Question about Frigidaire GLER642A Electric Dryer
Zanussi dryer belt sometimes rotates then stops
My zanussi dreyer model tc484w. i put on a new belt it works well when it is working stops then restarts when i rotate drum from inside, then works for a period of time then stops.
belt seem to be installed correctly but can not be sure.
any clue as to what is wrong
many thanks
bill foster
  • 142 Answers
Is the belt tensioner adjusted corretly? and belt on straight?
Posted on Jan 25, 2009
How do I get into the dryer to replace the drum belt?
May I suggest you type "SearsPartsDirect" into your computer search engine, and then type in the model number found on the tag somewhere on the machine.
If they list it, you should find pictures of the machine.
To get to the dryer drive belt, you have to take the whole machine apart.
God bless your efforts.
Oct 03, 2017 | Equator ED 620/W 110V Dryer - White
My 20 year old Zanussi dryer model TD 260 has stopped rotating, but the heat is on. Does this mean the belt has gone and where do I get an engineer to fix this.
More than likely is belt, remove the top cover, and you should see if it is the belt.
If you are in the u/k, then go to---
WWW.SERVICEFORCE.CO.UK
You should be able to arrange for an engineer to visit, or look in yellow pages for local repair company.
Jan 26, 2011 | Zanussi Dryers
Dryer modle Tc7102w/t5c7102s was working ok but drum won't rotate
Theres two things to look at, the brushes on the motor, replaceable and cheap, if they are are healthy then there is one or sometimes two large capacitors, these give the motor the ooomf to get it rotating, these fail which is a common problem with washing machines and dryers, again about £5= on ebay.
Mar 25, 2010 | Zanussi TC7102W Electric Dryer
The drum for our Zanussi TC7103 has stopped spinning
sounds like a new drive belt is required. pull the machine out remove the mains supply!!!!
remove the top and look into the back of the machineif you cant see the belt them remove the back of the machine, it's like a small fan felt from a car it's either come off or disintegrated in which case you'll need a new one.
Nov 09, 2009 | Dryers
The drum on my Zanussi G98302X dryer needs a push to start revolving. It will run for a while but sometimes stops again needing another push. Probably needs lubricating, but how?
I'm not sure of this model or how old it may be, but most dryers have a belt that wraps around the entire drum and is belt driven. Sometimes a worn or stretched belt might "slip". You may be due for a new belt.
Aug 25, 2009 | Zanussi Dryers
Belt work
take the bolts out and put the new belt around the tube then motor and you should be hooked up
Jun 04, 2009 | Zanussi TC7114W Electric Dryer
Replaced my zanussi tc-481w drier belt but it still won't work
Success! I found a clear explanation of the problem I was having and a diagram when someone recommended typing the model number into the Wiki how web site .
Result! Thanks for your help.
David
Nov 18, 2008 | Zanussi TC7114W Electric Dryer
Zanussi TC484W
There may be a capacitor in the motor circuit which has shorted out. The capacitor helps the motor start. If the capacitor is shorted, the motor won't start by itself, but will run fine if urged by hand. Good luck.
Feb 06, 2008 | Zanussi TD4212W Electric Dryer
Frigidaire GLER642A Electric Dryer Logo
151 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
