Question about Dometic RM2852 Refrigerator
Dometic rm2852 does not run on gas
Fridge starts normally on electric when power and gas turned on. will start on gas but shuts off. fault light on. started on electric trouble light not on, some time later trouble light comes on fridge still works on electric but will not start on gas. Gas pressure to fridge is 10" of water. Board has been changed same problem
  • Desertphile Feb 23, 2009
    My RM2852 has the same problem. It runs on propane and 13.8vDC. After it shuts itself off to save energy, it will try to fire itself up again: the igniter fires properly for about 8 seconds, and then the igniter ceases and the fault light comes on--- the burner does not light. When we recycle the start sequence two or three times, the burner stays on.
    My assumption is that there is a temperature probe checking to see if the propane burner is lite.
    Is there a trim-pot on the ignition circuit board that adjusts how long the igniter runs? If so, would increasing the time it fires allow the temperature probe to heat up?
    We took the refrigerator to be services, but the service shop said there is no problem; however, we have this problem a dozen times a day at least. This problem has existed from the first day we got the refrigerator.
  • Anonymous Mar 24, 2014
    WE HAVE problems STARTING THE FRIDGE ON GAS. TT TAKES A LONG TIME TO GET IT TO WORK
So, the solution was simple but not obvious: the heat probe and the igniter are one and the same item, and all we had to do was bend the probe/igniter closer to the burner. After we did that the refrigerator started to behave properly.
Oddly enough, the repair manual for the refrigerator shows a igniter with a heat probe above it: the is not how the refrigerator is built.
Posted on Mar 24, 2009
    Sniper:
  • 68 Answers
Sounds like your ignitor porcelain is cracked. Yes there is a miliamp signal sent to the circuit board to stop the ingnitor from arcing
Posted on Mar 19, 2009
Fridge check light is on and fridge not cooling
disconnect thermistor on back board let run if ok replace if not bad board or cooling unit
Apr 02, 2013 | Dometic RM2852 Refrigerator
Wont start on gas - however if you start on electricity and switch to gas it will transfer over and continue on
my dometic won`t run on gas it starts after 1 min. it shuts off so i push the on------- button then gas but it lights then goes out shows faulted
Jan 19, 2011 | Dometic RM2652 Refrigerator
Wiil not cool
If the heater is geting hot and not cooling sounds like it is in the defrost mode just defrosting or stuck in defrost mode.If it is in defrost mode it should stop defrosting after a while and start cooling. They defrost every so many hours depending on how they are set.
Jul 16, 2010 | Dometic RM2852 Refrigerator
My dometic fridge will not turn on
Check to see if you have a switch for storage, on, off etc. usually between doors, or near top right corner of fridge compartment. It may be in wrong position.
May 14, 2010 | Dometic RM2852 Refrigerator
RM2852 has never worked on electric.
there a 3 electrical parts
1) the switch
2) the thermostat
3) the heater element
You will need to test for fault , but most likley is the element
Aug 16, 2009 | Dometic RM2193 Compact Refrigerator With...
Will not stay lit
The pilot sequence is designed to run for 45 seconds. It could be that the thermocouple is not triggering the cycle once the pilot is lit. I am having the same problem and intend to replace the thermocouple and then give it another go. The fridge works fine on electric but stopped working on gas last week.
Jun 29, 2009 | Dometic RM2852 Refrigerator
Royale rv fridge lights on gas then goes out
clean burner assembly with compesseed air if no fix replace electrode the spark thingy as most women say to me lol 33.50 most dealers
Jun 08, 2009 | Dometic RM2852 Refrigerator
Dometic rv fridge runs fine on elec, lights on gas but in one min shuts down. Dometic RV S1621 fridge runs fine with elec, when start gas operation. The burner runs for about 30 seconds then shuts off....
It is key that all control switches are in the correct position, depending on what power source you are using, gas, electric, etc. If the switches are not in the proper setting, the unit will not operate.
Here's the manual for your fridge that should be printed out for your use and reference (and reading enjoyment). It has all the info needed to operate and troubleshoot it.
Typically, when using any gas appliance with a pilot light, the sensor has to first be hot enough to trigger it to allow the safety gas shutoff to open and allow the gas to flow to the pilot/burner. Follow the instructions and you should be all set.
http://gasrefrigeration.net/dom_techdata/2707_2811SM.PDF
Hope you find this helpful and best regards!
May 03, 2009 | Dometic RM2193 Compact Refrigerator With...
Dometic RM2852 Refrigerator Logo
435 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
