Question about Canon ImageRunner 2220I Copier
The scanning feature doesn't work
I get the message "Place document on platen glass and press key". Then I get the message "Preparing..."
Then I get the message again "Place document on platen glass and press key."
It won't send the scanned copy to my email.
  • Chris Coughlin
    Chris Coughlin May 11, 2010
    Do you have the scanning software installed on all your computers? Not just the server for printing. If not you need the program installed. Also, what program are you scanning with?
  • andzulisv May 11, 2010
    are you using the send feature or the scan feature it makes a difference
  • 92 Answers
Do a clear all to the machine.first do a backup of the data
Posted on May 10, 2009
    Novelist:
  • 126 Answers
Make sure once you have the software installed properly that you set up the file ( address) correctly. You need to have the designation specified.
Posted on Jan 04, 2009
How to scan using MP145 canon printer
  1. Place a document face-down on the platen glass.
    (Memo)
    Place a scanning side facing down on the platen glass.
    Align a document with the arrow (the alignment mark), which is at the bottom right corner of the platen glass
  2. Launch MP Navigator.
    1. On the Windows desktop, double-click the 'MP Navigator 2.0' icon.
    2. Alternatively, in the Windows taskbar, click 'Start', click '(All) Programs', 'Canon Utilities', 'MP Navigator 2.0' folder, then 'MP Navigator 2.0' icon.
  3. Click 'Scan Photo/Document'.
    The Scan Photo/Document window will be displayed.
Aug 16, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Need instructions on how to send fax, it seem as though we are not following the correct steps
Solution: Sending faxes on an MX310
Sending Faxes
The operation flow of sending faxes is as follows.
  1. Load the original on the platen glass or on the Automatic Document Feeder (ADF).
    Platen Glass
    1. Lift the document cover (1).
    2. Place the original in landscape orientation and align the upper corner of it with the alignment mark (2) as shown in the figure below.
    3. Gently close the document cover.
ADF
  1. Remove any documents from the Platen Glass.
  2. Open the Document Tray.
  3. Load the document in the ADF.
    Load the document with the side you want to copy, scan, or fax facing up in the ADF.
  4. Adjust the Document Guides to match the document width.
  1. Press the button.
  2. Adjust fax settings as necessary.
  3. Start faxing.
    1. Dial the recipient's number using the numeric buttons or coded speed dialing.
    2. Press the button for color sending, or the button for black & white sending.
      Note: Color sending is available only when the recipient's fax machine supports color faxing.
    3. If the document was loaded on the Platen Glass, the following message will appear. Load the next page on the Platen Glass.
    4. If you have only one page of document to scan, go to step 5.
    5. Press the same button as you pressed in step 4b.
    6. Repeat steps 4c through 4e until all pages of the document have been scanned in and then go to step 5.
  4. Press the button.
  5. To cancel sending a fax, press the button. To cancel sending a fax while it is being sent, press the button, then follow the instructions on the LCD.
Adjusting the Scan Contrast or the Image Quality (Fax Resolution)
Contrast is the degree of difference between light and dark. Increasing the scan contrast setting further blackens dark areas and whitens bright areas, whereas decreasing the contrast setting reduces the difference between bright and dark areas. You can adjust the contrast among three contrast levels.
  2. Press the button.
  3. Press the (left) or (right) button to select the contrast.
  4. Pressing the l_mark.jpg (left) button decreases the contrast, and pressing the r_mark.jpg (right) button increases the contrast.
  5. Press the button.
Adjusting the Image Quality (Fax Resolution)
You can adjust the image quality (fax resolution) of the document you send. The higher you set the image quality setting, the better the output quality will be at the other end, but the longer it will take for the transmission. Adjust the image quality according to the type of document you are sending.
  2. Press the button two times.
  3. Press the l_mark.jpg (left) or r_mark.jpg (right) button to select the resolution.
STANDARD:
Suitable for text-only documents.
FINE:
Suitable for fine-print documents.
PHOTO:
Suitable for photographs.
