Zenith digital tv converter -if i wanted to reverse the input and output -will it change analog to a digital signal ???????????
    Problem Solver:
  • 3 Answers
No, unfortunately it doesn't work like that.
Posted on Dec 31, 2008
Can I use my zenith TV tuner converter box model number dtt901 to watch my phone on TV
The Zenith DTT901 receives OTA (over-the-air) digital signals from TV stations and converts them to an analog signal to be used with an older analog television.
So the answer is no.
Nov 26, 2017 | Zenith Televison & Video
No optical plug on TV we wish to use it with. Have an optical to analog converter but can't get it to work.
If the TV has analog audio outputs, then you need an analog to digital audio converter. These converters are not bi-directional; thus the input can't be used for an output signal. This isn't clear from your description above. If your converter has optical IN and analog out, you might be better off with an RCA audio (M/M) to 3.5 mm cable (M) or adapter (RCA F/F to 3.5 mm M).
An analog to digital audio converter is here: http://www.gefen.com/kvm/gtv-aaud-2-digaud.jsp?prod_id=5278 . There are some converters that aren't compatible with all devices; you might want to try a different one. If you do have the correct converter, double check if you have enabled the external audio output on your TV. This will be in the Audio sub-menu for most LG TVs.
I hope this helps.
Feb 10, 2016 | LG NB2520A Soundbar System with Dual BuiIn...
How do I hook up Coby 5" black & white TV to my digital converter box ?
You will need a digital to analog converter which you can get at Radio Shack, Best Buy and most big box retail outlets or online. Your Coby is most likely analog and will require the digital signal to be converted to an analog signal from the digital converter box to the TV. UNLESS the digital converter box has analog (round connectors on the back) then you just need an analog RCA cable (which you can also get almost anywhere even your local CVS/Walgreens) to make the connection.
Nov 24, 2014 | Coby Televison & Video
Input signal.
You should be able to connect the TV to the antenna without the tuner converter box. If you still do not get signal you may need some type of signal amplifier between the antenna and TV. Hope that helps.
Dec 08, 2013 | Zenith Dtt901 Digital Tv Tuner Converter...
Digital audio output tv
Digital audio refers to technology that records, stores, and reproduces sound by encoding an audio signal in digital form instead of analog form. Sound is passed through an analog-to-digital converter (ADC), and pulse-code modulation is typically used to encode it as adigital signal. A digital-to-analog converter performs the reverse process, and converts the digital signal back into an audible sound. Digital audio systems may include compression, storage, processing and transmission components. Conversion to a digital format allows convenient manipulation, storage, transmission and retrieval of an audio signal.
Oct 13, 2013 | Insignia 42" LCD Flat-Panel HDTV
Hi,can I record digital transmissions on my sony slv-se820g vcr barry
You can record a digital TV signal on a VHS VCR but only in analog format. The digital signal must be input to the VCR by some component which has a yellow composite video output and a white audio output such as a digital cable TV box or satellite receiver. For over-the-air digital TV, either the TV must output analog video or you need a DTV converter box connected to the VCR. Bottom line, the digital signal must be converted to analog for the VCR since VHS VCRs generally are analog recorders.
Apr 12, 2011 | Sony SLV-SE820 VHS VCR
My digital tv tuner converter box with analog Zenith converter bo
Most DTV converter boxes have 2 outputs available; RF and component video. The RF goes in between the antenna and the TV and acts as a frontend tuner. The TV needs to be set to Channel 3 or 4 (depending on the box) and left there. All tuning is then by the converter box. By the way, you need to scan for channels as part of the setup. The other method is by using the audio/video component inputs to the TV and the set would then select AUX 1 or 2 etc to get the box input, and tune via the box.
Oct 03, 2009 | Zenith Analog to Digital Audio Converter
WHAT IS THE CORRECT WAY TO SET-UP TV, VCR, DVD, & DIGITAL CONVERTER BOX?
Connect the antenna to the converter box. Connect the output of the converter box to the vcr. Connect the output of the vcr to the tv. Connect the dvd to the component input (Red-White-Yellow) of the tv (if there is one. If not then connect the dvd to the component input of the vcr.
With this arrangement you will be able to tape programs on the vcr if you want. If the vcr is not on the signal from the converter box will pass through to the tv.
Jul 06, 2009 | Insignia Digital-to-Analog Converter for...
I have Rabbit Ears on an analog TV using a Zenith digital converter box. But how do I tape a TV show on my VCR that I'm not watching? I purchased another digital converter box to attach to the VCR but what...
The only way you can tape a different show than you're watching is to do as you have done: purchase a second converter box and connect it to the VCR as you did with the TV. You can pick up a device called a splitter which will allow you to divide the antenna signal between the two boxes.
There are some problems with the splitter arrangement. If you need to adjust the antenna position to get a good signal on one channel, like the one you want to watch, that may mean it isn't in the best position for another, like the one you want to record. You might need two antennas for the best performance.
Also, you can't program recording on different channels at different times unless you'll be home to change channels on the converter box. The VCR will only find a signal on channel 3 or 4, depending on how you set up the box, and you'll always record on that channel. The TV channel you record will be chosen by the converter.
Finally, you need to connect both the VCR and the converter box to a single antenna connection on your TV. There are two ways to do this. One is to use a splitter again. Normally they are used to split a single antenna input to two ouputs, but they can also combine to inputs into one output (basically you just use it backwards). Connect the ouputs from the box and VCR to the splitter's output connectors, and then go from the splitter's input connector to the TV antenna connector. This arrangement may not give the best picture quality, though. An alternative is to use an "A/B" switch, which allows you to choose which source connects to the TV.
It sounds more complicated to hook up than it actually is. It is more complicated and less flexible to use this setup than it was before the switch to digital broadcasting, but they call this "progress."
Hope this helps. If you need more information, just post a followup comment!
Nov 29, 2008 | Insignia Digital-to-Analog Converter for...
Computers & Internet Logo
David Payne
David Payne
