Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Problems running macros on vista
I have problem running macros on windows vista, gives me a compile error.do i need to install vb dll file
Am nit now windows vistra Home premium now
Posted on Jan 02, 2009
Can you give an example of compiler using vb?
Dim parameters As New CompilerParameters() Dim results As CompilerResults parameters.GenerateExecutable = True parameters.OutputAssembly = Output results = icc.CompileAssemblyFromSource(parameters, SourceText)
The code above uses the CompilerParameters object to tell the compiler that you want to generate an executable file (as opposed to a DLL) and that you want to output the resulting assembly to disk. The call to CompileAssemblyFromSource is where your assembly gets compiled. This method takes your parameters object and the source code, which is a string. Once you compile your code you can check to see if there were any compilation errors. We use the return value from CompileAssemblyFromSource, which is a CompilerResults object. This object contains an errors collection, which contains any errors that occurred during the compile.
There are other options for compiling, such as compiling from a file. You can also batch compile, which means you can compile multiple files or sources at the same time. Additional information on these classes is available on MSDN Online:
Feb 17, 2011 | Microsoft Visual Basic 6.0 for PC
Error in ms office
Rename and Reinstall the Vbe6.dll File
NOTE: You need your Office CD-ROM to complete this task.
  1. Quit all currently open programs.
  2. Start an MS-DOS prompt in a window by doing one of the following:
    • Microsoft Windows 95 or Windows 98: Click Start, point to Programs, and then click MS-DOS Prompt.
    • Microsoft Windows Millennium Edition (Me): Click Start, point to Programs, point to Accessories, and then click MS-DOS Prompt.
    • Microsoft Windows NT 4.0: Click Start, point to Programs, and then click Command Prompt.
    • Microsoft Windows 2000 or Microsoft Windows XP: Click Start, point to Programs, point to Accessories, and then click Command Prompt.
  3. To change the directory to the location of the Vbe6.dll file, type one of the following (including the quotation marks), and then press ENTER: CD "C:\Program Files\Common Files\Microsoft Shared\Vba\Vba6"-or- CD progra~1\Common~1\Micros~1\Vba\Vba6NOTE: This is the default directory for the Vbe6.dll file. If you installed Microsoft Office into another drive or directory, you must type its path.
  4. To unregister the Vbe6.dll file, type the following.
    In Windows 95, Windows 98, or Windows Me, type: C:\Windows\System\REGSVR32 /U VBE6.DLLIn Windows NT 4.0, Windows 2000, or Windows XP, type: REGSVR32 /U VBE6.DLL-or- C:\Winnt\System32\REGSVR32 /U VBE6.DLLNOTE: This is the default directory for the Windows System directory. If you installed Windows into another directory, you must type its path.
  5. In the MS-DOS prompt window, rename Vbe.dll to Vbe.old by typing the following and then pressing ENTER: rename vbe6.dll vbe6.old
  6. Quit the MS-DOS prompt window. To do this, do one of the following:
    • Type Exit at the command prompt, and then press ENTER. -or-
    • Click Close (the X in the upper-right corner of the window).
  7. Start Microsoft Word.
  8. On the Tools menu, point to Macro, and then click Macros.
    The Windows Installer detects that the Vbe6.dll file is missing on the system, installs the file from the Office CD, and registers it again.
Mar 23, 2010 | Microsoft Office Professional 2007 Full...
Download icuin36.dll. The computer tell me that It can't find this file and I should to get it. Could you please tell me where can I get it? And very often my computer close down some programs because...
David
Try this first Click on the Start Button
Go to Run and click on it
In the Run box type the following:
regsvr32 icuin36.dll
If it is successful it will tell you and the problem should be fixed
If not try this download
http://kromann.info/icu/icuin36.dll
DLL (Dynamic Linked Library) Files:
To download and install a DLL file, you will first need to download the DLL file and register it on your computer.
Steps:
  1. Download the DLL file using the download link on this page and save the file to one of the folders as seen in step 3. .EXE files do not need to be manually registered.
  2. Backup the old version of the DLL file.
  3. Click Start > Run and type in the following command:
Windows 95, 98, or Me:
regsvr32 \windows\system\icuin36.dll
Windows NT or 2000:
regsvr32 \WINNT\system32\icuin36.dll
Windows XP or Vista or Windows 7:
regsvr32 \windows\system32\
icuin36.dll
Oct 14, 2009 | Computers & Internet
Compatibility issues between Compaq Fortran and Vista
hi,
i ill ask u to simply use a xp os, so that u wil not have such a problem occurring again. or partition you hard drive so as to install both xp and vista os.
Sep 20, 2009 | Compaq Visual Fortran Professional Edition...