Return to Start Faxing
Back to the Top of the document
Dialing the Coded Speed Dial
  2. Press the numeric buttons to enter the two-digit code (00 - 19) assigned to the number you want to dial.
  3. Press the button for color sending, or the button for black & white sending.
    Note:
    * To cancel sending a fax, press the Stop/Reset button. To cancel sending a fax while it is being sent, press the Stop/Reset button, then follow the instructions on the LCD.
Feb 04, 2011 | Canon PIXMA MX310 All-In-One Printer
How do I scan a picture from the HP J4680 to computer
This is the step on how to scan docs using HP J4680:
    1. Press the "Power" button on the HP J4680 and lift the top cover. Place the document to be scanned on the scanner glass. Be sure the document is face down and properly aligned with the top, left-hand corner of the glass.
    2. Use the arrow keys on the control panel of the HP J4680 to select the "Scan" feature. Press "OK" to continue. Then Press the right arrow to select the scan feature. Press the "Start" button to begin the scan.
Dec 13, 2010 | HP J4680 Office Jet All-In-One Printer
How do you scan?
Open the Applications folder on the hard disk on which MP Navigator is installed, then open the Canon Utilities folder and double-click the navicon.gif MP Navigator 3.0 icon. MP Navigator opens.
2. Point to Scan/Import and click 'Photos/Documents (Platen)'.
3. Place the document face-down on the platen glass, and select 'Document Type'.
How to place the document and Document Type depends on the document to be scanned.
Allow 3/8 inches (1 cm) or more space between the edges of the platen glass and the document.
Align a corner of the document with the corner at the arrow of the platen.
  • When you select Color Photo or Black and White Photo, the position or size of the image may not be scanned correctly if you do not leave 3/8 inches (1 cm) or more space between the edges of the platen glass and the document.
  • When you select Color Photo or Black and White Photo, the position or size of the image may not be scanned correctly depending on the document. In such a case, select Document Size such as A4 or Letter according to the document to be scanned.
  • When you select Magazine(Color), the Descreen function will be enabled and scanning takes longer than usual. To reset the Descreen function, disable Descreen in the Scan Settings dialog box.
4. Click 'Specify'... and set the preferences as required.
The Scan Settings Dialog Box opens. Specify the Document Size and Scanning Resolution.
  • When Document Size is Auto Detect or Auto Detect(Multiple Documents), the position or size of the image may not be scanned correctly depending on the document. In such a case, select Document Size, such as A4 or Letter according to the document to be scanned.
5. Click 'Scan'.
Scanning will begin.
When the document has been scanned, the scanned image is displayed in the Thumbnail List area.
Oct 26, 2010 | Canon MP610 Photo All-In-One Printer
Trying to scan a photo... won't scan
a) try cleaning the glass with windex or vinegar
b) make sure the calibration strip (if there is one) is not covered
c) make sure the cariage is not lkocked (most scanners have a lock fro transport
d) remove and re-install the software
Nov 10, 2009 | Canon Pixma MP480 All-In-One InkJet...
I want to scan documents with my Pixma MP 150
Scanning using the Operation Panel 1. Place the document face-down on the platen glass.
2. Press the [Scan] button on the machine.
MP Navigator starts on the connected computer. You can scan in documents placed on the platen glass using MP Navigator.
Oct 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Just changed all cartridgages and photo quality is still bad
scanning
Spots on a scanned
- Glossy photo (original)
- In the high humidity
environment
When a glossy photo is
strongly pressed on the
platen glass, the photo
will stick to the glass,
and the stuck points are
scanned as spots.
- Do not strongly press
the photo on the platen
glass.
- Clean the platen glass
(to eliminate any
moisture).
- Spots appear on
the scanned
image, though
there is no such
spots on the
original
document.
Oct 13, 2009 | Canon Pixma MP500 All-In-One InkJet...
How do i scan a document?
Place photo on glass platen, then got to START
Start button, Canon Utilities, Solution Menu, Scan/import, photo/platen, then press big green button.
THen have fun scanning it is fantastic
Jan 23, 2009 | Canon PIXMA MP610 InkJet Printer
Scanning on an mp500
First you should have installed the scanner in the computer using the cd comes with the scanner.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
  2. Load paper in the auto sheet feeder or the cassette in the portrait orientation.
  3. Lift the document cover and set a document on the platen glass.
    MEMO:
    - Regardless of the document size, set it in the landscape orientation.
