Question about Dell W3000 30 in. HD-Ready LCD Television
Dell 32" tv speakers making popping sound
It started when changing channels, there would be a short pause in sound then a loud pop, now it just makes a constant popping sound, i tried using different speakers and using the dvd player, and got the same result.
  • 1 more comment
  • b4petersen Jan 26, 2009
    I have the same problem as well on my 32" dell.the right speaker went out about a year ago, and the left one went out days ago. the monitor works fine but is useless with out sound.
  • nbody Feb 10, 2009
    Same thing. It was the left speaker about a year ago, but it would come in and out. It started with crackling, so I just unhooked it and went with the right speaker for a while. Hooked it back up every now and then to check it out and it did finally work again. Then the right one started crackling a few days ago, so I unhooked it, then the left one started with the popping. Now both of them have basically crapped out, as of late last night. Watching tv with the CC on is not quite as interesting. I'm wondering how much new speakers generally sell for. The tv is almost 2 years old and works fantastic otherwise.
  • gumby9 May 11, 2010
    The sound goes out on these TV's after about 2 years. Dell is aware of the issue. They are working hard to ignore it. They no longer sell/support (Dell)TV's. They will offer to remedy the problem by selling you another (repaired?)TV for only 20% more than the price of a new one. I have called several times and sent several emails to customer (non)service. I sent an email to MD and finally got a response ( a flunkie sent a link to a repair place, they would not touch it). I think maybe it's time MD should get another email, or 2 or 3 or ?... Michael_Dell@Dell.com
SOURCE: Dell no sound
I got this solution from an apprentice on the site, try it out.
http://www.fixya.com/support/t577255-dell_w3201c_no_sound_after_two_years
Posted on May 08, 2008
SOURCE: dell 32' lcd
I tried this and went from no sound to a popping noise that does not adjust with the volume switch. It is either on or off.
Is there anywhere we can a replacement for this???
Posted on Aug 25, 2008
  • 90 Answers
SOURCE: DELL TV 32" LCD TV
the problem is the audio amp board has been fried. It needs to be replaced. This will restore the actual sound transfer to and from the speakers.
Posted on Feb 08, 2009
SOURCE: I have the same problem with my 3 year old Dell 32 inch Tv
The audio amplifier board has a number of components covered with a tough brown waxy, rubbery potting compound. Very careful and tedious removal of this compound exposed many corroded component solder joints. The problem created by this potting technique is apparently a common problem with this sound board. In my case cleaning the corrosion of the circuit board proved to correct the sound failure problem. (Not for the faint of heart).
Posted on Jul 13, 2009
SOURCE: I have a Dell TV 32 In.LCD W3201\r\
I had the same problem with my dell tv. It's the exact same one you have. It kept making noise at first, and then the sound just went out. I changed the speaker wires to a slightly stronger, thicker wire and now it works great!! I hope this works for you.
Posted on Dec 16, 2009
2010 VW CC factory stereo amp popping sound
If the amplifier itself is making the popping sound I suggest you disconnect it immediately, as it could be an electrical short within the amp. If the popping sound is actually coming from the speakers, it could be due to a crossed wire, blown amp channel, or blown speaker. If you posses the technical know-how, you can test the amp channel and speaker by connecting a different speaker to the channel responsible for the popping sound. If the new speaker makes the same popping noise then it is most likely a blown channel. I hope this helps =)
Sep 24, 2013 | JVC AM FM CD DET FACE CAR STEREO
The POP of death on my Vizio tv...now does not turn on
You will have to take it to a TV repair center. it definately sounds like a short or the board has blown.
Apr 29, 2012 | Vizio L32 32 in. LCD HDTV
How can I get rid of the popping noise?
It is the speakers on the tv fluxing sound is too loud. Change your bass settings or use a different sound system.
Jun 03, 2010 | Vizio VO320E LCD TV
Dec 05, 2009 | Dell W3201C 32 in. LCD Television
32'' Vizio LCD no picture or sound
Your filter capacitors have popped due to diodes shorting, P-channel FETs shorting from gate-to-drain. Pull-up resistors have changed value and as a result your capacitors have peaked (popped)....so now the tv is in protection mode to prevent further damage to your tv. Take it to your local shop for servicing, or take it back if its under warranty......
Nov 05, 2009 | Vizio L32 32 in. LCD HDTV
Makes an loud clicking/popping sound
The audio outputs are intermittently shorting to their supply and allowing DC voltage to pass - the speakers will be damaged if it continues. you can confirm this by measuring (with a dc voltmeter)at the speaker outputs for DC volts.
Sep 19, 2009 | Sony STR-DA50ES Receiver
Popping sound from speaker when changing channels
This noise is normal with the cable box unless you set the cable box on HDMI sound
Dec 26, 2007 | Bose 3 2 1 GSX System
Snap Snap Pop
Probable bad IHVT ( aka flyback transformer ) part # 257805
or Asti 2078...................................T.
Nov 09, 2007 | RCA F32450 32" TV
32 RCA makes popping sounds
It needs a new FLY BACK transformer. That is what you are looking at. The origionals are not made for the set any longer but insist on having a generic on installed by a local TV shop. I just put one into a RCA 31" and it works nice. Don't throw away the TV. Get it fixed. MAKE SURE YOU INSIST THEY USE THE GENERIC ONE! THEY DO WORK!
Sep 15, 2007 | RCA E13320 13" TV
Speaker makes a popping sound when car starts
may be the antenna jack such is connected in cassete is n't good
Jul 08, 2007 | Panasonic CQ-C8803U CD Player
Dell W3000 30 in. HD-Ready LCD Television Logo
615 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
