Question about GE GSS20IEP Side by Side Refrigerator
Dent in Freezer
I had an icemaker that wasn't working, the green light was blinking. I took the icemaker out and let it thaw out and put the icemaker back in and it worked. Problem is when reinstalling it I chewed up the side of the interior of the freezer which is no dented in a couple places by a sharp corner of the icemaker part. It does not appear to be punctured, but I would like to be able to fill those dents with something to make those spots a little sturdier. Is there anything recommended to patch the white shell of the interior of the freezer?
  • 115 Answers
About the best that is going to hold in that moisture is jbweld then when it drys paint it white with touch up paint
Posted on Dec 30, 2008
Green light
Try unplugging the freezer for 10 minutes to reset the cycle.
Oct 17, 2013 | Danby 3.6 cu. ft. / 102 liter Chest...
The Ice Maker quit. A red light on the freezer wall is blinking.
a steady blink is ok and when you hold the flapper in should be a solid red light. if its blinking and solid when you hold it down the optics are ok. feel the weter fill tube going into the icemaker is it frozen it should be soft. if its frozen thaw it with a hair dryer. if thats ok chances are its the icemaker module which is the icemaker motor. hopethis helps...
Jun 07, 2011 | KitchenAid Refrigerators
ICEMAKER /WATER
The line in the back of the freezer section is froze up. Remove the ice-maker and use a heat gun or hair dryer to thaw. be careful not to put the heat gun or dryer to close. It wont take long to thaw. BB
Dec 15, 2009 | GE Refrigerators
Ice maker stopped working
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | KitchenAid KSRP25FNSS Side by Side...
I have a Whirlpool refrige. side by side and the ice maker has stopped working. The infrared light keeps blinking. I have unplugged it a couple of times as well as turned the infrared off. Any advice?
Sep 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Sep 05, 2009 | Whirlpool Refrigerators
Ice maker not producing any ice.
Pour about 1/2 cup of water into icemaker . Squeeze the black fill tub which is above the icemaker cup . If ice apears to be in it , this indicates that the weter valve is not completely closing , letting a drip ocasionally go thru and freezing inside the tube , ( water valve bad ) . that will be a different solution . If the icemaker dumps the cubes after freezing . and black tube is not frozen , replace the water inlet valve . If the icemaker does not dump the ice after frozen , replace the icemaker ( only 1 screw holds the icemaker in , located on rear portion on right , faceing down . Also check the icemaker rake , which should be about the 2:30 position . To thaw out the black tube (which runs thru the top of the refrig ) a 1/4 push on connector will be needed . Remove the icemaker and use a hairdryer aimed up into the hole . Cut the tubing to the fill tub behind the fridge about 9 inches from where it enters the top of the fridge . This will let warm air inside the top fill line to help thaw . Ocassionally blow thru the 9 inch tube until you can blow thru it . May take a day or 2 , depending how frozen the line is . Once air will go thru , install the push on connector to couple the cut lines back togather .
The blinking red light on the right side , is the receiver for the electric eye for cutting off the icemaker when the door bin is full , This blinking is normal . 2 blinks ...pause...2 blinks..etc .
Do not replace the filter if water flow is good thru the dispensor .
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
KSRA25IL ice cube tray won't fill
The fill tube is probably frozen. Its in the roof of the freezer. turn off the freezer and heat the roof of the freezer with a hair dryer, being careful not to get it too hot,and it should thaw and work again. If you can put the food elsewhere for a day, just turning it off with the door open should work also.
Nov 11, 2008 | KitchenAid KSRS25IL Side by Side...
Kitchenaid superba icemaker leaking/freezing in freezer section
Your water hose that connects to the back of the freezer may be loose. Move the fridge out away and in the back make sure it is tightend.
Let me know if it helped :)
Oct 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
General electic gsh25jfta bb
According to the manual for your refrigerator:
Blinking green light indicates an ice cube is stuck in the icemaker. To fix - Turn off the ice maker with the on/off switch. Then remove all of the ice from the icemaker by hand and turn it back on.
I hope this helps.
Jul 19, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
GE GSS20IEP Side by Side Refrigerator Logo
143 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
