Question about Sony VAIO PCV-RX470DS PC Desktop
Need power-switch pin-out for Sony VAIO PCV-RX470DS
My old computer, the Sony VAIO PCV-RX470DS, needs a modern mobo and memory. I can install those w/o problem, but I need to understand the power switch pin-out so I can rewire it to the appropriate pins on the new mobo. The switch assembly includes a LED for power on and a LED for HDD running. Power switch is on a small circuit bd marked SWX-66, rev 1.01. The wiring harness is labeled FoxconnCO114 and 1-959-913-21. Any help much appreciated.
    Novelist:
  • 101 Answers
The connector pinout is found on page 54 of the System Reference Manual, which is available in PDF from the Sony Support site at this link:)
javascript:moreinfowindow('http://www.docs.sony.com/reflib/docget.asp?manualid=3124&template_id=1&region_id=1&DL=',600,560,10,10,'Manuals')
Posted on Dec 30, 2008
Is there a current motherboard that will fit in a Sony Vaio pcv-RZ22g case to replace an old Asus P4S533 motherboard?
Desktop computer cases have mountings that suit the majority of motherboards.
You most like need a new switch mode power supply as the existion one won't have the correct power connectors and won't supply enough power.
Jan 22, 2013 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Can I add 1 gig of ram to an old Vaio PCV-RX280DS with Ubuntu Linux installed?
no, i'm sorry the maximum amount of ram the motherboard will recognize is 512 mb, it's not an OS limit it's a MOBO limit
Mar 15, 2012 | Sony VAIO PCV-RX280DS PC Desktop
I have added 256MB memory to my Sony PCV-RX470DS desktop but it still only shows 256MB that was already installed. Do I need to change anything in BIOS or make any kind of hardware change via jumpers or...
You may need to re-seat the memory module.
Shutdown your PC, remove the newly added memory module. and re-plug it back in, this time when you install it make sure you hear a click noise when installing it to ensure its properly installed.
I doubt you need to update the BIOS to support more memory.
Otherwise you may have a dud memory module.
When installing/removing memory ensure you are properly earthed so that you don't zap and kill the memory.
Mar 09, 2011 | Sony VAIO PCV-RX470DS PC Desktop
Won't power up
If there is no power on the cpu then try a different power cable, if that doesn't help then open the side panel of the cpu and refix the psu cables.
Dec 24, 2010 | Sony VAIO PCV-RX470DS PC Desktop
The computer suddenly shut off and will not turn back on. I assume the power supply is shot. The computer was kept on constantly, and was seldom shut down. I have opened up the case and it is extremely...
there are two posibilities...
1 ur power supply is out, to check if ur power supply is OK, check if fan on power supply is running when u switch on the PC, if it works then that's OK
2 - ur motherboard is out, if this is the case ur CPU fan will not work but ur power supply fan will work
to check both u may have to open the PC
Dec 14, 2009 | Sony VAIO PCV-RX470DS PC Desktop
Upgrading from Windows ME too XP
give me your system configuration. for capable for install the xp
Jan 26, 2009 | Sony VAIO PCV-RX470DS PC Desktop
My Sony VAIO PCV-RX470DS won't read a second hard drive
Go to Control Panel, Performance and Maintenance, Administrative Tools, Computer Management.
Under Computer Management, expand Storage->Disk Management. On the results panel,  Right Click the Volume(X:) then click Mark Partition as Active or click Reformat.
Dec 26, 2008 | Sony VAIO PCV-RX470DS PC Desktop
How can I remove the side cover on a Sony Vaio PCV RX470DS?
http://www.retrevo.com/support/Sony-PCV-RX470DS-Desktops-manual/id/751bh234/t/2/ u can find the manual here
Dec 25, 2008 | Sony VAIO Digital Studio PCV-RX550 PC...
Sony VAIO PCV-RX470DS PC Desktop Logo
453 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
