Question about Fuji FinePix A400 Digital Camera
Problem with my camera
I have a big problem with my camera. Whenever I press the snap button to take a picture, the camera shuts off. I can flip through the pic saved on the memory without it shutting off, but anytime I try to take a picture it shuts off. The low battery light flashes almost all the time, I've replaced the batteries many times, it still doesn't work correctly. Please help.
  • 3 Answers
Use panasonic rechargeable batteries... I had the same prob, but after panasonic it works fine...
Posted on Dec 02, 2007
When I push the power button the lense moves in and out several times then the camera just turns off. I tried charging the battery and holding the power button down for 10 sec. but still does the same...
The power button has two purposes explanable;
1. A firm press and hold would shut down the entire device, where would be common feature for the camera to perform a system check to include the lense functionalilty.
2. A gentle press and release of the same power button should capture a snap shot only after the camera has been powered on, by the similar process as pressing firmly the power button
Remember
Pressing firmly the power button would shut down camera completely after a system check if only the camera was on.
Pressing firmly the power button when the camera is off would turn on the device by performing a system check also.
Important note
The camera when powered on would have an indicator light of ready to capture snap shots.
The camera would autoshut down when left on for an extensive duration without capturing snaps.
The instance of such would generate a camera check once more before powering off completely
The lense adds to the cameras feature capabilities of acquiring images. a function of the lense is capture an impressive image where the mechanism of drawing closer to the object is made possible by a moveable lense. The Olympus FE-340 Digital camera is powered by a battery requiring sufficient energy for a snap shot. keep in mind that, the camera can perform without the lense. However, the device is designed to automatically responded whenever the lense is required.
Important note;
1 a solution to the camera is with the source of energy in which instance batter power.
2.Dislogde the entire power area consisting of battery, check for improper installation; reinstall the battery in appropaitely noticing the installation indications of power supply. Cover the battery compartment properly, and charger afterwords.
Caution
1.Charge the battery for the entire duration known of a full charge.
2.Unplug thereafter when the full charge indicator is visible.
3.Try on the device for improvement in situation by taking photo snap shots
Dec 02, 2010 | Olympus FE-340 Digital Camera
Camera switches itself off unless the viewing screen is closed.the camera will still take shots using the viewing lense but will shut off immediately if the screen is opened.
This behavior comes when the camera is confused about whether the flip-screen is snapped into the camera screen out or screen in (for protection). The screen is supposed to turn off automatically when you snap it into the camera-back screen down. But if you flip and twist it in a certain way, the camera gets confused. I'll bet that if you keep your screen out, on the side of the camera, you can take pictures just as well as ever. To fix the problem, flip the screen out with the camera on, then rotate it all the different ways you can which allow you to close it with the face out. One of the orientations will leave the screen on, I believe. At least this procedure is the one I followed on my A610 to fix the same problem.
Mar 30, 2010 | Canon PowerShot A610 Digital Camera
Display screen no longer works while taking pictures
Sounds like they accidentally pressed the DISP or DISPLAY button on the back of the camera. This manually turns the screen on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time with the camera turned on.
Aug 01, 2009 | Canon PowerShot A630 Digital Camera
G1 phone camera doesnt take pictures
As the others said, there are the two settings. I had a similar problem, then realized how it worked. You need to not press very hard while it focuses first. Then you can press all the way down, if you hold it all the way down, it doesn't recognize that you've already passed the first "Focus" pressure point and gone into the second "Capture" pressure point.
Oct 25, 2008 | HTC G1
Camera wont take snap
Because the camera has Mechanical Focus the camera button has 2 Pressures, Holding The first 1/2 of the button press will enable to Mechanical Focus to work, And then once the green dot is shown telling you its in focus, pressing the button all the way down will then take your picture !
Cannon sd 600,self timer How to use the selftimer
1. Make sure the camera is in shooting mode (silhouette of camera)
2. Press Func/Set button
3. Scroll down to Drive Mode icon (usually single square)
4. Use left/right arrow to select 2-sec or 10-sec delay (clock with 2 or 10 next to it)
5. Press Func/Set button
Now whenever you press the shutter button, the camera will delay 2 or 10 seconds before snapping the picture. Remember to set back to single shot (single square) or continuous shooting (three overlaid squares) mode when done.
May 28, 2008 | Canon PowerShot A520 Digital Camera
Red eye button when I try to snap a picture
I believe that's your flash setting. Just press to the left of the Menu/OK button to change the flash setting.
Apr 03, 2008 | Samsung Digimax S630 Digital Camera
Canon Powershot A70
There is a button on the back that can be pressed called Disp. (stands for Display). There are two or three settings it flips through each time you press the button. Press this button a few times to cycle through the choices in each of the playback and camera mode to see if this resolves your issue. Happy snapping...
Nov 23, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
Upside down photos
it is most definatelty the same solution as someone above has stated, its as simple as pressing the 'up' key on your volume button when about to take a picture.
Nov 03, 2007 | Samsung SGH-D900 Cellular Phone
Nothing happens when I press button to snap a picture
its not a great problem. but the thing is
1>>you have been handling it in quite rough manner
2>>the camera must be a very old aged one
3>>must be a faulty piece.
the buttoon has got loose. u wont get charged much for fixing this in service centre. so u its not a big deal to spend few bugs for camera.
Oct 07, 2007 | Canon PowerShot A540 Digital Camera
Fuji FinePix A400 Digital Camera Logo
93 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
