Question about Dell OptiPlex GX280 PC Desktop
I need help with instaling a new hd on a dell gx280
    Novelist:
  • 159 Answers
If you take out your old disk, all your data goes with it .. also, the new disk will not come with MS Windows already on it .. you will have to install from Windows CD .. and you will need the License Key (hopefully still to be found stuck on the top or back of the PC)....
The other choice is to 'clone' your old disk to your new disk first .. this transfers all your data across and avoids the need to re-install windows ..
To actually swap the disk over, RTFM .. (see your PC's service manual on the Dell site)
Posted on Mar 17, 2009
  • 4 Answers
Pull off cover. Locate the same hd as the one you are replacing. Label the wires and how they connect into the hd. Green tabs usually need to be depressed and hd should come out or check for screws holding it in. Afterwards turn on pc if it boots up you should be fine if not you will need to install an operating systems. like windows xp or vista.
John
Posted on Dec 30, 2008
5 Suggested Answers
  • 12 Answers
SOURCE: miss match hd on a dell gx280
Hi, I have had lots of experience installing hard drives. You never get exactly 80gb when it is partioned. Some space is utilized for other things that cannot be used. So you aren't doing anything wrong. Just another way companies can make you think your getting more then you really are.
sorose4u
  • 217 Answers
SOURCE: I think my HD went out, so I bought a new one, gx280 compatible
set the SATA OPERATIONS to RAID/AUTODETECT in bios...and then do the reinstallation
you may have to even install the raid drivers which is available on the dell resource cd...when u start setup at one point it gives you an option to press F6 to install third party drivers opt for it and install the raid drivers using resource cd if the first option doesn't help
Posted on Mar 07, 2009
  • 232 Answers
SOURCE: HI, I NEED ALL DRIVERS FOR DELL GX280, MUST BE
try this website :
  • support.dell.com/support/downloads/index.aspx
  • you should be able to have all drivers required for your system .
    Posted on Oct 01, 2009
    Testimonial: "HI,THANKS VERY MUCH FOR YOUR HELP, I WILL START TO DOWNLOAD TOMORROW,BEST REGARDS TO YOU "
    • 425 Answers
    SOURCE: I installed a second SATA HD in the desktop dell
    You need to set up the second drive as a slave, this is done with jumper settings, if you look on the bottom of the hard drive you will see the settings required for the jumper.
    Posted on Nov 21, 2009
    Keyboard & Mouse not inputting..Dell OptiPlex GX280.. OS, XP. Microsoft Wireless Desktop 3000 (keyboard/mouse) new.. Dell boots up and desktop appears, the cursor (arrow head) remains in middle of...
    Check that batteries are charged and installed properly.--make sure driver disc is installed if applicable- check instructions as some wireless suites need you to push a small connect button to initialise them . Also try shifting the usb conector into another USB port if it is notm getting reconised.
    I hope this helps
    Andrew.A
    Apr 09, 2011 | Dell OptiPlex GX280 PC Desktop
    Dell gx280 wont run I installed new video card in pci e slot
    I had exactly the same problem on my friends Dell GX280. It will only let you use the onboard card or the new radeon card not both together. In the end we had to buy a Radeon card that was made specifically for two monitors and disable the onboard card on BIOS. It would not let us use the two seperate cards in unison.
    May 06, 2010 | Dell OptiPlex GX280 PC Desktop
    I installed a second SATA HD in the desktop dell optiplex gx280. I can see it in the configuration screen, but in the Windows the HD can't be seen through the explorer, but system/hardware show it with...
    Nov 21, 2009 | Dell Computers & Internet
    HI, I NEED ALL DRIVERS FOR DELL GX280, MUST BE FREE, JUST INSTALLED, NEW WINDOWS XP 6, CANT GET DELL TO DOWN LOAD THEM. BEST REGARDS
    try this website :
    Oct 01, 2009 | Dell OptiPlex GX280 PC Desktop
    I have a Dell Optiplex Gx280. I recently downloaded some softwares from Dell Drivers & Support Website. I also installed DELL BIOS Software. It asked me to restart my pc and my System never booted...
    can download the software you will not have the correct for OS or video card can driver you need is to update its drivers.
    hopefully you understand it and help you / me to you.thanks to trust you..Good luck
    Jul 20, 2009 | Dell GX280 Optiplex 2.8GHz Desktop...
    CPU Fan Failure on Startup
    if you have tried changing the fan then the problem is with the motherboard & motherboard needs to be replaced.
    Apr 25, 2009 | Dell OptiPlex GX280 PC Desktop
    Mar 07, 2009 | Dell OptiPlex GX280 PC Desktop
    Miss match hd on a dell gx280
    Dec 30, 2008 | Dell OptiPlex GX280 PC Desktop
    Dell OptiPlex GX280 PC Desktop Logo
    57 people viewed this question
    Brian Sullivan
    Brian Sullivan
    mukhtar21 shaikh
    mukhtar21 shaikh
