sure you have the connector plugged in the correct monitor port. some computers have 2.
Jul 18, 2008 | E-Machines eMachines Desktop PC
I have an LG W2261V, and an old Sharp LL-T19D1-H. The PC runs both just fine, and the PSU has plenty of power. Unfortunately the LG handles power save mode very differently, where the LG would not switch on after entering this mode unless reset (unplugged, PC rebooted, etc). Extremely frustrating, as the old Sharp never had any problems exiting its own power save mode. The LG would enter this mode based on the monitor power settings (in whatever power scheme you are using) in the screensaver tab in display properties. I fixed this by selecting "Never" for "the Turn off monitor" property. I guess this is a warning to those who may wish to buy a new LG monitor, but want to use a power scheme to turn off the monitor.
Oct 01, 2006 | LG Flatron L1951S 19" LCD Flat Panel...
Computers & Internet Logo
442 people viewed this question
Alun Cox
