Question about Sony STR-DE545 Receiver
It works a few minites,then stops and displays "Protect".
Every time I turn it on,it works for a few minites,then stops and displays "Protect".I notice that when it stops,there is a transister which is surounded by a "U" aluminum plate gets hot quickly.
  • Yijun Zhao
    Yijun Zhao May 04, 2007
    Dear Dsom,
    Thank you for the solution,but I turn the volume down to the minimum,it still display "PROTECT".
This happens when you cross the speaker wires. the amp goes into protection mode. i would check the back for stray strands of wire touching. if thats not it it may be internal.
Posted on Jul 16, 2007
  • 56 Answers
Your complaint isn't a problem at all. This is a usual characteristic of the relevant amplifier. The protection mode comes on when the main volume/bass/treble or whatever is too loud. Unfotunately, you can not overcome it. But, as they always say: It's a Sony:)
Posted on May 01, 2007
Hello i have a 2000 toyota 4runner limited 4x4 . i live in maine and when i start the truck up in the morning to go to work, after the truck warms up it puts out nice heat. but after i drive it for 10...
bleed cooling system.run engine with red cap off till up to temp.replace cap before turning off engine.might have to add more coolant while running.
Feb 13, 2011 | 2000 Toyota 4Runner
Fans on both indoor and outdoor units are running but compressor wont restart, even after turning power on and turning back on. also, if compressor resets and runs, it'll run for a few minutes then trips...
the compresor have delay protection and this wil not alow compresor to run only after few minits (turn off the unit and disconect from the main power suply, wait 30 minits and after that turnit on) or the refrigerant gas in the plant missing. in this case you must call specializated personel to find the leack and fixit, after that they wil refil whit refrigerant gas (r404, r 134, or what your unit have)
Feb 14, 2010 | Heating & Cooling
Subwoofers stop working after few seconds
Check the subs wiring... follow the manual....
Jul 16, 2009 | Car Audio & Video
My washer will stay on for a few minits then it turns off i have to unplug it and wait a while then it works again for a few minits
Hi, this is a typical timer or , control board issue. the control sector is damaged. possibly a circuit malfunction or, a damaged chip set. replacing the timer control or, control board will fix this issue.
Jul 09, 2009 | GE WPGT9360EPL Top Load Washer
"Protect" and "Push Power"
i have a sony component push power protect, i have already replace IC but still protect push power
May 02, 2009 | Sony Audio Players & Recorders
Push protect problem/ sony MHC-VX33
push power protect is error signal shows problem in power amplifier board, mostly power amp out
IC STK402-100S found deceptive.
contact nearest Sony service center for proper repair.
Sep 29, 2008 | Sony MDS-JB940 Mini Disc Player
DRYER STOPS
could be thermal overload in motor its a motor protector in the motor when the motor gets hot it cuts power to the motor when motor cools it closes and resets age of drier counts some times you can take drier apart and blow dust out of motor and will fix now if the door is not closing tight vibration can cause door switch to break contact that will do it too most of time motor or relay must be replaced
Oct 27, 2007 | Kenmore 63942 Dryer
Sony STR-DE545 Receiver Logo
362 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