    - Place the copying face down on the platen glass.
    - Align the document with the alignment mark (shown as the arrow) on the lower right corner of the platen glass.
    Note: The machine cannot scan the area approximately 3 mm from the front and right edges of the platen glass.
    < 1 > Alignment Mark
  4. Close the document cover gently.
  5. Confirm that the printer is in Copy mode. If the printer is not in Copy mode, press the <COPY> button to switch into Copy mode.
  6. Check the copy settings, following the procedures below carefully.
    < 1 > Check the paper size and media type.
    < 2 > Use the up / down cursor button to specify the number of copies.
    < 3 > Use the right / left cursor button to adjust the intensity.
    Memo: Pressing the right cursor button increases the intensity. Pressing the left cursor button decreases the intensity.
  7. Press the <Color> button for color copying, or the <Black> button for black & white copying. (The printer starts copying.)
    Note: To cancel copying, press the <Stop/Reset> button.
Apr 02, 2008 | Canon Pixma MP500 All-In-One InkJet...
Setting up fax machine to receive
Receive Mode Setting
On the operation panel, press the following buttons to select the appropriate receive mode.
  1. Press <Fax>.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode set], then press <OK>.
  4. Press the right or left arrow button to select the receive mode that best suits your needs, then press <OK>.
    FAX ONLY MODE: When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only.
    MANUAL MODE: When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually.
    ANS MACHINE MODE: When you want to receive voice messages on your answering machine and receive faxes automatically.
    FAX/TEL AUTO SW: When you want to receive faxes automatically as well as voice calls.
    DRPD: When you have subscribed to a DRPD service with your telephone company.
  5. Press <Stop/Reset> repeatedly to return to fax standby mode.
Sending Methods Sending From Your Machine (Memory Sending)
  1. Load the document on the Platen Glass or the ADF.
    Sending from the platen
    Important: When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
    Sending from the ADF
    *MP830 shown
  2. Press <FAX>.
  3. Adjust the settings for your document as necessary.
  4. Dial the recipient's number using the numeric keys or speed dialing.
  5. Press <Color> for color sending, or <Black> for black & white sending.
    • When the document was loaded on the Platen Glass:
      1. When the following message is displayed, load the next page on the Platen Glass.
        If you have only one sheet to scan, press <OK>..
      2. Press <Color> to send in color, or <Black> to send in black and white.
        IMPORTANT: If you do not press the same button you pressed in step 5, the machine does not start scanning.
      3. Repeat steps 5a and 5b to scan in all pages of the document.
      4. Press <OK>.
    • When the document was loaded in the ADF:
      The machine starts sending automatically after the document is scanned in.
  • To cancel sending before sending a fax, press <Stop/Reset>.
  • To cancel memory sending while sending a fax, follow any instructions on the LCD after pressing <Stop/Reset>.
  • If the document remains in the ADF after pressing <Stop/Reset> during sending a fax, press <OK>. The remaining document is automatically fed out.
Sending From Your Machine (Manual Sending)
Use manual sending when you want to talk to the recipient before sending a document, or if the recipient does not have a fax machine that can receive automatically.
Caution:
  • With manual sending, you cannot use the Platen Glass to send documents.
  • You will need to connect a telephone to your machine if you want to talk to the recipient before sending a document.
Follow this procedure:
  1. Connect a telephone to your machine if you want to talk to the recipient before sending a document
  2. Load the document in the ADF.
  3. Press <FAX>.
  4. Adjust the settings for your document as necessary.
  5. You can lift the handset if one is connected to the machine.
  6. Dial the recipient's number using the numeric keys or coded speed dialing.
  7. Talk through the handset to the recipient. (If you hear a high-pitched signal instead of the
    recipient's voice, go to step 9.)
  8. Ask the recipient to set recipient's fax machine to receive faxes.
  9. When you hear a high-pitched signal, press <Color> for color sending, or <Black> for black & white sending. Then hang up the handset.
Jan 07, 2008 | Canon PIXMA MP530 All-In-One InkJet...
102 people viewed this question
old marine
old marine
