Question about Pioneer DEH-P3500 CD Player
Rear speakers are not working for deh-p3500mp
Have a pioneer deh-p3500mp and don't know how to change the balance to get the rear speakers to work in my car: they have been wired correctly but I just don't know which buttons to press
  • 27 Answers
How do I reset my pioneer deh-x6500bt car stereo and produce sound from my rear speakers?
a 'reset' of the entire stereo should be able to be accomplished by disconnecting the battery for several minutes: alternately if you remove the faceplate there should be a reset button you would need a pen to press, however you should be able to find the EQ levels and set the balance and fade I think it is so the rear produces sound, if that is not the case, I would check wiring to make sure nothing is loose. I suppose it could only be a software/firmware problem with the stereo itself however, if you have had this happen before and it was fixed without tinkering with the wiring.
Jul 30, 2014 | Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth...
Cant access the fade controls. Rear speakers are not operable without it.
When the rear output setting is "rear s/p:SW", you cannot adjust the front rear spreaker balance. Go to the rear speaker output from function and select "rear sp/full".
Aug 19, 2012 | Pioneer DEH-P7600MP CD Player
Wiring colors ford ranger 1992 &pioneer deh 3900 mp need to know which wires are which thanks
I suggest check this diagram
DEH-3900 Installation Manual -->> DEH_3900MP_CRD4131_installation_manual
1992 Ford Ranger Pickup Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Hope helps.
Oct 03, 2011 | Pioneer DEH-3900MP CD Player
I would like to install a Pioneer DEH-P3800MP stereo system in it and don't know which wires connect to the stereo!
2000 Hyundai Elantra Stereo Wiring Constant 12V+ Light Green Switched 12V+ Brown Ground Black Illumination Dark Green/White Dimmer Dark Green/Black Antenna Left Rear Front Speakers 5 1/4" Doors Left Front (+) Green/Red Left Front (-) Light Green/White Right Front (+) Red/Blue Right Front (-) Light Green/Black Rear Speakers 6" x 9" Rear Deck Left Rear (+) Yellow/White Left Rear (-) Yellow/Blue Right Rear (+) Green Right Rear (-) Green/Blue
Jun 22, 2011 | 2000 Hyundai Elantra
Wiring my pioneer deh -p2000 to my speekers
Check the back of your receiver, to see the plug with a set of 8 wires that should have the following color standard:
Left front: White
Right Front: Grey
Left Rear: Green
Right Rear: Purple
Note: 1) Colored wires with a line/stripe on it is NEGATIVE, thus connect to negative on speaker. When connected, speaker cone should vibrate OUT, not inwards, otherwise reverse speaker connection;
2) You can check to see if speakers are in the right order by 'panning' balance and fader controls (from left front only to right front only, to right rear only, to left rear only in succession)
3)If there is an amplifier in your setup, the RCA plugs (like home audio plugs, should be connected instead, NEVER both!)
Hope this helps
Sep 25, 2009 | Pioneer DEH-P2000 CD Player
Adjusting front and speakers
Push the menu/sel button, select bal/fad. Pioneers use the same adjustment for balance and fade. push side to side for balance, up and down for adjusting front to rear
Aug 18, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
How to ajust speaker front to back
Hello bill_cordova,
Start with the "AUDIO" button. Press it until FAD appears in the display. Press the up/down buttons to adjust front/rear balance. FAD:F15-FAD:R15 is displayed as the front/rear balance is moved from front to rear. FAD:0 is the center position with the balance equal between the front/rear speakers.
Hope this helps. If it does, please rate as "FixYa".
Apr 24, 2009 | Pioneer DEH-P4700MP CD Player
DEH 1700 speaker problem
here is the manual it will tell you all u need to know about this head unit
Sep 24, 2008 | Pioneer DEH-1700 CD Player
No sound out of rear speakers
Depending on your setup. you may have a "bridge" option which allows you to bridge channels. Check each channel with one speaker at a time. also each channel may have individual fuses. Check your channel fuses first, and test each channel with one speaker. GL
Jan 02, 2018 | Pioneer DEH-P77DH CD Player
Pioneer car sttereo without manual. front speakers work but rear speakers silent
Press the audio button (A button in right hand upper corner) till you see FADE or BAL press the up down or left right arrows to adjust the fade and balance till all your speakers work.
If they still dont work, check the wiring at the speaker and the wiring behind the head unit to make sure their properly intact and properly grounded.
Jul 28, 2008 | Pioneer DEH-1600 CD Player
Pioneer DEH-P3500 CD Player Logo
218 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
