Question about HP Photosmart C6180 All-In-One InkJet Printer
Jamming paper I printed labels and a small piece of adhesive paper from label sheet must be on roller as it jams my docs and can see it missing from the label sheet. Now when printing, paper jams and sometimes makes a terrible sound. I can remove the paper from the back but it still jams intermittently, producing a document crumpled on one side when it does print. It jams more when you fill paper tray 1/2 way or more. Do I dare remove screws myself and try to clean? How do I clean the rollers after unassembling? Could there be damage to something else having to remove jams by pulling so often?
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 29, 2009
How do I align the HP Laserjet 1020 to print straight? Its printing crooked every time. No two sheets are in the same position
Most likely to be a page feed problem, look online to clean page feeder rubber rollers.
Try here for the pdf manual which covers problem with jams and skewing
http://www.hp.com/ctg/Manual/c00264334.pdf
Mar 05, 2015 | HP LaserJet 1020 Printer
How to print labels?
It is recommended that the bypass (paper) tray be used for labels.
Place the sheets into the bypass with the labels side down.
Be careful NOT to overload the paper tray.
You have to be careful to use labels that are rated for laser printers, Verify that your labels' adhesive material can tolerate fusing temperature of 200C (392F) for 0.1 second.
Last thing to check is that the sheets don't have any curling (of the labels or of the backing sheet) as this will cause jams in the machine.
Jun 12, 2014 | Xerox Phaser 3635MFP/X Multifunction...
Align paper
This can be the result of a piece of paper (or similar) jammed in the printer - can be very small - and usually pulls the paper to one side. Another reason may be something on the roller (have you printed labels - especially part sheets?). Do you get regular marks on the printed paper?
Oct 07, 2013 | Canon MG5250 Printer
Own three CP3525dn's (purchased new). Two have recently begun jamming [fuser wrap] when printing labels. If it doesn't jam then the paper usually "dog ears" coming out. New fuser did not...
Over time, printing labels builds up a light residue of the adhesive (due to heat pressing) used on the labels in the paper path. A thorough cleaning of all paper path parts with alcohol prep pads, or Glass Plus and quality paper towels, will reduce this gum build up.
You should regularly print standard paper jobs on a laser printer that will be printing labels. Rule of thumb is 4:1 - four sheets of regular paper print for each sheet of labels printed. This helps keep the adhesive cleaned out of the paper path.
Patience and a lot of scrubbing should do the trick, though you may have to install a printer maintenance kit early given the issues noted. Printing labels cuts maintenance kit duration in half, at a minimum.
Jul 06, 2011 | HP CP3525DN Color LaserJet Printer
E260 will not print labels
This printer has capability to print on labels. Here are some tips when printing on labels:
· Use labels designed specifically for laser printers. Check with the manufacturer or vendor to verify that the labels can withstand temperatures up to 210°C (410°F) without sealing, excessive curling, wrinkling, or releasing hazardous emissions.
· Labels can be printed at a higher fusing temperature up to 220°C (428°F) if Label Weight is set to Heavy.
· Select this setting using the Embedded Web Server, or from the printer control panel Paper menu. Label adhesives, face sheet (printable stock), and topcoats can withstand up to 25-psi (172-kPa) pressure without delaminating, oozing around the edges, or releasing hazardous fumes.
· Do not use labels with slick backing material.
· Use full label sheets. Partial sheets may cause labels to peel off during printing, resulting in a jam. Partial sheets also contaminate the printer and the cartridge with adhesive, and could void the printer and cartridge warranties.
· Do not use labels with exposed adhesive.
· Do not print within 1 mm (0.04 in.) of the edge of the label, of the perforations, or between die-cuts of the label.
· Be sure adhesive backing does not reach to the sheet edge. Zone coating of the adhesive at least 1 mm (0.04 in.) away from edges is recommended. Adhesive material contaminates the printer and could void the warranty.
· If zone coating of the adhesive is not possible, remove a 2-mm (0.06-in.) strip on the leading and driver edge, and use a non-oozing adhesive.
· Portrait orientation works best, especially when printing bar codes.
· Use only paper label sheets. Vinyl, pharmacy, and dual-sided labels are not supported.
For further assistance, please contact Lexmark Technical Support.
Mar 04, 2011 | Lexmark E260dn Laser Printer
My Brother MFC-9840CDW keeps jamming every time I print mailing labels. I've had it four 1.5 years with no trouble. The label gets stuck and I have to pull out the toner tray to fetch it. I also...
hello, sounds like there are many possible solutions for you machine, first with paper jamming, are labels going thru manual feed tray, or paper tray, it might be possible that mp feed roller needs cleaning or replacing. if paper tray, simple would be feed roller, clean or replace, if jams continue with normal paper from paper tray, the problem will be front door, i have yet to be able to repair paper jams when front door assembly fails. as far as colors, both drum and toner can cause this problem, if using 3rd party toner, this will also cause some color problems. sorry no real quick fix for this machine, i've tried.
Sep 24, 2010 | Brother MFC-9840CDW Laser Printer
Lexmark T640 won't print on label sheet a SECOND time...
try changing feed rollers. For a quick fix, remove the rubber rollers and flip them inside out. It should work
Jan 28, 2009 | Lexmark T640 Laser Printer
Label sheets won't feed, jam
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
good luck..
Dec 22, 2008 | Lexmark Z845 InkJet Printer
Paper jam error message
I had the same problem, and found that the sheet feeder mechanism was intermittent. The problem seems to be that the lubricating grease inside the mechanism.(white nylon round thing with gears on it) becomes too slippery with age, and stops picking up the activating arm which allows the cam unit to move to kick the top sheet of paper into the rubber feed wheel.
The repair was extremely difficult because it involved taking most of the printer apart to get to the ink pump/sheet feeder mechanism.(white nylon round thing with gears on it). And then I tried quite a few lubricants (including no lubricant at all) but none of these worked reliably. Finally I tried a dab of automotive wheel bearing grease (it feels like glue), and this worked perfectly. I have had no more paper jam errors and no miss-feeds in about 7months of everyday use.
Dec 28, 2007 | Canon PIXMA iP1600 Printer
Labels jamming
Check the entire paper processing path as it sound like either the roller gear is not engaging properly to push the paper out of the top, or the output paper path is somehow blocked, like from a label or something else stuck at the top, the roller gear is damaged, or other obstruction.
Nov 16, 2007 | Konica Minolta magicolor 2300DL Laser...
HP Photosmart C6180 All-In-One InkJet Printer Logo
238 people viewed this question
Ben Johnson
