Question about Toshiba 43H70 43" Rear Projection Television
Video Connection Issue
Trying to connect an LG BD300 blu ray player to a Toshiba 43H70 TV via component video connection. When connected the blue and red signals are aligned properly but green is not. I have tried various cables and resolution settings but nothing works. I have connected the BD300 to an alternate TV and it looks great. I also tried just a straight composite video cable to the Toshiba TV and that works as well. I just can't get the component video to work. FYI, my cable box is connected to the Toshiba TV and it has no issues. Any help/suggestions would be appreciated.
  • 4 Answers
Use an HDMI cable! It carries video and sound in high definition which is blu-ray dvd player. Costs about $25.00-40.00.
Posted on Dec 30, 2008
Connecting my new samsung blu-ray player (bd-fm57c) to my toshiba theaterview tv.
I don't think that cord will work. HDMI carries video and audio signals, you might get video but probably no sound. You might as well try anyway though so here goes... The red green and blue plugs are your video and the other red plug and the white plug is for stereo sound. The yellow plug is just a lower quality video plug. So plug in the red blue and green plugs into the component video inputs on the TV then the red and white plugs into the audio inputs. DON'T plug in the yellow plug. If this doesn't work go to your local home theater store and ask for a receiver or switcher that will downscale high def HDMI to component video and stereo audio. You can probably pick up a cheap one for around $100. Good luck!
Mar 29, 2014 | Toshiba 50 Inch Big Screen Flat Tv Theater...
I'm trying to watch a 3d movie in my blue ray 3d
First off is your TV a 3D TV. If it is you should be able to go into the menu setting (or on the remote) and change the display from regular TV to 3D. Then your 3D blu-ray player should recognize it.
Jul 15, 2017 | Televison & Video
How do i connect a Blu-ray player to my TV
It should connect best to the one with blue,green,red and then the two for sound--red and white---This is component hookup.
once connected you select the input via the remote or menu..
The ones with the yellow, white and red are composite (yellow is video and color and red/white are audio---doubt it will work off blue ray unless similar outputs on that.
Mar 19, 2012 | Toshiba 36A60 36" TV
I've connected my new Sony Blue-Ray Disk Player to my RCA F25645 TV via the three (Red, White, Yellow) composite cables but the screen only says "unusable signal" and will not display the Blue...
Hello
There is no RGB connector input at the rear of your RCA tv. There is Video, Audio-L, Audio-R and S-video inputs. You won't get any response from your TV, if you connect the RGB connector to the above said audio video connections. You can connect the Blu-ray player with S-Video connector. After connecting it with specific S-Video cable to your TVs S-Video input and Blu-ray players' S-video output, assaign the input of your TV to S-Video, by going to its Menu, and sufing through it. OK.
Jan 02, 2011 | RCA F25645 25" TV
Hooked it up to a blue ray player, no cable at all, just the blue ray, and i get no sound from the tv, just a picture
To connect the Blu-ray player to the TV, connect the Video OUT of the Blu-ray player to the VIDEO 1, VIDEO 3, VIDEO 4 port on the TV using the "RED/WHITE/YELLOW" Composite cable to get both audio and video. You may also connect the "Component OUT" port of the Blu-ray Player to the VIDEO 5 and VIDEO 6 port on the TV using the (Red/Blue/Green/Red/White) Component cable to get both audio and video from it. If you have any questions on connectivity, you may wish to reply with your query.
Thanks,
Pradeep
Nov 19, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
How do i get my sons dvd player in color. it plays every movie in black and white
Make sure the connection to the TV is correct. Yellow(video) jack from the DVD player will go to yellow jack of the TV, white to white(audioL) and red to red(audioR) for compsite audio/video connection. Red to red, green to green and blue to blue for component connection.
Dec 29, 2009 | Sony DVP-SR200P DVD Player
My menu says dtv Currently unavailable. How do I use the HD feature on my Olevia LT32HV
Do you have a High Definition cable/satellite reciever or a Blu-Ray player? Does your tv have a HDMI input or component or DVi or all of those? Most newer HD components use the HDMI connection. The HDMI connection is a single cable that has both video and digital audio together. The component connection is a connector with three rca jacks that are red, green, and blue. Audio is connected seperately with this connection via red and green rca audio jacks or a digital audio connector. The last is a DVi connector that is found on computers. Some older HD tvs and components use this connection. There are adapters available to turn a DVi connection into a HDMI connection. So if your TV does not have a HDMI connection but your HD reciever does you can use and adapter but you will not have any audio this way without using a seperate connector for the audio.
Sep 16, 2009 | Syntax Olevia LT32HV 32 in. HD-Ready LCD...
I'm a senior citizen and bought a very simple DVD Player by you, but can't get it connected correctly. I am not a stupid person but beginning to feel like one. Please HELP>
This player has the typical composite and component TV connections. If you have an older standard TV, you will need a composite to RF TV adaptor. If you have a newer widescreen HD Television, you should be able to connect the composite or component cables to it directly Composite is the 3 video cable bundle (Red, Green, Blue), and composite is the yellow single connection. Audio connects via the standard white/red connectors. If your TV is newer and supports multiple inputs, make sure you can switch to the input you are connected to via the TV remote! Check your manuals.
Sep 05, 2009 | Sony DVP-SR200P DVD Player
No sound through channels on hdd dvd
If you are taking output from the Red, Green Blue connectors (Component) from your video source and plugging them into your hd dvd recorder, you need a sound channel as well. The S-video carries both audio & video but not in high-definition. Sounds like you've got the 3 channels for your video (RGB-component) connection now you need an audio signal into your HD DVD recorder. That will be 1 fibre connection or 2 cables. Let me know if you get it working & good luck!
Nov 13, 2008 | Wharfedale DVD-M3 DVD Player
HDMI Connection
is the hdmi connected to the tv
Apr 09, 2008 | Sony STR-DG510 Receiver
Toshiba 43H70 43" Rear Projection Television Logo
98 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
