Question about Water Heaters
No instant hot water
Recently my water pipes were ''hammering'' increasingly loudly and for longer periods of time (when the water was off). I searched on the Internet and drained the pipes as recommended. Now, I no longer have instant hot water at any of the faucets in my home.
  • Don Doty Dec 30, 2008
    We have a tanked hot water heater with a Lain Termotech pump which up to this point, provided instant hot water at each faucet until I drained the pipes.
    Scholar:
  • 71 Answers
If you have a tankless hot water heater, you may still need to install an expansion air chamber to stop the "water hammer"; If you have a tanked hot water heater, you will never get instant hot water like with a tankless unit.
Posted on Dec 30, 2008
  • Glenn Snow Dec 30, 2008
    OK, now I understand, you no longer have noise or instant hot water... so, we suspect the heating pump mechanism.. make sure it is powered and turned on, and if so, you must also make sure there is no locked air in the pump system. you must force water through it to bleed out the air, then you should be fixed, assuming to that there are no heating elements in the pump itself to burn out... good luck
Why does the water suddenly runs COLD after many minutes of running hot?
Unless you are using a tankless hot water heater, there is a limited amount of hot water available in the tank. Electric and gas water tanks need time to recover after use, and if you are using heavily, it can exhaust the available supply. That said, there are a couple reasons why you may have less hot water than seems normal. In both electric and gas water heaters, silt can form in the bottom of the tank. This will build up over time and displace water. It also reduces the heating efficiency of gas units. There is a drain valve on the bottom of water heater tanks to allow for purging of this silt periodically, but few ever do it. You could also have, in the case of an electric hot water heater, a bad element or thermostat. Most electric heaters have an upper and lower element and thermostat. If one fails the other will still work, but the water takes longer to get hot and will deplete faster.
Nov 04, 2015 | Water Water Heaters
Noisy water pipes when neighbours use water
Install air chamber to cushion sudden-stop of flowing water.
Water flow coming to sudden stop is called water hammer, and will bang pipes, but also loosen plumbing joints, causing leaks.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#bang
http://waterheatertimer.org/images/Flow-rates-water-hammer-600.jpg
Air chamber has to be vertical, and about 18" long, with cap on top.
By code each Hot and Cold line at each tap will have air chamber located behind the wall. So there are two air chambers at each tap.
In your case, you can probably add air chamber to your Hot and Cold lines and solve problem for both dwellings.
Water hammer is caused because water does not compress like air.
So when long column of water suddenly stops... the whole pipe-full of water comes to sudden halt... and that water could weigh 1-1/2 pounds ... and just like a hammer head moving, the weight of water bangs the pipes to dissipate energy, causing noise.
Apr 21, 2013 | Water Heaters
My Noritz N-0751 M-DV makes a loud vibrating noise when I first turn on the hot water. I was advised to flush the system and did but the noise is still there
This sounds like "water hammer"
You can fix this by adding an arrester to the water line. here is a link to what they look like and how they work http://www.plumbingsupply.com/waterhammerarresters.html
You may want to check you water pressure and see if its over 80 psi.
If so then your regulator needs to be adjusted or replaced. If you home does not have a regulator and the city has upped the pressure then you will need to install one. water hammer will break pipes over time and can damage that nice water heater you have.
Jan 10, 2013 | Noritz Residential Heaters Tankless Water...
How to Fix Hot Water Pipes Hammering/Banging?
Had a similar problem and found that the plumber who had replaced the recirculating pump had removed the plastic pipe hollders. These are spacers used to hol the pipes firmly as they pass through the wood studs. Even with only two spacers missing the hammering sound passed through the whole system. Once new spacers were installed the hammering sound stopped.
Jul 14, 2012 | Water Heaters
I HAVE A 50 GALLON 5YR OLD RICHMOND HOT WATER TANK SOMETIMES YOU TURN ON HOT WATER AND IT RUNS FINE.THEN ALLOF A SUDDEN THE WATER STOPS AND PIPES BANG.WE HAVE 44PSI COMING IN FROM CITY
What you're describing is "water hammer". This problem, left unchecked, can cause big problems for your home's plumbing. Water hammer is result of quickly shutting off the flow of water in your home. The faster the rate of water flowing when it is rapidly shut off can result in very loud banging. The banging is caused by the pipes shaking in the walls, ceilings and any place they aren't secured. This repeated shaking causes soldered and glued joints to weaken and eventually fail. The most common sources for water hammer are toilets and wash machines, but even quickly shutting off a faucet can cause it too.
An short article about water hammer is here. Below is a link to images of products designed to arrest water hammer and associated noise.
Please rate this reply - I hope this helps!
Dec 06, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
I recently had to replace the thermostat in a 1 year old Whirlpool propane water heater. Since then the water heater burners ignite about every hour and run for 20 minutes even when no water is being used....
Hello HI GAS USAGE indicates a LEAK in the hot water supply piping.Is there buried pipes anyware,that could develop a pinhole leak you ca'nt see?Is any faucets dripping at all?That is exxesive run time for a heater in standby mode the new thermo is doing its job.Feel the supply pipe is it always hot?
Aug 27, 2010 | Whirlpool Water Heaters
Size and installation for instant water heater
Ariston gl4.0 should be fine if used inline with your hot water heater. Used alone it will likely run out when dishwasher is filling and you are using sink.To use your existing hot water for backup: 1 connect existing HOT water line to cold (inlet) on ariston, 2 Then HOT (outlet) from ariston to sink and dw. If you want instant hot water at a sink 10 feet away: use 3/8 pex pipe from ariston to sink, so you only have to run off a cupful or 2 before hot water arrives at sink.
Aug 30, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
Bosch Pro tankless water heater overheating
The vent pipe you use is the correct size for the heater.Longer runs require bigger pipe.I also would check to see if the water is getting to hot.
Mar 16, 2009 | Bosch ProTankless GWH 715 ES LP Tankless...
Water Heaters Logo
121 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
