Question about Cell Phones
MY NOKIA 6600 GETS SWITCHED OFF AUTOMATICALLY AFTER ABOUT 8 HOURS. IT IS 3 YEARS OLD WITH 512MB OF MEMORY CARD.please help
  • 3 Answers
OFF PROBLEM
Posted on Mar 25, 2009
Memory card unformatted nokia micro sd 512mb
my friend good day...the micro sd is not supported for nokia 6600 ,better use memory card which is the big one..thanks
Jun 09, 2010 | Nokia 6600
Farmating mmc card for nokia 6600
TRY TO REFORMAT YOUR MEMORY CARD USING PC THEN REFORMAT YOUR NOKIA 6600 PHONE USING THE HARD RESET CODE.
***NOTE THAT REFORMATTING YOUR SYSTEM WILL LOSS ALL DATAS AND FILES
Mar 20, 2009 | Nokia 6600
Memory card problem
Promblem Regarding Memory Card of 6600 Nokia. ------------------------------------- 1). Format the memory card by the phone using "format" option available in memory card "options".
2). If still same problem appears, then format it through pc-suite software, or through memory card reader which available in market (this process is by using PC).
3). If still same problem appears, then try with a new memory card.
Because it depends on your handset. After inserting a new memory card, if the same problem appears please contact your nearest "NOKIA CARE".
All the Best....
Thanking you.
Mar 02, 2009 | Nokia 6600
6600 sends mms everytime i receive an sms
My friends i suggest you to format your memorary card here are the steps:
Make sure that you format the memory card first so that there is no trace of virus in the phone and remove any password from the memory card.
1. First of all make sure that your phone's battery is full and then switch off you mobile phone.
2. You'll need to hold three buttons together which are : The green button, left selection key and the no. 3 key
3. Keep on holding these three button and then press the power button to switch it on.
4. After this you'll get a screen which will say FORMATTING.... after that you can leave the keys.
Caution : This will completely format your phone memory and will reload the whole phone due to which you'll loose all your contacts or infact anything stored in the phone memory.
I hope this helps you....this step can be taken for any Nokia phone which has Symbian OS Series 60 Version 7 and above...you can say most of the phones which came after Nokia 6600
Feb 11, 2009 | Nokia 6600
Nokia 6600 not starting
Hi there...to fix your problem you have to format your 6600...just simply turn off the phone...and then hold this buttons at the same time Power button,3,*,Call button...be sure press it at the same time...wait until the formatting msa appears after that your phone will work now normally...hope this will help you
Nokia 3110 classic
Solution 4 Nokia 3110c Restart
Those who still have this restarting problem on Nokia 3110c ... Im telling the solution again, step by step.
It ll work . you dont need to go 4 the firmware v5.05
If
ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings from the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now
ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off
ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On
ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Feb 11, 2008 | Nokia 3110 Cellular Phone
Nokia 6600 phone unlock codes
please take the help of some other mobile service centre
Feb 02, 2008 | Nokia 6600
Nokia 6600 - Emergency Help
FLASH IT WITH GREEN KEY * 3
Nov 13, 2007 | Nokia 6600
Regarding Nokia 6600
Remove the memory card then check.if ok.Scan the memory card with appropriate antivirus software. Then format phone using * 3 call button then switch on your mobile
Apr 29, 2007 | Nokia 6600
NOKIA 6600 turns off by itself
try it with the 3key format trick. if your phone shuts off for 30 seconds the UEM is the faulty part.
Feb 17, 2007 | Nokia 6600
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