Cannot use my pictures folder in windows XP, error reads Uxcore.d
Try re-installing uxcore.dll file.
To re-install UXCore.dll
Just follow this repair link (http://www.corruptedfilerepair.com/File-Information/UXCore.dll-Windows-Live-Client-UX-Microsoft-Corporation.asp) and download the file named UXcore.dll
Steps:
1. Download the DLL file from the download link on this page and save the file to one of the folders as seen in step 3. .EXE files do not need to be manually registered.
regsvr32 \windows\system\UXCore.dll
Windows NT or 2000:
regsvr32 \WINNT\system32\UXCore.dll
regsvr32 \windows\system32\UXCore.dll
Download File UXCore.dll
EXE (Executable) Files:
Steps:
1. Download the file to a folder on your computer
2. Scan the .EXE file using an Anti-Virus Scanner.
3. Run the .EXE file by double-clicking the file
ZIP/RAR Archives:
You will need to uncompress the files in the archive using WinRAR or WinZip first.
Nore : Default Location - c:\program files\windows live\installer\uxcore.dll
Jul 17, 2009 | Microsoft Windows XP Home Edition
MSVCR71.DLL NOT FOUND
If the error started appearing soon after you have installed a new application or device driver, then it is possible that the error is occurring due to problems in the installation. To fix the error in this case, uninstall the software you installed and reinstall it.
Many times, errors related to DLL files, such as Msvcr71.dll, occur due to malware infections. Download, install and run Malwarebytes.
Hope this helps.
Jul 09, 2009 | Microsoft Windows XP Home Edition
Windows sidebar stopped working
Here is a solution I found when I was having problems and it worked like a gem..its a problem with two programs running a .dll file:
1. Open a command prompt by being Administrator (Right click on Command Prompt and click Run as Administrator)
2. CD to C:\Program Files\Windows Sidebar ( cd drive letter:\Program Files\Windows Sidebar )
3. Run these commands in this order:
1. regsvr32 -u sbdrop.dll
2. regsvr32 -u wlsrvc.dll
3. regsvr32 atl.dll
4. regsvr32 sbdrop.dll
5. regsvr32 wlsrvc.dll
Then start up the sidebar.
Good luck. If you have any questions let me know.
Apr 02, 2009 | Microsoft Windows Vista Ultimate Edition
I can not install OfficeSuite. I have Windows Vista home Premium. I had downloaded updates all afternoon and it still shows error 1719 Window installer not correctly installed. Help!
Download:Windows Vista Service Pack 1
I tried personally in WIN-XP worked same applies to Vista.
Error Message:
Error 1719. The Windows Installer Service could not be accessed. You may be running in safe mode or Windows Installer may not be correctly installed. Translation:
This message might appear when you’re trying to add or remove a program that installs via a Windows Installer MSI (Microsoft Software Installation) package file. The Windows Installer Service is the standard method for installing and uninstalling software on Windows XP. It keeps track of all of the components that need to be installed for a particular program to run and ensures that any files that are shared by programs are not removed when one of those programs is uninstalled. The Error 1719 is an indication that some Windows Installer Service files are missing or have become damaged. Solution:
The first thing to try is re-registering Windows Installer in the Windows registry. Make sure that no other programs are running and then click Start, Run, type msiexec /unregister in the Open field, and click OK. Next, click Start, Run, type misexec /regserver in the Open field, and click OK. Restart your computer and try installing or uninstalling again.
If you’re still getting the error message, the next step is to try reinstalling the Windows Installer files. In order to do this, you’ll first need to rename the existing files.
First, click Start, Run, and type msiexec /unregister in the Open field, and click OK.
In My Computer, click Search and locate the following three files: msi.dll, msiexec.exe, and msihnd.dll. They are hidden files so you’ll need to select Search Hidden Files And Folders under More Advanced Options. When you’ve found the files, rename them, by removing the .dll and .exe extensions and replacing them with an .old extension(for example msi.dll becomes msi.old).
Once you’ve renamed the files, WinXP will automatically replace them with a new copy from the dllcache (a hidden folder where copies of important system files are kept in case you mistakenly delete or rename critical system files). Restart your computer and try to install or uninstall the program again.
Finally, if neither of the above processes corrects the problem, boot into Safe Mode, and go through the above steps again, first re-registering and then reinstalling.
or
Go through the following links:
http://www.vistax64.com/vista-general/45784-windows-vista-error-1719-help-3.html
Hope this will be helpfull
Please rate me...
Thanks & Regards.
Nandu
Sep 02, 2008 | Computers & Internet
Installing SQL server and VB.NET on VISTA Home Basic
installl SQL SERVER 2005
Vb.net is fine its your sql that will mess things up
BTW visual studio come with an SQL server
Jan 09, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
64 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
