Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Printer will not print black with new cartrige.
I think the print head is clogged how do I find a new one, no one in stafford, VA has one can I order on line.
  • Anonymous Jan 14, 2009
    I own a Multipass 390 which isn't printing correctly. I've replaced the ink cartridges and cleaned it. Black ink comes out faintly and the colors are faint or nonexistent.
  • 2,098 Answers
I don't know if you will find any online, but Canon's customer support center (1-800-828-4040) sells print heads for your model (about $40). Use the phone prompts for supplies and accessories.
Posted on Dec 30, 2008
Printing is not clear some long white lines
This sounds like you are running low on ink, your print heads are clogged or are out of alignment. I would buy a new All-in-One because of the low cost of new ones these days but if you want to make this one work try using the printer software and find clean print heads and/or align print heads. If that doesn't work try new ink. Good Luck!
Jun 06, 2014 | Panasonic KX-MB2010 All-In-One Laser...
Printer is printing with a lot of lines
If the lines you are getting are white then you have clogged print nozzles. Typically the nozzles clog when old ink plugs up some of the nozzles on the print head. These nozzles can't spray ink onto the page and you end up with white lines. You would need to replace the print head but I would recommend you clean off your cap and wiper assembly first. If you don't and there is a bunch of old ink built up, you run the risk of clogging up the new print head and having the same problem.
Nov 04, 2013 | HP Officejet Pro 8600 e-All-in-One Printer
Not printing properly
Print heads need to be cleaned cause they are clogged which is why even replacing the cartridges is not fixing the problem.
If the printhead can't be cleaned then a new printer is in order.
Apr 19, 2010 | Kodak ESP 5 Printer
My kodak 5300 is printing poorly. one line will be normal and the next line will be real light...anything i can do..i have new ink and have tried all that i can think of... thanks
Here is a page for your software drivers and a firmware upgrade.
HOWEVER...This looks like the print head may be clogged. Try a deep clean cycle in the printer menu.
If any ink has been allowed to run out, or the printer has been idle for more than a 6 months, the print head is probably no good. Contact Kodak regarding a new print head.
Apr 19, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
My printer just prints in very light red
You are out of red ink, OR the print head is clogged (but that usually) produces streaky lines more so than light color.
You can try cleaning the print heads:
  1. Open the 3845 desktop assistant c00026601.gif icon on your desktop or start menu
  2. click on utilities or tools
  3. click maintenance
  4. click clean cartidges
  5. follow the on screen instructions
If that doesn't help, you're either out of ink in which case:
  1. Buy a new cartridge (or have yours refilled professionally)
or your print head is clogged beyond repair, in which case:
Happy printing.
Jan 27, 2010 | HP Deskjet 3845 InkJet Printer
My ink levels are fine but print is very faint and lines are missing, it is illegible
Your print head is clogged or damaged. Press the print head into a paper towel. You should get a nice block of black or three stripes of color. If not, try placing print head on paper towels soaked with warm water to get the ink flowing (ink may soak through paper towels, so beware of where you do this). Then try pressing the print head onto dry paper towels as before. If you can't get the ink flowing, you need a new cartridge because the print head is clogged with dried up ink.
Dec 19, 2009 | Lexmark Office Equipment & Supplies
Does not print properly. It leaves white lines across documents.
The print head is clogged.Try unclogging with cleaning tests on maintenance menu.If this not help better think about new printer, because repairing and cost of new print head is profitable.
Nov 09, 2009 | Epson STYLUS CX3900 All-In-One InkJet...
Put in new cartridge for the epson stylus c88+ and they do not print out the ink first black and now yellow. It was working now nothing !!! Help
hi...
Just try to head clean, then print a nozzle pattern if na print out are still the same, i think your head have problem... it called clog.... just use syringe and cleaning solution and pump the panel of head so that the clogging remove in your printer head....
May 08, 2009 | Epson Stylus C88 InkJet Photo Printer
Unable to clean Epson C88 Nozzle
In view of leke0513's lack of interest in this problem, I think we may say it has been "solved by poster".
Mar 25, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson Photo R265 Lines every 2.5 cm
check if those lines matches the positions of the rollers inside the printer - you can see some of them by opening the cover
Dec 24, 2007 | Epson Stylus Photo R340 InkJet Printer
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
130 people viewed this question
old marine
old marine
