Question about HP DeskJet 9800 InkJet Printer
Unreliable printing with HPLaserjet P1006 and PC with VISTA
Often printer and computer need to be shutdown and rebooted in order for printer to work.
IB4G2008
  • 3587 Answers
SOURCE: hp Printer P1006 driver issues with vista
wow..if you remove the old drivers first..then go to www.hp.com for the freshest set, you might get lucky.
also Vista has a SP1 version out now..
Posted on May 07, 2008
SOURCE: HPlaserjet P1006 Series
dgfh
Posted on Aug 03, 2009
komguy
  • 2306 Answers
SOURCE: HP LaserJet P1006 Printer will not print HELP!!!
wwww.partsurfer.hp.com under the support link will have a manual to download.
Posted on Sep 01, 2009
  • 54 Answers
SOURCE: need software to install hplaserjet p1006
Visit the below web link and select the appropriate operating system to download and install printer software
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=3435684&lang=en&
Posted on Oct 14, 2009
cyberware
  • 196 Answers
SOURCE: Need software to install hplaserjet p1006
Kindly insert the PROGRAM CD in the CD ROM drive and auto run the aplication CD without connecting the printer,in few minutes of installation progress you will get alert to connect the printer and then printer is configured by OS Above is the normal procedure,
very minute but technical tip is to
connect the printer first and insert program CD for printer in the ROM drive and open device manager and scan for hardware changes ,you will get alert on task bar that new hardware is found and new window for device installation ,click continue with browsing file path for CD in drive and continue installation ,in next few minutes your device shall be ready to use. In case there is problem with installation with CD kindly go to manufacturers website and download windows compatible drivers.
For Safe Computing Kindly keep your antivirus updated and firewall is on.
Thanks And Regards
Kindly rate this solution
Posted on Mar 03, 2010
I need to reconnect my hplaserjet printerP1006 since my mother board was change .help
If your system mother board was changed, system might be formatted. Reload the drivers once again..
Sep 20, 2011 | HP LASERJET P1006 Printer
Thanks And Regards
Mar 03, 2010 | HP LASERJET P1006 Printer
HPlaserjet P1006 Series When printing getting a white blank streak down the middle of the page
To isolate the problem you need to do a 'half test'. This involves printing and stopping paper half way through the printer. This can be done by opening the toner door at the appropriate time. The paper should have just entered the fuser (watch out, the fuser is HOT). You should see the paper with the printing on it after removing the toner cartridge. Carefully turn the toner cartridge over and move back the door that covers the drum. DO NOT TOUCH THE DRUM. If there is the corresponding blank spot in the center of the drum, like the paper, the scanner is dirty or blocked. A can of compressed air will help here. If you have access to a different toner cartridge, you may want to try that first.
Jul 20, 2009 | HP LASERJET P1006 Printer
My wGPS606 wont print on my Windows Vista laptop!
I just found a way to enable the HP P1006 with a different print server (Liveprint on Orange Livebox router). Perhaps this might work with the WGPS606 wireless print server?
I set up the P1006 via the print server as instructed (I'm using Vista 32 Home Premium) but no test page would print.
BUT!! (with thanks to another another forum):
I selected printers, then right-clicked on the wireless printer I'd just installed and selected 'properties'.
Under the 'Ports' tab I deselected 'Enable bidirectional support'.
Problem solved.
Hope this helps.
let me inform you that this printer is not compatible with any wireless print server. The drawback is that it is not possible to network such printers. A printer needs a steady flow of data, which is easily accomplished when it is connected directly to a PC, but cannot be guaranteed when the printer is connected via a LAN. Also, these technologies require intensive handshaking between the driver and the printer.
The host-based software uses the computer's resources to process print commands and rasterizing data, taking advantage of the computer's memory and processing power."
Sorry I can't be more upbeat - but its probably useful to know that someone at HP thinks the job's imposible - unless someone out there has a fix?
May 11, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Hp laserjet p1006 printing jobs gets struck in printing queue
I know this problems in my part it was the hp driver.
My Solution is to use an compatible driver.
HP Laserjet 5 / or 6 standard windows driver.
After that i have not this problems.
The secound problem is that this printer have very less memory and big pages in a few times are not able to print.
Dec 25, 2008 | HP LASERJET P1006 Printer
Hp p1006 wont load/feed paper
i know this is not perfect but...
paper runs out during printing... so
1)open the front cover
2)close the front cover
3)IT WORKs
If i helped you please rate me
Dec 10, 2008 | HP LASERJET P1006 Printer
1020 PRINTER DRIVER HP
There are no drivers for fixya but I have found a workaround by some anonymous poster
Xp software&drivers will work in Vista after a little tweaking in printer properties.
1)Install the CD-Rom HP Software/Drivers that came with your Printer at the time you purchased it. These Xp software&drivers are Vista Compatible after tweaking the Printer Properties. Reboot after installing.
2)Goto Start/Printers. Right click HPLaserJet1020 then Left click Properties. An HPLaserJet Properties window should have popped up.
3)Click the Advanced Tab. Click the Print Processor button located at bottom of window.
4)Select print processor as>>>IMFPrint. Then Select Default Data Type as>>>RAW. Click OK.
5)Now return to the Main HPLaserJet Properties window and click the General Tab. On the Bottom of that window; Click the Print Test Page Button. Finished! A test page should be printing out if you adjusted the printer properties correctly. Enjoy!
optionally you may have to disable print spooling
Quote "This did not work for me until I changed the option in that same window (advanced settings) to "print directly to the printer". Spooling does not work. "
Jul 14, 2008 | Office Equipment & Supplies
HP DeskJet 9800 InkJet Printer Logo
22 people viewed this question
Ben Johnson
