Question about Dell Inspiron 1521 Notebook
Windows Error Recovery
My Dell Inspiron 1521 won't load anything accept the 'Windows Error Recovery' screen and none of the security options (safe mode's etc) work.
Can anyone help?
  • 4 more comments
  • rimmer350 Dec 30, 2008
    I have tried a few of the discs that came with it, but none of them are being read, i just keep getting th same screen up.
    When i did a diagnostics test, the error code came up as: 2000-0146. Does that mean anything?
    Sure thing, i appreciate the help.
    No, i've never had the hard drive replaced, the error was caused by some software installation going wrong, but i can't get back in to delete it.
    Sorry, what does os mean? I'm not good at technical things.
    Oh right, it is Vista. No, the warranty ran out earlier this month.
    Cheers for the help, but none of these seem to be working. Every so often a blue error screen pops up, but it's so fast i can't read it before it's gone again.
  • rimmer350 Dec 31, 2008
    I've tried bootig off the disk and it starts to work but then it says that some of the files needed are missing or corrupted and i get an error code: 0x80070003
    I get a choice of where to save the new vista, which drive is best to save it in?
    Master:
  • 413 Answers
Try booting with the disk that came with the computer and start over with a fresh install of windows
Posted on Dec 30, 2008
  • 5 more comments
  • Dan rogers
    Dan rogers Dec 30, 2008
    give me a little bit to research this i have not forgot just takes a little time in the mornings
  • Dan rogers
    Have you had this hard drive replaced recently or ever?
  • Dan rogers
    sorry i forgot to ask but what os are you running?
  • Dan rogers
    OS means operating system, like windows 98,xp,vista
    But that is not so important now. Is the computer still under warranty?
  • Dan rogers
    This was somethig i found. Not too sure if it will work though. The command prompt should look like this C:\
    When i looked up the error code it just said that your drive has had errors on it before which made me think the drive was failing but now im not too sure this is the case. As for the code they are talking about below im not sure what yours is, This is some thing you are going to have to play with. Welcome to the headache of personal confusors
    This is the option of the last resort as it comes to salvaging your data and
    OS.
    Turn the machine off, turn it back on and IMMEDIATELY press two keys: CTRL +
    F6. If you hear a distress series of beeps (around 5/sec) keep pressing for
    about 1 min. After that release F6 but keep pressing Ctrl for a while.
    At this point the MS Windows Boot Console should appear and offer you
    choices. Choose Boot in Safe Mode With Internet.
    Now, that combination Ctrl+F6 is maker specific. It worked for my DELL
    towers. Other manufacturers reportedly have other "secret" codes.
    You may try Alt, Del, PgUp, PgDn instead of Ctrl. Also F6 is not cast in
    concrete. You may try other function keys. Some machine may require only one
    key to be pressed.
    Every machine MUST have a code like this. It took me about 10 min to find
    mine.
  • Dan rogers
    if you can get your hands on a actual windows disk. Boot off the disk and re install windows
  • Dan rogers
    Dan rogers Dec 31, 2008
    your operating system gets installed on the c:\ drive since that is the drive your computer is set to boot off of and the boot drive needs the OS installed.
Windows 8 will not load on my inspiron one 2020. after dell screen the screen just flashes
After you start your computer and the initial computer system display dissappears (before Windows begins) repeatedly pressing the F8 (I believe) should take you to a Multi-Boot selection screen. At that point you should see several selections for booting your system (ie. Safe Mode, Repair Windows, etc) I would select the "Repair Windows" option for the Automatic Repair. Let me know if it helps.
Dec 22, 2013 | Dell Inspiron One 2020 All-in-One Desktop
Booting problems
Can you get to ANYTHING? Safe Mode? Recovery? Restore? Command Prompt? Unplug, remove Battery, leave battery out, plug in, try to boot. post results. Do you have a repair disk?
May 06, 2013 | Dell Inspiron E 1405 1505 1705 PA10...
INSPIRON 640M WILL NOT GO INTO SAFE MODE , IT GIVES OPTIONS BUT NONE OF THEM WORK , THEN IT GOES TO THE BLANK SCREEN.
Try going to safe mode manually. The steps mentioned below will help you accessing the safe mode
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Safe Mode/Safe mode with networking".
Step 5: Select that and HIT ENTER.
Jan 20, 2011 | Dell Inspiron 640m Notebook
I have received a Blue Screen Error but I do NOT have the XP disk
if you cant get online on your pc you're gonna need to go to someone else's and download a windows boot disk from the ms website then boot your pc from that, choose recovery console then repair boot partition.
Feb 28, 2010 | Microsoft Windows XP Professional for PC
I am trying to restore factory on a dell inspiron 1521 and i is asking for an administrator password the only password i know i put in and it is not accepting it
If Administrator is the username, the password should be blank or none. (leave it blank) just click on Ok and it will go straight to the option of System Restore, Complete PC restore, Dell factory image restore. etc.. Hope this helps
Dec 08, 2009 | Dell Inspiron 1521 Laptop
Dell Inspiron 1520 laptop. Blue Screen
Dear, Requested data was not in memory. An invalid system memory address was referenced. Defective memory (including main memory, L2 RAM cache, video RAM) or incompatible software (including remote control and antivirus software) might cause this Stop message, as may other hardware problems. What you can do is if you have more than one memory modules, you can boot the system with single and see. If this is due to memory leakage issue, you can find it here
Oct 16, 2009 | Dell Inspiron 1520 Motherboard
Problem with windows. It won't boot up
this only problem with windows or virus....
you can use recovery to solve this problem..nothing else...check and it will work fine
Jan 08, 2009 | Dell Inspiron 6000 Notebook
Did you fix the Dell Insipirion 9200 video problem?
This sounds like your video settings could be set improperly, did you attempt to boot up in safe mode and then change your display options? Sometimes you need to monkey with windows to get it to accept new video settings, try removing the video display from the control panel, if this has been done and you can't correct the issue a reload may be in order or at worst case you may have a malfunctioning video card
Nov 19, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 1521 Notebook Logo
1,949 people viewed this question
Alun Cox
