Question about Yamaha Electric Guitar
I have just purchased a Yamaha EG012 and a Yamaha GA-15 Amplifier. I've followed the instructions adn plugged everything in, but when i turn on the amp and adjust the volumes there is just a buzzing noise from the amp and the guitar doesn't become electric
  • 3 Answers
It's a bit worrying that there is a buzzing noise from the amp - you might want to get it checked out to make sure you're not in danger of electrocuting yourself.
If you're sure the amp is safe try turning the volume up half way and dabbing your finger on the end of the lead, you should hear a change in the hum or it'll disappear altogether. If it does change or go, your lead is OK and the fault must be with the guitar. I'd suspect the lead first though - apart from the humming that you mention.
Posted on Jan 15, 2009
    Scholar:
  • 79 Answers
You may have a switch with 2 settings somewhere on your amp - one for active and one for passive. try changing that.
If this doesn't work, make sure you got the guitar in the line input, change the lead for another incase it's faulty, turn the volume up on the guitar to activate the pickups, and rock-out when you find the problem and fix it.
Posted on Dec 30, 2008
How can I plug an amplifier into a Yamaha Digital P-95 piano?
Get an AUDIO to STEREO adapter from best buy, radio shack, etc. for a low price then use an audio cable from the stereo jack to the amplifier.
Sep 05, 2014 | Yamaha P-95 P95 DIGITAL PIANO BLACK
Muffled Sound From Speakers.
Please illuminate me explaining the word "Muffled" means and i will be glad to help you out...
Feb 10, 2013 | JBL *new* Jbl Jrx115 15" 2-way Speaker...
Hey I recently purchased a Roland TD-4 and i have no idea how to hook up an amplifier to it. My friend gave me a little amp, and i've tried many ports and cannot get it to play outloud. I'd like it...
First plug a set of headphones into the Left audio out and see if you get any sound from there... NOTE: it will only be in the left headset and this is normal. Turn up volume control... note the level will be low as this is a line output, not headset. This is a test to see if there is audio.
Sep 02, 2011 | Roland A: TD-4 Electronic Drum Set Pads,...
Is there a fuse in this amp? is it replaceable without soldering?
Hi, blowing a fuse in an amplifier is a problem that most guitarists face at one time or another. If an amp won't turn on, or it turns on for a second, then makes a popping sound and turns off, the problem is usually a blown fuse. Though a blown fuse can be a hassle, especially during a performance, it does not have to put a stop to your musical enjoyment. With a spare fuse you can be back jamming to your favorite tunes in no time flat.
Things You'll Need
Fuse.
Instructions
Turn off the amplifier and unplug it from the wall.
Locate the fuse, which is usually found at the back of the amp. The fuse will look like a small black wheel sticking out of the amp with a number and the letter V next to it. For example, 9V.
Gently turn the fuse counter-clockwise to remove it from the amp.
Discard the old fuse.
Insert the new fuse into the empty fuse slot and turn it clockwise until it is firmly in place.
Plug in the amplifier; make sure the power switch is in the off position.
Turn the amplifier on to make sure the new fuse is working properly.
Hope it helped..
Jun 14, 2011 | Crate FlexWave FW15 Guitar Amp Combo, 15...
I've had my Clavinova for over 15 years now and the sound is becoming distorted. Is this an inevitable problem or is there some simple maintenance needed?
The Clavinovas are maintainable. Since you have not described the distortion we can't give much help. If there is difference between notes on the keyboard, the contacts may be getting dirty. If the audio is distorted for everything, the amplifier or speakers may need maintenance.
Mar 28, 2011 | Yamaha Music
I have a YAMAHA GA 24/12 mixer and 10 aux (all) no
Check that you have the gains INTO the aux channel from each strip you want routed there turned up... AND... the gains OUT of the aux turned up. Two places to adjust the gains.
The AUX LIKELY use TRS balanced outputs... check that you are using those.
These are a starting point, I do not have a manual for this device.
Feb 11, 2010 | Yamaha Music
Line 6 spider III 15 watt sound problems
Hi there. Sounds like the power amp IC is shorted. Must replace.
Paul
Jul 04, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Amp turns on but no sound even with diff guitars and cords
Hi Dan
I wish I could just say what to fix, but you can not do this at home. Line 6 is a great amp and worth the time taking it down to the music shop , to be looked at an give you a repair estimate. good luck keep on rocking in the free world. DFD
Apr 12, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
How to change speaker yamaha keybord
Simply put, the speakers can't be changed on Yamaha keyboards. If you have blown the speakers then put the sound through an amplifier or HIFI speaker system - but you must be able to have an AUX cable and AUX on the HIFI for this to work. Sometimes it can also work by use of composite cabling too, depends really on what audio equipment you have.
Apr 02, 2009 | Yamaha YPT400 61 Key Portable Keyboard...
Electric Guitar wont play through Amp
the buzzing is indicative of an open ground connection, check the cord by substitution or with an ohm meter, if the cord is good look at the connections to the jack inside the amp ( im guessing you built the amp from a kit). Is this a solid state amplifier? Tube amps have lethal votages and should not be experimented on without knowledge of electronic safety. Also if there is more than one input to the amp try plugging the guitar into another one and see if its still the same.
Dec 30, 2008 | Yamaha Electric Guitar
Yamaha Electric Guitar Logo
333 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
