Question about NetGear RANGEMAX WNR834M Router (WNR834M100NAS)
Occasionally cannot reconnect to Wireless Network after standby
I cart my IBM Thinkpad Lenova T60 back and forth to/from work and work from home 1/2 the time. Computer stays on most of the time and connects via docking station at work and wireless Netgear RangeMax at home, usually with no problems. Occasionally, like today, the wireless does not connect but when double click the wireless icon in the systray the Choose Wireless Network dialog shows "Not connected" for the Netgear line, but the connect button is greyed out. Doubling clicking on the Netgear line offers me to disconnect, which I do. Then the Netgear line shows Manual and Connect button greyed out, so I double click again and get the Network Key request, click connect and dialog "Waiting for Network comes up but then times out. Another computer right along side the laptop has a wireless connection to the same router with no problems.
I know if I restart the laptop I will be ok, but I have like 80 windows open all the time and closing down takes 1/2 hr. Looking for a way to avoid that agony.
TIA FAH
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Sep 16, 2009
2 Suggested Answers
redhaze89
  • 854 Answers
SOURCE: I cart my IBM Thinkpad
change the wireless security to WEP or WPA-PSK (TKIP)
A. Checking the Wireless Settings of the Router
Note: You need to use a computer hardwired to the router to check the wireless settings.
1. Open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it doesn't take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you can't remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on the Wireless Settings under Setup and take note of the SSID.
5. You may also change the wireless channel here. We suggest channels 1, 6 and 11.
6. At the bottom of the page, look for the Security Options. If in case that the security is set to WEP or WPA-PSK, we have to enter the same wireless security on all wireless PCs. To make sure of the key, we can try modifying the security. Please refer to the following:
For WEP: Select Key 1 and enter 10 hexadecimal digits (0-9 and A-F) on the empty box beside it. Then, click on Apply.
For WPA-PSK: Enter an alphanumeric key (minimum of 8 characters) on the Passphrase box and click on Apply.
Note: The Key and Passphrase are case-sensitive.
7. On the left pane, please scroll down and click on Wireless Settings under Advanced. Please make sure that the boxes for Enable Wireless Router Radio and Enable SSID Broadcast are checked.
8. Click on the Setup Access List button and uncheck the box Turn Access Control On.
9. Click the Apply button.
B. Connecting to the Wireless Network
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
5. Select your network and click on Connect.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
For Windows Vista:
1. Click Start then select Connect To.
2. Connect to a network window will show up.
3. Select your wireless network and click Connect.
4. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
Posted on Aug 16, 2009
Ibm lenovo t60 ethernet not working
Did you reboot the machine? Did you reboot the wireless device? Try this procedure: http://compnetworking.about.com/cs/windowsnetworkin1/ht/renewipaddrwxp.htm
Dec 12, 2012 | Lenovo Thinkpad T60 Notebook
I am unable to connect to a wireless network on my ibm thinkpad T60 pc
First is there a security code to connect to your wireless access point? This is YOUR home wireless? Is your wireless adapter enabled, and working properly on the laptop? Reboot the wireless access point by removing th AC plug and wait 30 seconds,plug in, wait for the device to self-test. Cold-start your laptop, unplug. remove battery, plug in, reboot. If that fails go to IBM/ Lonovo website and update driver for wireless adapter.And all other deivers as needed.
Nov 16, 2012 | IBM Lenovo ThinkPad T60
I cannot connect to a wireless network on my pc
Goto your network adapter control panel, right click on Wireless Network Adapter, choose properties.
On New Windows "Wireless Network Connection Properties" click Configure Button, than check option that look like "Let Windows Configure This Device", Click Apply, and try to reconnect to your Wifi Network again !
Nov 16, 2012 | IBM ThinkPad T60 Notebook
Laptop mouse problem
This is a common problem with laptops, unfortunately, there is no real solution of fixing the touch pad.
The best solution is to use an external usb mouse.
I recomend an optical mouse, they cost about 5 US dollars.
Dec 29, 2009 | IBM ThinkPad T60 Notebook
I upgraded my thinkpad t60 to vista and cant get the net, device manager shows 'unknown device' help me
Download drivers as follows and remember which folder they were d/l to:
1. Intel PRO/Wireless 2200bg, 2915abg, 3945bg, 3945abg, 4965ag, 4965agn Mini PCI adapter
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-70505
2. ThinkPad 802.11a/b/g, 802.11b/g Wireless LAN Mini PCI Adapter
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-67351
Right click on the device and follow the prompts to "update the driver"...Enjoy ...
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-62928
Dec 25, 2009 | IBM ThinkPad T60 Notebook
Drivers for Network controller, Video controller, Wireless
Please visit IBM website and you can see the driver files in that site
Apr 04, 2009 | IBM ThinkPad T60 Notebook
IBM ThinkPad T60. No sound & internal wireless modem is dead
Sounds like you need to reinstall the sound driver, the should be located on your computer, or you can download then from IBM's website
XP drivers: http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-62855
Vista: http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-67218
Hope this helps, if so please rate accordingly.
Thanks,
David
Mar 12, 2009 | IBM ThinkPad T60 Notebook
I cart my IBM Thinkpad Lenova T60 back and forth to/from work and work from home 1/2 the time. Computer stays on most of the time and connects via docking station at work and wireless Netgear RangeMax at...
For Windows Vista:
Dec 30, 2008 | NetGear RANGEMAX WNR834M Router...
NetGear RANGEMAX WNR834M Router (WNR834M100NAS) Logo
509 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Brian Sullivan
Brian Sullivan
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
