Question about HP Pavilion dv4000 Notebook
Need new hard drive for DV4000
Any suggestions for a replacement hard drive for a DV4000? Thanks in advance.
  • 1 more comment
  • twmpywel Dec 30, 2008
    I believe it is the CTO version, but am not entirely sure.
    Thanks very much!
  • dmantek May 11, 2010
    Is this the CTO version or the MV version?
  • 27 Answers
For the DV4000
CTO Version: http://www.notebookparts.com/products/description.php?II=9595
Part#: 383483-001 40GB Hard Drive. I googled part number and found this link. Hope this helps.
If you have the MV version, you will need at least a 60GB hard drive, Part#: 384483-001
Posted on Dec 30, 2008
    Master:
  • 568 Answers
Http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=DV4000&submit=Go+%BB
visit above website and select your model and operating system
Hi,i hav laptop hp pavilion dv4000,i try on it it doesnt boot. i try to load operating system, it doesnt see the hard drive, i put new hard drive, the same thing happen. And the battery went off when the...
- try going to bios and check if the HDD is detected
- if yes, load default bios
- if not detected, go to HP website and see if there's an option how to reset the HDD
- if resetting the HDD did not resolved it, then you need to replace the HDD
Jun 25, 2011 | HP Computers & Internet
Can i replace the the hp pavilion DV4000 SERIES 80GB (4200 RPM) HARD DRIVE with any 7200 rpm notebook hdd?
You should be able to replace it, but you will need an adapter lead from laptop hdd to motherboard as the laptop hdd will be smaller and you may need a kit to fix hdd into 3.5" bay. Both are readily available.
Feb 13, 2011 | HP PAVILION DV4000 SERIES 80GB (4200 RPM)...
The power adapter that plugs into the laptop HP DV4000 is broken, and I can't use the charger. where can I find a new one to replace the broken one, or will I have to buy a whold new charger? thanks
Do you mean only the power cable that linked the power brick with laptop was broken? Of course if you are 100% sure that's the only part that fail, you may only buy a cable. Check this link blow:
http://www.chargerbuy.com/cable-connector/power-cord.html
But if you are not that sure, i'll suggest you buying a whole new charger:
HP Pavilion DV4000 AC Adapter
Aug 03, 2010 | HP Pavilion dv4000 Notebook
Hi, Is the standard hard drive in this notebook a SATA or IDE drive. Part no. is 383486-001. Thanks
It is IDE. 383486-001HP 80GB Ultra ATA/100 EIDE hard drive - 4,200 RPM, 2.5-inch width, 9.5mm height
Hope this helps,www.PuterCare.com
Jul 08, 2010 | HP Pavilion dv4000 Notebook
I don't know the model of internal hard drive for my HP pavillion dv9420us. My system crashed and we have been unable to restore it after performing all HP suggested tests, etc.
Take the computer to any local computer store.
They can remove the disk-drive, identify it, either as "IDE" or "Serial ATA", and sell you a replacement (which need not match the manufacturer or model or size of the original), and will connect it.
Then, you will need to reinstall Windows.
May 07, 2010 | HP Pavilion dv4000 Notebook
I installed a new battery in My HP DV4000 laptop but it won't charge. It's a 8800mah and says 11.1 volts. The old one says 10.8 volts. Any ideas?
this problem happens when the voltage of the battery is slightly less or equal or more than the output voltage of the charger u need a more powerful charger for charging that battery
Mar 31, 2010 | HP PAVILION DV4000 SERIES 30GB (4200 RPM)...
Loud humming noise, then went away. hp told me to remove hard drive then reinstall, now have no bootable device message???
your hard drive has died. replace hard drive and re-install operating system.
hard drives only last up to 5 years. guaranteed to fail eventually.
Nov 26, 2009 | HP Pavilion dv4000 Notebook
HP Pavillion dv4000 is stuck with a 'disk read error'
try with Disk Manager so Format with Low Level Format...run in under DOS
Oct 23, 2009 | HP Computers & Internet
Noisy fan
hi thanks for using fixya!
I suggest, you bring your laptop to a service center to check further and replace the fan.
Regards!
Apr 26, 2009 | HP Pavilion dv4000 Notebook
Hinges too loose on my hp dv4000
You LCD hinge weared and teared too hard. So these is a interstice on your right hinge. You need a new hinge. You can find the hinge on ebay. and below is a replace manual.
h10032.www1.hp.com/ctg/Manual/c00530488.pdf
Jan 31, 2009 | HP Pavilion DV4000 15.4" LCD LEFT AND...
HP Pavilion dv4000 Notebook Logo
90 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
