Question about Sony Dvcam DCR-HC15E Mini DV Digital Camcorder
Promblem with sony
IiIhave downloaded that file and it installed on my computer (Vista) i then had to buy a ilink goit thta but still having problems it does not pick up that it is plugged in i go to add hareware and still nothing my camera is sony handycam dcr-hc15e
  • Anonymous Apr 03, 2009
    vista can't find HC15E connected by i-link
I have a sony vaio cr590 with iLink port and DV Camcorder sony HC15E and I cant recieve any signal by Click to disc Software, Please Help me.
Posted on Jan 24, 2009
I cant download my DCR-TRV250 Digital 8 videos to my computer. I tryed on Win 7 and Win XP, with or without Sony drivers... But no computers recognize my cam. Also I looked for help on Sony eSupport, but...
From the Sony support page for this camera, it has the following:
  • Drivers:
    • The drivers needed to connect your Sony camcorder to a computer and transfer files are already included in the operating system.
  • Not Supported:
    • The USB streaming feature is not supported with the Windows 7 operating system.
    • The Windows 7 Starter edition is not supported.
From the user manual page 184, they explain how to connect a iLink (IEEE 1394) cable from the camcorder to your computer. Since "USB streaming feature is not supported with Windows 7" as stated above, you now how to retrieve your video using the iLink connection instead.
Unfortunately, the camera does not come with an iLink cable, so you have to buy one. Additionally unfortunate is the fact that many computers do not have a IEEE 1394 connector to use with the iLink cable. As a result, you have to buy an adapter card for your desktop computer or hope that your laptop has a built-in IEEE 1394 port.
Once you get the iLink to IEEE 1394 issue resolved, you can then use the software provided by Sony or any DV capture software to download high quality copies of the video from your DCR-TRV250.
Dec 30, 2010 | Sony Handycam DCR-TRV250 Digital Camcorder
Cant instal drivers
usb streaming function is not readily supported by windows vista. this would depend on the software that came supplied with the camcorder. unfortunately, the software being incompatible and the funtion (usb streaming) not supported by driver included in the supplied cd-rom, usb connection will not work (although you can use it for still picture transfer). for tape transfer you would need to go another route which is ieee1394 (ilink or firewire) connection. it should be a plug-and-play connection. your computer should support and have a working ieee1394 (ilink or firewire) card installed. a compatible ilink cable for both devices and a video capturing software like windows moviemaker and having all the needed hardware and software then your good to go. hope this helps.thanks:)
May 29, 2010 | Sony Handycam DCR-PC330E Mini DV Digital...
I have a Sony Handycam TRV325E. I've lost the
if your computer is running windows vista or 7.forget the software.if you have win xp i don't think it's economical to buy the disc.why don't you just download the usb driver from this website:
http://www.sonydigital-link.com/dime/camcorders/sd/d8/d8.aspx?site=odw_en_GB&m=DCR-TRV325E
with the driver installed you can get the PC communicate with the camcorder so you can get your pictures from a memory stick to import to your PC. now with videos, that would have to go a different route and you don't need the software for that.the video import would have to go through the dv (ilink or ieee1394) out jack from the camcorder to an ieee1394 port in your PC.your computer should have the required ieee1394 card installed and enabled.if you do it should then be a plug-and-play connection.all you would need is a compatible dv cable compatible with both cam and PC and a video capturing application like windows moviemaker to import your files of the tape.see p.209 of manual fig.59. hope this helps.thanks:)
Apr 09, 2010 | Sony Video Cameras
I have windows vista and i cant install the usb driver and pixela programs for this handycam please help me.
the usb driver and pixela application is not compatible with windows vista. usb streaming is not supported by windows vista and 7 OS. however it would still be possible to transfer videos from your dv camcorder using the dv interface (ieee1394 or ilink) connection. you would need to have an ilink (ieee1394) card installed in your computer. you can check by going to device manager window. if you don't, try checking with your PC manufacturer recommendations for an ieee1394 chipset or card.if you do, all you need is an ilink cable (btw, the cam uses 4pin jack).get the correct cable for use with the PC and camcorder, and use windows moviemaker for your video capturing software.hope this helps.thanks :)
also, here's the support site for your unit:
http://support.sony-europe.com/dime/camcorders/dv/dv.aspx?site=odw_en_GB&m=DCR-PC101E
Mar 31, 2010 | Sony Handycam DCR-PC101E Mini DV Digital...
Sony Handycam DCR-HC42 Mini DV not recognized by Windows 7
win vista and win 7doesn't support usb streaming. the usb driver for this model would not be compatible with your computer's OS. although, you were able to download PMB still this wouldn't work, it's basically an alternative software that you can use with the newer OS. still the device driver would not be installed. and you would get a message that "ilink connection is not detected". the reason you get that is bec the camcorder and the software is intended for use with the dv (ilink or ieee1394) connection. so if your computer has an ieee1394 card and you have a compatible ilink cable,then your good to go,it should be a plug-and-play connection (no drivers required). all you need then would be a video capturing software (like win moviemaker) to transfer videos from tape to PC. hope this helps. thanks :)
Mar 28, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
Failure to connect my dcr-trv265e sony cam in windows vista
You need iLink (firewire/ IEEE1394/ DV) cable to transfer movei files from DCR-TRV265E to PC and PC should have DV port to plug-in.
USB cable will not give you such facility.
You can see iLINK cable here.
Jan 03, 2009 | E.Digital Sony DCR-TRV265E camcorder Pal
Having trouble downloading my sony dcr-trv250 camcorder to my computer
I PRESSUME YOUR PC IS WINDOWS VISTA CAN ONLY BE DONE WITH ILINK CABLE THE CAMERA HAS NO HARDWARE COMPATIBLE FOR VISTA
Dec 15, 2008 | Sony Handycam DCR-TRV250 Digital Camcorder
Unable to use firewire Sony handycam DCR-HC 54E (mini DV)
Anyone try this on Windows XP? Apparently firewire doesn't work with Vista.
Dec 10, 2008 | Video Cameras
Sony handycam dcr-hc53
I think you are using Windows Vista and facing problem to connect Sony DCR-HC53
Download Update for Picture Motion Browser software at Sony Support.
You need iLINK cable to transfer movie data in to computer. iLINK cable is shown in below picture.
You can have more info HERE about iLINK connectivity if you are running Windows XP in your laptop.
Oct 23, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Sony Dvcam DCR-HC15E Mini DV Digital Camcorder Logo
121 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
